22 -
Everything posted by JazzyPidjay
i think is impossible, but don't know for sure 127 sensors, are not easy to build and a linear slider, it's surely a better way..
ooh yes neo-lo-fi picture !! 8) yes stick the jack in your nose and ready to play :-*
ok good question ! and i have the solution :P excuse my english, if u don't understand something it's surely because of my expression, but i try. 1- the first problem i have encountered is when i touch a sensor the message 0,127,0,127,0,127... was send in loop to resolve this problem i have simply connect the 0v of the midibox to the ground. 2- ok at this stade, when i touch a sensor it send correctly the values like a button. (but very quickly and intuitively) but when i touch to or more sensors, there's no more message send or messages are send randomely. to fix this problem, i simply plug myself ;D with a jack in the belt directly to my skin connected to the ground ;D Now my body was perfectly at 0v, the computer & the midibox also !! and i can touch 32 or more sensors, without any problem, like a button. i search a better way to solve this problem, but for now i plug (myself) & play ;D Now i'm on way to design my definitive midibox with two circular "camembert" of 7 & 9 parts and some linear touchsensors of 12 parts... 8) From where come this purple colour of your board ? ???
Hi thorsten ! i don't know how to create a meta ? i have read this file : midibox64_sfb_table.txt and i know i can set Meta Event values in "Edit event" in my Midibox. but i don't know "where" and "what" i must do ? thanks
Hi !! after many tests, with the Vmidibox64... i can't understand how two buttons can send Program Change + / - with a potentiometer, i'm able to send Program Change (0...127) but it's not very easy to set up like this. With the button i can only set the Program Change to a specific value. ??? Anybody know how to Increment/Decrement Program Change ? thanks
exactly, on my definitive midibox i will tinned the pads ;) and varnish each pad with a varnished conducting. here is my testing board, if it's help !? (10x15cmx300dpi) the circle is approximatively 9cm. http://img.photobucket.com/albums/v439/jazzy_pi/pcb.jpg ++
http://www.ucapps.de/mbhp/mbhp_din_touchsensors.pdf is what you wanna know ?
i have made it. simply draw the layout with Eagle. and use the copper side for both components & sensors. it cost about 6 €uros, (it's just my testing board) Board, Leds, Resistors, that's all (if you already have the perchlorure, etc...) it's more clear ?
:D no problem, probably tomorrow !!
it works perfectly, thanks !! 8) (it was a ground problem...)
here is a small video (without sound) we can't really imagine the ease of use with this video, it's a real pleasure. :-* the three sensors of the bottom are in "toggle" mode and the three on the top are in standard "hit" mode. http://mercury.walagata.com/w/jazzypidjay/touchsensors.avi Now make a beat with my computer is really easy like make it on a table :o
i can share all things that you want... but i have don't understand some questions ??? (i'm french) all that i can say for the moment is, I have simply use the touchesensor fonction of the DIN (with 47k & pin 14...) and made a copper board, that including the led for the DOUT (useful for the Toggle Mode) and copper for the DIN. Sensors & Leds works perfectly !! and it's the fastest way to trigger sounds that i know !!! :o :o WOW!! if i pressed two, three, four or more sensors at the same time, no problem i received all the notes in Cubase, without any latency !!! great !!! it's definitively the heart of my future midibox, soon finished. what exactly do you wanna know ? if i can help you...
i'm sorry the touchsensors are already polyphonics !!! Great ;D Thanks very much Thorsten, you change my music.
Change all banks (128) with Vmidibox64
JazzyPidjay replied to JazzyPidjay's topic in MIDIbox Tools & MIOS Studio
Great, thanks very much :D -
Hi i love touchsensors :o !!! thanks for this Thorsten you change my way of life !! 8) with this test board, i can make toms rolls or phat breakbeats with only one finger, and a small circular movement !! :o BUT... :-\ when i touch two sensors in the same time, i heard one or the other sound randomly. is there a way to have touchsensors acting like buttons ??? (polyphonic?) I wish that it be possible by any means.... :'(
thanks ;)
Hi ! Anybody know if it's possible to modify the parameters of all the banks in only one send ? because i wanna set 2 buttons in all of my 128 banks and don't wanna believe that send 128 times is the only solution ? thanks very much.
??? i think i haven't understand ::)
hi ! anybody know if all the expression pedal are built with 10kOhm potentiometer inside ? can i buy any model of expression pedal ? thanks very much.
hi ! it's strange, when i plug my midibox directly on my cheap casio synth the touchsensor work very well !! (great things... :D) but when i plug my midibox into my soundcard (Echo Layla24) the touchsensor send 0,127...in loop, even if i change the touchesensor sensibility .. ??? any idea ?
my touchsensor now (testing) is a simple copper / epoxy board with the appropriate resistor and without the DIN resistor, like recommended on the site. so, i keep on searching the solution. thanks thorsten ! :)
Hi ! (MB64 & Mios 1.7) i have test the touchsensor with sensibility set from 1 to 32 and it still send 0, 127, 0, 127... in loop when i touch it. ??? any idea ? can i really use a touchsensor like a button ? or it's normal ? thanks very much ;)
ok thanks you very much. :)
nothing new ? :'( nobody can explain how to program bank buttons in the mios ? :-[
:) - Yes i have look to the schematic to DINX4 and i have connect the touchsensor (copper plate) correctly but it still send 0,127,0,127,0,127 in loop, until i have the finger on the copper ? it's the normal fonction of it ? really strange. - For the dedicated Bank Up & Down button, anybody have the time to tell me more about USER_DIN_NotifyToggle, and MB64_SFB_Handler_02 ? after many try, i'm unable to realize my dream :'( Thanks Thorsten !
