squid
    4
Everything posted by squid
  1. There seems to be a problem with the DIN pcb version 2. I read the board as version 1. Am i totally stupid or what? regards sqid
  2. Than you very much Thorsten. I had scanned through all the relevent asm files to see just what the minimun was i could get away with, but got stuck on the DIN board.... i assumed that the board had to be filled with at least 4 (74HC165) shift regs, but now i know better. But what about the disabled AIN multiplexers.............................. How do i connect 6 or 8 pots to the core without a mux?? what am i not seeing here?? I shall go back to the job and have a good think. Very best regards and thanks again for your speedy attention. Squid.
  3. Well, well, Weller... reasonable price, long lasting, spares easily obtained and good iron-coated bits. The temp control depends on a magneic effect known as the Curie point, so theres no fancy electronics to fail at the wrong moment, A tip... always keep the sponge wet, that way you will make a good joint ( all else considered), and greatly increase the bit life. hope this helps, Regards all.
  4. !!!!!!!!   I pressed tab and my post was accidently posted..... To begin again: can anyone advise me on the minimum number of parts i would need for the following midibox design? 6 pots, 16 buttons, no lcd display, no banksticks. what software options would i need? Midibox64? Has anyone built such a meagre box??? Thank you.
