gemini2039
    10
About gemini2039
  • Birthday 01/01/1
  • Gender
    Not Telling
gemini2039's Achievements
MIDIbox Newbie
  1. Thanks !!! that was the problem ... now it's working ... ;D ;D ;D
  2. I noticed something , I don't know if that could be the problem ... on this page http://www.yanansi.co.uk/lcd/12864/ there's the reset pin but on the lcd it's written RET ... is this the same or is it a mistake ??
  3. the first picture was with the driver lcd7_ks0108 ( http://gemini2039.dyndns.org:63333/DSCN0569.JPG ) when I only put the mios and the change id utility ( with 1000 for glcd ) I get this : http://gemini2039.dyndns.org:63333/DSCN0570.JPG sometime the writings are at the bottom of the screen ... I've check the connections many times ... I did it once again to be really sure but I don't have any bad or inverted connection Thanks for helping !!!!!
  4. ok sorry for all the posts !!! I'll wait for TK .. thanks for your help Moebius !!!
  5. cooooooooooool man now I have something on screen.... I know now why you're as a god in this forum ... loll but how to say I still have a problem ... can you have a look at this http://gemini2039.dyndns.org:63333/DSCN0569.JPG Thanks !!!
  6. Hello, I hope I'll get this f.... graphic lcd working .... My pic id should be fine now ( changed with the change ID soft ) I would like to know what to do with the Reset pin ? is it important ? I've connected all the others.. my core module is loaded with the bootstrap loader and the mios... the screen turns on when I power and the backlight too.. I've add a 10k for contrast and this works too .. should I see something now ?? my glcd is a hs12864-3b I've bought it on ebay http://cgi.befr.ebay.be/ws/eBayISAPI.dll?ViewItem&category=75520&item=5188914396&rd=1&ssPageName=WD2V here is all the pins I have ... http://www.yanansi.co.uk/lcd/12864/ I've seen that D/I was R/S so I nly need the Reset Thanks for helping !!!!!!!!!!!!!!!!
  7. http://www.websitetoolbox.com/tool/post/diykit/vpost?id=419861 This was the answer it seems that I need another pic programmer compatible with ICPROG
  8. I've bought a Pic programmer which works with Micropro http://kitsrus.com/index.html because I had toooooo much problems with the JDM ... but now I'm a bit stuck ...
  9. Hello , I've made the core module , everything is working fine but I want to put a GLCD on it so I have to change the ID with 1000 at the end .. But with this program I can't ... it has got and ID field but with only 8 values ... and if I put ffffffff in it I get :080000000F0F0F0F0F0F0F0F80 If I update my hex file with the good id , the program doesn't care about the 1 I've put because when I save the file I stil have all zeros on this line ... Is this program shitty ???? must I change to another one ? or can I put an glcd without putting the 1000 ID ??? Thanks for helping !!!!
