robin303
70 -
About robin303
- Birthday 04/21/1978
Gender
Male
Location
Holland
robin303's Achievements
It would be that bad if it's Sysex on a specific channel. So how does the automapping feature in Novations Remote SL work then? Preconfigured patches? There must be some kind of "program change" signal coming from Reason for automapping to work, right?
Hi everybody, first of all it's nice to be back after a long absence. It's cool that the midibox forum is still an active community :-) Anyways, I finally have some time to work on my box again which I completed nearly 1.5 years ago (I'll post some pics of the finished work soon). It has been gathering dust ever since finishing it, just because I never came round finishing the software. The assembly language is just to darn hard if you only have 3 or 4 hours per week. However, I have been watching the porting of midibox apps to C and since this language is more in my alley, it is interesting to play with this. Back to subject :D I have read about the Novation Remote SL and its 'automapping' concept sounds pretty good to me! But how would I make my MidiBox 64 'learn' from a host application like Reason or Ableton which parameters are available? For instance when I activate a ReDrum module in reason, does Reason send out all its parameters over midi? Could the midibox then read this data and thus automap it to any available pots/buttons/leds on my Midibox64?
Ok, you are welcome! Oh and don't forget the stuff on the right side of rebirth. Personally I love tweaking the PCF, Distortion and echo controlls when doing 'live' performing!
Interconnecting Rebirth and a MidiBox...
robin303 replied to Basile's topic in Testing/Troubleshooting
Somehow, this topic ended up here: ::) http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=france;action=display;num=1095861271;start=0#0 -
You won't need REWIRE. You must be able to attach a midi device to your computer, that's all! Then you will set Rebirth to listen to remote control commands on channel x. And you set your connected midibox64 to output data on channel x. Okay, but how to start on designing a rebirth midi controller? First of all you will need to figure out which rebirth knobs you can control via midi by looking at the rebirth midi implementation (one of the documentation pdf's). Let's start for example by looking at what you would need to control the first TB303.  ;D TB303-1 Pots/Faders: Pattern selection, Tune, Cutoff, Reso, Env.Mod, Decay, Accent, Pan, Level, Delay Amount... That's 10 pots/faders. TB303-1 Buttons: Waveform, Pitch Mode, Clear, 13 note buttons, down, up, accent, slide, note-on, note-off, back, step, distortion send, pcf send, compressor send, pattern on, mix on. That's 29 buttons. But do you need all these buttons? What do you want to control? Maybe you don't want to program the 303's from your midibox, in that case you can loose all the buttons related to programming and just stick to the ones needed for live performing on your box. So that's waveform, distortion send, pcf send, compressor send, pattern on, mix on. You must also define the number of pots/faders/buttons needed for the second 303, for the 808 and for the 909. In other words, you need to make a complete overview of the needed controls. When you're done with that you can start sketching/photoshopping or use front panel designer (http://www.schaeffer-apparatebau.de/English/FPD_index.htm) to make a design. Try to make the design intuitive, so will be able to know what buttons controls what without the need for labels and all... This is all creativity  ;) You could for instance make two rows of 10 pots to control the two 303's. And under this the layout for controlling the 808/909. I would, like the program does, keep the master section to the right, put pcf controls under this, put delay controls under this etcetera. In other words, keep the basic location of controls the same as the onscreen counterparts. When done designing, think about if you want/need to have an lcd screen, motorised faders, a midi-thru... And then we will know what hardware you'll need. The amount of modules depends on the amount of pots/faders/buttons that you are going to need.
I hope you understand English, I can understand a little French but I cannot write it  ;) I have succesfully played around with Rebirth and my midibox64. It is great fun and works very, very well! There are standard controller numbers for all the common knobs and faders. For example: cutoff, resonance, volume, 'send' amounts, pfl, echo, distortion etcetera. Really almost everything can be controlled! If you take a look at the midi implementation chart in your rebirth manual you can see which controller and note-on numbers are used. It's also possible to program the patterns of the 303's. For this to work, Rebirth must be set to the "program synths" setting. You can program your box in a way that it will do this automatically (with a meta event). Now you can assign buttons to the step, back, up, down, accent etcetera buttons of either one of the 303's. Voila! Remote programming. Note that remotely programming the 808/909 is not possible in Rebirth. Last but not least, very handy for live performing or jamming, you can trigger patterns from the midibox. By sending specific note-on message via midi, you can select the pattern for each one of the four modules. However, the midi implementation for pattern selection kinda sucks in Rebirth. You have to first send an A,B,C or D note-on message and after that a 1,2,3,4,5,6,7,8 note-on event.. Because I didn't like this I have written a very handy meta event (a piece of code that you put in the ram of your midibox). This enables you to select patterns by turning a knob instead of pressing a button (like it works in Reason). If you're interested I can post the code of this metaevent here. I also have configuration files for you, once you have built your box! Hope this information is usefull and that you can read English  ;D
Working with banksticks and banks
robin303 replied to robin303's topic in MIOS programming (Assembler)
Thanks for the xplanation, I tried it out and all my 4 banksticks seem to be working perfectly :) Now, some more challenge, I hope you can help me on the way with this next thing. I'm really anxious to try and learn how to program my box. Let's say I would want to copy a "preset bank" into a "working bank".... I have created some preset banks to control different instruments in Reason. So there's one bank configured for the Mixer, one for the Dr.Rex, one for the NN-19 etcetera. I have stored these preset banks in bank 51 to bank 62 of my midibox64. I also have 16 "working banks", stored in bank 1 to 16. Now I would like to create a metaevent to load one of the "preset banks" into the currently selected "working bank": MB64_META_Handler_03 ;; input value 51-62 (0x33-0x3E) in MIDI_EVNT_VALUE ;; This will copy the SOURCE bank n to DESTINATION current_bank ;; 51 - reMix module 57 - RV7000 module ;; 52 - Subtractor module 58 - Scream4 module ;; 53 - Malström module 59 - BV512 module ;; 54 - NN-19 module 60 - Small FX modules ;; 55 - Dr:rex module 61 - MATRIX module ;; 56 - reDrum module 62 - General controllers ;; Only continue if the current bank is a "working bank" (between 1 and 16) to avoid overwriting the preset banks. movlw 0x10 ;Set W to 17 IFGEQ MB_BANK, W, rgoto MB64_META_PATCHLOAD_NOTOK ;If MB_BANK >= 17 then goto MB64_META_PATCHLOAD_NOTOK error message movf MB_BANK, W ;store the current bank number in W (this is the TARGET of the copy action) movff MIDI_EVNT_VALUE, MB_BANK ;change current bank to bank MIDI_EVNT_VALUE call MB64_BANK_CopyFromExternal return This is not working. When I trigger the metaevent while I'm in "working bank" 4, I do see the *** snapshot *** message, but after this the midibox returns being in bank 1 without any evidence of a copy actions having taken place. :-/ Do you see any mistakes in my code? -
For pots, go to the Reichelt site and type in the search box: P4M-LIN 10K for pots with 4mm shafts and P6M-LIN 10K for 6mm shafts. The m stands for mono, which you will want for this purpose. LIN stands for linear, like Steven_c said, you will need Linear pots and faders, not audio faders which are exponential. http://www.reichelt.de When I last searched at Reichelt, they didn't have the right faders so I ordered these at Conrad. But beware, the cheap ones (say around 2euros) really do feel cheap (although they work perfectly reliable on my box). http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTE3OTM5OTAxNDI=?~template=pcat_area&p_load_area=241780&~target=area Good luck ;)
You could download the AIN/DIN/DOUT test application. This worked very fine for me when troubleshooting my newly-built mb64. Just make sure that your analog input pins are all connected to ground. Here's the link: http://ucapps.de/mios/ain64_din128_dout128_v1_3.zip
This afternoon, I have added two banksticks to my midibox64 (which already had one functioning bankstick). So now there are three of them in my box. But I can't seem to find them! I made sure that the DEFAULT_BANKSTICK_CS setting in main.asm is set to -1. How can I verify if MIOS can access the extra 32 banks? Where do I find them? Once I get it to work, I would like to write a meta event that can copy bank a from bankstick b to bank x on bankstick y. Is this possible? Thanks for any help :)
Change Global Channel with a meta event
Oh by the way. With the Global Channel thing (that's what this topic was for :)) .... I want to display the channel change in the display once I turn the potmeter. So I made this: ;; -------------------------------------------------------------------------- MB64_META_GLBCHN_CHANGED_L1 STRING 16, 0x00, " Global Channel " MB64_META_GLBCHN_CHANGED_L2 STRING 16, 0x40, " Changed To " MB64_META_Handler_08 ;; Change global midi channel to MIDI_EVNT_VALUE from potmeter [00-0F]. movff MIDI_EVNT_VALUE, MB64_GLOBAL_CHANNEL call MIOS_LCD_Clear TABLE_ADDR MB64_META_GLBCHN_CHANGED_L1 call MIOS_LCD_PrintMessage call MIOS_LCD_PrintMessage ;; set cursor movlw 0x4C call MIOS_LCD_CursorSet movf MIDI_EVNT_VALUE, W call MIOS_LCD_PrintChar return Now I have two problems: 1. Printing the value MIDI_EVNT_VALUE, the display does not show me the channel number but a vertical bar graphic. 2. When I turn the potmeter to quicly, I can only see my message for 1/10 of a second. Because the normal display page is stealing the focus back. Can I override this behaviour and make my message the 'boss' for two seconds? -
Yes Thorsten, you are right. After opening MidiOx I have verified that all is being received correctly. The 'hanging' meant that the midibox was not responding to anything anymore. But obviously it was busy sending data. I am using the 1.0c release of sysexbox. So I would suggest you make some kind of 'busy' flag in sysexbox, so that one can see that's it's still working. And maybe you can take a look at the 'bytes received' and 'blocks received' fields, because here they don't reflect the actual amount of data sent. That's pretty confusing. For the rest of it, great software! ;D -
I am using a Midiman Midisport 2x2. Requesting Mios Program memory returns 1 block (1184 bytes) then crashes (hangs) my box and -after a while- reboots my box automatically. Requesting a 32k or a 64k bankstick dump crashes my midibox. It reboots after about 1 minute. Requesting Mios EEPROM memory makes my box reboot as well. Requesting a midibox64 bank works perfect. 8 blocks, 2120 bytes. I'm sorry for the weird results but that's the status :'( I did the tests several times, restarting both sysexbox and my midibox quite some times. -
Yes it's a stupid mistake. I just didn't think about this parameter change that I did in MidiOx. Like I said, for .SYX updates, 350ms works perfectly fine. Weird huh ??? I tried the latest version of sysexbox and it worked perfectly for MidiBox program upload and for a settings.syx upload. ;D 8) However, the 'request dump - mios program memory' feature doesn't give much feedback. I know something is happening because my send and receive leds are burning for a while. But then the Leds go out and the status tells me only 1 block was received (1.184 kb). On the bright side, requesting banks seems to work OK! Is there any way to convert the requested bank data back to a text file format?
