aleintrance
    10
Everything posted by aleintrance
  1. thank u thorsten for the fast reply I'll check all!
  2. Hi all!! My seq is up and basically working, but I still have some probs: 1 - I've mounted alps stec detented encoders. When I turn of a click an encoder the parameter advance by 2 steps... Where have I to modify? 2 - Some strange artifacts happens to LCD: sometime when I modify i.e. step 3, another step change visualisation, and after it show back the correct info. I've cleaned all the solder flux on LCD and Core boards 3 - solo button and enter button doesn't work checked and rechecked with the tester it's ok. Is there a prg to test buttons and encoders? 4 - sometimes pic restarts without logic.... 5 - bankstick not working (modify on pin 28 ok) Hope someone can help me. Sorry for my english Thank u in advance
  3. Oki moebius! After 5/6 attempts also the b verion was d/l. Thank u for your patience.
  4. thank u moebius! The link to the version c is working, but the link to version b tells 'service not available' (not 404) probably it's the same file redirected from http://mios_tools.midibox.org/ Anyway I've d/led the version c Thank u
  5. Nope! It doesn't work here. ???
  6. http://mios_tools.midibox.org:80/ doesn't work, could someone help me? Thank u in advance!
  7. Hi all! I've just finished to put together all the components. I've burned the bootstrap loader, downloaded the MIOS 1.7. Now I've opened the zip of the seq v2.1 program and I see 2 files 'main.syx' and 'setup_mbseq_v2.syx'. Have I to download all the 2 progs? in which order? Thank u in advance!
  8. Ciao! I'm wondering about many of us (like me) may have one or more 'retro' synts.... I'm very far about writing code.... but I think it  hasn't to be difficult to make it work: 1 core 1 AOUT may be an USB module?  :P .....only for mad scientist. Hope this may be a seed.... if someone hasn't already talked about this before....
  9. Thank u!
  10. Hello Boxers! I saw the little draw at the bottom of the pdf of din connection, but I can understand exactly wich is the common pin of those encoders. Is that draw viewed from knob or from pins? Thank u in advance .... my seq v2 building started today
