![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Tanstaafl
268 -
About Tanstaafl
- Birthday 09/08/1956
Contact Methods
Website URL
http://www.ggbnet.com
Gender
Male
Location
Houston, Texas
Tanstaafl's Achievements
![Rank: MIDIbox Tweaker (3/4) MIDIbox Tweaker](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
custom keyboard/controller to control arturia's jupiter 8v vsti?
Tanstaafl replied to gooner's topic in Design Concepts
I have made 2 arturia control surfaces with mbhp. MMV and miniMoog. both work great. good luck -
again, too dang kool ! I have all of the parts for this, think i will burn the pcb this weekend and give it a try, Thanx Prof !
Too Dang KOOL! specs / schematics?
sooo kool ! now all u have to do is hack MIOS and make the lcd's display cyrillic.... hee hee hee great looking box, bud. gb
Here is the next incarnation.....still some bits to go... but getting there gb MBSEQ-next.pdf MBSEQ-next.pdf
eventually I will have all of the Din's and Dout's connected... but they will have to be separate drawings... unless I can do it in flash or something to get all the layers.... like I said, a work in progress. The original is done with photoshop so I have layers to work with. p.s. I have not taken the test, but I don't believe fish drink. Respiration / osmosis? might take care of the h2o requirement? gb
Here is a work in progress for my front panel interconnections to DinX4 & DinX2 modules only the first is connected, taking my time with this.... SeqV3-FP-InterconnectButtonsSwitches.pdf SeqV3-FP-InterconnectButtonsSwitches.pdf
Mellotron Sounds library - best commented library ever!
Tanstaafl replied to TheAncientOne's topic in Miscellaneous
p.s. Thanx Stryde!!!! -
ok, sherman set the wayback..... I messed with walkmen clones, old 8-track hardware.... been there done that... it's REDICULOUSLY expensive.... The Mellotron dudes got it correct the first time... a standard capstan that spins everything at the same rate.. but the wear and tear... then I bought my first Kurzweil in a pawn shop... old K2000S maxed out the RAM and OS. About 500 USD. ..... that's kinda when I gave up on the tape thing.... it has tickled my fancy a few times since then... but I do find it to be much more satisfying to just spring for the pro samples... and put em in the K2000. my 2cents -
BTW, we survived IKE !!! no power or internet for 5 weeks, thank you very much.... I can't believe this in Houston!! anyway, nice to be back c ya -
I've been working on a DIY Mellotron since the 70's...... grrrrrrr -
uhhh, heat it up with your soldering iron and pull the wires away.... then use a hobby knife to scrape the leftovers off the board, then drill the holes that got filled up? i use that procedure on a regular basis... if there is a better one, lemme know!! gb
these are personal preferences, at this point, your questions are about esthetics. everybody has a different vent on what looks good.. or might be usable as an interface good luck with your particular interface ! gb
