timnoserider
    3
About timnoserider
  • Birthday 01/01/1
  • Gender
    Not Telling
timnoserider's Achievements
MIDIbox Newbie
  1. Hi Thorsten! Thanks for the quick answere. I rewired the power connection . This reduced the jitter to a value of <3.
  2. Hi! I have 8 MFs connected to a core module (unmuxed), exactly as described in mbhp_mf_interconnections.pdf (including the 100nF capacitor). The jitter monitor measures a jitter of 3 to 8. That would mean I had to set AIN-Deadband to a very high value to avoid sending midi-events triggered by the jitter!?! Btw, I have a second core with MFs connected where I measure a jitter of 0. Any suggestions what could cause the jitter and how to avoid it? Thanks in advance
  3. Hi there! I just got 2 Cores and several DINs & AINs up and running. The Cores are linked via Midibox Link and everything works so far... But now to my problem: All buttons and faders are working and sending midi events when pressed or moved. But if I press a button that is connected to a DIN-module of the first core, I have to wait for approx. 2 or 3 seconds before I can use any button or fader connected to the second core. This only occurs in the described situation, everything else works without noticeable delays or other problems... Any ideas what could cause the delay? Besides a minor question: when two cores are linked via Midibox Link, where to connect the midi-in /-out LEDs? I connected the LTC-module to J11/MI of the first core and J11/MO of the second (MAX not stuffed). The midi-out LED works fine but the midi-in LED flickers all the time (without midi-events received).
