dimi
24 -
Everything posted by dimi
[SOLD!] MidiBox SID incl. C64 Housing / Frontpanel / 4X 8580 / many Parts
dimi replied to dimi's topic in Fleamarket
SOLD... Topic can be closed! Thanks! Dimi -
Only the Control-Surface isn't finished. Next thing to do are the LINK-BUTTONS on the control surface an all other Buttons and Encoders. Finished are all SID-Modules, all CORE-Modules, all DIN, all DOUT, the internal Memory and PSU. -
Yes, it will come with 2 original C64 Transformator... the PSU is already built in. I hope I didn't misunderstood you. But this MidiBOX Sid isn't completely finished yet... Nearly the complete Control-Surface has to be done. -
Hi Since we produce no more music and have completely sold our equipment 2 Years ago, I offer here my nearly finished SID. I will probably never finish this project and also have no more use for the SID :( This offer contains everything you can see on the pictures below. All DIN, DOUT, CORE and SID modules, the C64 housing, the front plate, the original C64 Transformator (2X), all Encoder and many other (spare) parts. Some parts are from other DIY - Projects like Trevor's 9090 or the Gyraf SSL-Mixbus Compressor and Acidcode ML-303 Projekt (for example there are more than 20X THAT 2159 VCA) It's just a bonus-add-on that comes within this offer ;) It comes with all documents I have, but everything can be found here at ucapps / midibox. Everything is built and soldered well with care by a professional service technician ;-) In order to get a better overview, you should have a look at my old blog: http://www.midibox.org/forum/index.php/topic,5950.0.html Price is 350 Euro fixed plus shipping fee for an insuranced Package via DHL from Germany. Shipping fee is: 10 Euro within Germany 32 Euro within Europe 62 Euro to the US Maybe you have to pay tariff, if outside the EU. I will not sell single items of this offer. Exclusively completely. Payment via Paypal prefered. If you have further questions don't hesitate to ask. If you like to buy this machine, pls contact me via the PM function within this forum. Or send an Email to dr.dimsen [at] googlemail [dot] com Thanks again to all who supported / helped me while building this unit so far. Dimi
Die Frontplatte kostet in dieser Ausführung ca 170 Euro inkl. Versandkosten und MwSt.
Aluminium eloxiert natur. Sieht sehr gut aus wie ich finde.
Vielen Dank für die Infos/Bilder :) Da werde ich mir noch gut was einfallen lassen müssen was die DIN und DOUT Module angeht. Wahrscheinlich mache ich es ähnlich. Viele Alternativen hat man da ja nicht ;) Wird nicht leicht werden, vor allem da ich ja ein komplett 3. DIN-Modul habe, das nimmt schon mehr Platz weg, als Dein DIN1X im Plastik-Tütchen ;D Die Taster um eine viertel Drehung zu drehen ging leider nicht, da meine Taster im Gegensaz zu denen die Du verwendeten hast noch einen zusätzlichen PIN haben (Gehäuse). Naja, den könnte man anbknipsen...ich schau mal. Weiter Bilder folgen...
Danke für den Tip :) Hat ganz gut hingehauen. Wenn man sich die Taster mal so von der Seite anschaut, sieht es im ausgebauten Zustand grauenhaft aus. Eingebaut geht es allerdings. Ich denke wenn ich später die langen Tasteraufsätze noch kürze, fällt es kaum mehr auf. @Thorsten: Ich habe mir bei dieser Gelegenheit nochmal die Bilder von Dir genau angeschaut. Wie hast du eigentlich die DIN und DOUT Module befestigt? Das ist unheimlich schlecht zu erkennen. Ich glaube da wird es noch ein ziemliches Platzproblem geben. Auch habe ich auf Deinen Bildern nur 2X DIN gesehen. 3 Stk. werden jedoch benötigt. Wo hast Du das 3. DIN-Modul bloß versteckt? ;) EDIT: Habe es entdeckt, versteckt unter den Flachbandkabeln auf der rechten Seite im Oberteil des Gehäuses. Hast du die ganzen Module auf "Pappe" geschraubt und diese eingeklebt? Was mir aber jetzt noch fehlt ist das 2. DOUT Modul, da habe ich nur eins entdeckt :)
Allerdings, das kann ich genau so bestätigen. Was sich ebenfalls etwas schwierig gestaltet: Die Lochrasterplatine mit den Microtastern für die Modulationsmatrix. Sitze nun bereits am 3. Versuch ;D Entweder passten die Bohrungen für die Montage an der Frontplatte nicht, oder aber die Taster passten nicht 100%ig. Daraus folgte dann, daß bei 2-3 Tastern kein Tasthub mehr möglich war. Gar nicht so einfach das ganze. Bei den Tastern hat man nicht viel Spielraum. Die sitzen alle direkt neben-, bzw. untereinander. Was man dann an "Ausrichtungsspielraum" benötigt, muss man mit den Bohrlöchern machen. Z.B diese leicht vergrößern...
29.01.06 Nachdem der Kleber ausgehärtet war und ich die Beinchen der LEDs zugegebenermaßen etwas arg kurz gehalten habe, habe ich diese per Blankdraht miteinander verbunden. Aufgrund zu kurzer Beinchen nicht sonderlich schön, aber es passt :) 29.01.06 Und weiter geht's mit den Microtastern
28.01.06 Die Lochrasterplatinen sind mittlerweile zu den passenden Teilstücken zersägt... ...und die LED-Matrix ist auch bereits eingeklebt Jetzt heißt es "abwarten bis der Kleber komplett ausgehärtet ist".
25.01.06 Nach einer etwas längeren Pause, in welcher ich meine 9090 fertig gebaut habe, gibt es heute mal wieder einen kleinen "Schnipsel" Neuigkeiten... Das Panel von Schaeffer ist angekommen :) Die ersten notwendigen Teilstücke auf der Lochrasterplatine sind bereits angezeichnet und warten auf ihre Bearbeitung/Teilung durch meinen geliebten Proxxon. Nächste Woche habe ich Urlaub...habe da zwar auch noch viel anderes zu tun, aber ich bin guter Dinge in diesen Tagen auch "hier" ein gutes Stückchen weiterzukommen.
Danke für die Blumen :) Ich hoffe meine Bilder helfen dem einen oder anderen...werde das hier konsequent bis zum Ende führen...jetzt ist aber vorerst Pause. Ich mache erst weiter, wenn mein Frontpanel von Schaeffer da ist und das ist noch nicht mal bestellt :'( Ich arbeite momentan noch parallel an Trevor´s 9090, die ist auch schon soweit fertig, nur das Frontpanel samt Potihalterung fehlt noch und ich habe gerade eben erst einige Eurolos dafür bei Schaeffer gelassen, daher muss mein SID noch 2-3 Wochen warten. Ich möchte halt mit den LEDs, Tastern und Encodern warten bis das Frontpanel da ist, damit ich Abstände auch alle richtig einschätzen kann. Es gibt wenig Schlimmeres als alles wieder wegen Ungenauigkeiten auseinandernehmen zu müssen *g*
Achso *lol* jetzt habe ich das verstanden ;D Egal, ich denke auf meine etwas umständlichere Weise ging das auch. Hauptsache es funzt :) Gruß Dimi
Nö, ich meine schon die .syx Nachdem ich mit MIÓS-Studio die jeweilige .hex der "change_id application" geflasht habe, habe ich danach MidiOX geöffnet und die jeweilige setup_8580_slaveX.syx dann damit geflasht. Sollte doch eigentlich geklappt haben, zumindest gehe ich davon aus.... ich muss wirklich dringend mal, wie von dir vorgeschlagen die paar Taster und LEDs (Link, SID) einbauen um das zu überprüfen. Mach ich bald :) Gruß Dimi
Hallo Da ich mir ja gerade einen MidiBOX-SID baue, dachte ich es wäre vielleicht ganz interessant hier mal einen kleinen Blog zu posten. Im englisch-sprachigen Bereich gab es das ja schon ein paar mal :) 21.12.05 Hier geht die Geschichte los, mal wieder mitten im Lötstellen-Wohnzimmer, vorerst wurde Ebay leer gekauft *g* Guest-Star: Commodore C64 featuring MOS8580 Hier die Hauptdarsteller MOS8580…noch vor der Maske, daher etwas unscharf ;) Und in einer der wichtigsten Nebenrollen, hier ebenfalls noch ungeschminkt und überarbeitungswürdig: Der Brotkasten in der Rolle „des Gehäuses“ Die „Optimized PSU“ sieht auf Lochraster aufgebaut bei mir dann so aus. Klar, man hätte es auch etwas kleiner hinkriegen können... ...ganz ohne Kabel und Brücken ging es ohne vorherige Plan-Zeichnung dann doch nicht ;)  Das Hz-Stück: SID-Modul #1 ist fertig... 3 weitere Slave-Module werden folgen ...das SID-Modul von unten und wieder von unten... (die Beinchen des 100nF werden noch gekürzt, sind noch ein wenig lang) Tiefe Einblicke in das Core-Modul #1 ...auch hier folgen noch 3 weitere Slave-Module... Unterseite des Core-Modules „Gemeinsam sind wir stark“ - links das erste SID-Module und rechts daneben noch einmal das Core-Modul… Dies ist das erste von 3 DIN-Modulen ...auch das DIN-Module hat eine Rückseite ;) Zoom Zoom Mal "auf die Schnelle" das Step A Control-Surface gedengelt, damit man wenigstens ein wenig an der Klangerzeugung schrauben kann... Die Rückseite des selbigen... 5 Microtaster für die jeweiligen Parameter, 1 Microtaster fürs Menue und... ...1 Encoder zum ändern der Werte... ES LEBT – ES LEBT! Erste Tests mit „MIOS-Studio“ Hier noch ohne DIN-Modul und Taster... reiner Funktionstest... flashen der Software, Midi-Tests, etc. Mittlerweile sind auch die restlichen Module angekommen (3X SID, 3X Core, 1X DOUT für die LED- Ansteuerung, sowie 4X 24LC256 zum speichern der Sounds) Hier noch die neuen Module völlig unbestückt... 24.12.05 Habe heute mal ein wenig weiter gemacht und mit den 3 Slave-Core Modulen begonnen Kartenhaus mal anders *g* Eigentlich wollte ich erst morgen/übermorgen weiter bauen, aber ich kanns nicht lassen... wenigstens schon mal die Bauteile für die 3 Slave-SID Module sortieren :) ...aber auch dabei blieb es nicht. 25.12.05 Und weiter gehts...die Gehäusearbeiten fangen an *graus* Und weiter gehts mit der Verkabelung der Module... Im unteren Gehäuseteil fehlt jetzt nicht mehr ganz so viel...MIDI, Audio-OUT, Bank-Sticks 07.01.06 Nach ein paar Tagen Pause habe ich mich daran gemacht, die Bank-Stick-Platine einzubauen 4 Bänke mit je 128 Patches... Ein wenig wirr, aber erfüllt definitiv seinen Zweck ;) ...und ab ins Gehäuse und an das CORE-Modul angeschlossen. Dieses formatierte auch schön brav nach dem ersten Einschalten die Bänke A-D durch (leider ohne Bild) So, nun habe ich den verschiedenen CORE-Modulen auch jeweils einge eigene ID gegeben. Nach kleinen Startschwierigkeiten und der durchaus netten Hilfe hier im Forum ging es dann aber recht zügig ohne weitere Probleme. Über die Problematik kann bei Interesse hier nachgelesen werden: http://www.midibox.org/forum/index.php?topic=5947.msg36595#msg36595 Meanwhile.... tbc...
So, mit MIOS-Studio hat alles wunderbar geklappt :) Einfach die jeweiliegen PICs ins Mastermodul gesteckt, jeweils die ID geändert und danach mit MidiOX das jeweilige setup_8580_slave.syx geflasht. Ich freu mich ;D In den nächsten Tagen werde ich dann mit dem CS anfangen und einen kleinen Blog habe ich auch in Vorbereitung. cheers Dimi
Hallo Thorsten, vielen Dank für die ausführliche und zügige Antwort. Daran, die PICs im Master-Core-Modul zu flashen habe ich auch schon gedacht. Allerdings war ich mir nicht sicher ob dies so ohne weiteres möglich ist. Die Antwort habe ich ja nun bekommen :) Dann werde ich das mal ausprobieren. Thx! Dimi
Hallo zusammen, ich bin nun soweit das ich 4 Core- und 4 SID-Module fertig habe. Die Module sind bereits fertig miteinander verkabelt. Auch ich stolpere ein wenig über diese change_id - Geschichte, obwohl alles bereits mehrfach in deutsch und englisch hier dokumentiert und erklärt wurde. Verstanden worum es geht habe ich (so halbwegs)  ;D Die Situation: 4 X SID 8580 4X Core PIC18f...Mios 1.8 ist bereits auf jedem PIC drauf, sonst nix weiteres an Software. Nun habe ich lediglich das Master Core Modul und das erste Slave Core Modul mit einem PIC bestückt. Die anderen PICs müssen ja vorerst draussen bleiben, da sonst alle die selbe ID bekommen würden...soll ja nicht ;) Da ich (noch) keinen LINK.Butten habe, schicke ich also per MidiOX den dementsprechenden Sysex-String vorab für den MidiMerger. Sieht von der Bestückung her momentan also so aus: Soweit - so gut... Nun brauche ich die passenden 3 .syx Files mit den dementsprechenden ID-Änderungen für die jeweiligen Slave-IDs. Leider stoße ich hier auf ein paar Probleme. Perl ist installiert, allerdings, wenn ich die Main.asm aus der change_id Application öffne, um die ID auf 01 zu ändern, weiss ich nicht genau was weiter zu tun ist. Ich habe einfach versucht die Datei dann per "export" als .hex zu speichern. Allerdings resultiert daraus eine über 90kB große .hex-Datei. Viel zu groß also. Wenn ich diese Datei per Perl konvertiere, resultiert daraus eine .syx-Datei mit 0 Byte ??? Dann habe ich in der Main.asm etwas weiter unten gelesen, daß mit MPLAB zuerst die Project-Datei (Change ID.mcp) geöffnet werden muss. Dies habe ich getan und im Anschluss wie angegeben die Main.asm geöffnet und die ID geändert. Dann soll man F10 drücken um eine neue Main.hex zu bekommen. Bei mir passiert da allerdings leider überhaupt nichts. Agenommen das Problem ist gelöst und ich habe die geänderten hex-Files mit den jeweiligen IDs fertig, stelle ich mir die weitere Vorgehensweise wie folgt vor: 1.) Die jeweiligen .hex-Files müssen mittels perl in .syx convertiert werden. 2.) Dann schicke ich mittels MidiOX das erste syx-File mit ID1 rüber und der erste Slave-Core sollte dann die ID1 haben (richtig/falsch?) 3.) Danach schicke ich über MidiOX das aus dem SID-Package fertige "setup_8580_slave1.syx" rüber (richtig/falsch?) 4.) Dann schalte ich die Kiste aus, nehme den PIC des ersten Slave Core-Modul aus dem Sockel und stecke den nächste PIC dort rein. 5.) Wieder einschalten und den Sysex-String für den MidiMerger senden 6.) Dann wiederhole ich die Schritte 2-5 für den Slave2 und Slave3 PIC mit den dementsprechenden Files. Sollte in diesem Ablauf ein Fehler sein, so bitte ich um Korrektur ;) Hat wer eine Idee woran das Problem mit MPLAB liegen könnte, bzw. was ich falsch mache? Für Anregungen / Ideen / Vorschläge bin ich dankbar :) Gruß Dimi
Hast Recht, blöder Fehler...waren vertausch...man sollte zwischendurch mal ein paar kurze Pausen einlegen, soll ungemein helfen ;D Vielen Dank! Dimi
lol - ich meine natürlich war nicht RICHTIG herum drin...herrje :)
Sooo, erster Fehler (kein Sound) fixed! Betriebsblindheit - Q01 war nicht falsch herum drin ::) Backlight nachwievor dunkel, mal schauen ob ich noch einen BC337 finde...
Hallo zusammen, ich habe gerade mein erstes SID- und Core-Modul zusammengebaut. Leider haben sich 2 Fehler eingeschlichen 1) kein Backlight am LCD, Darstellung sonst in Ordnung, Contrast lässt sich regeln, Luminanz ohne Änderung 2) kein Sound am Ausgang des SID-Modules LCD (20X2 Backlight) und Bausätze sind aus Mikes Midishop Ich fange mal bezügl. des Displays an Was ich bereits getestet habe: Lötstellen sollten soweit in Ordnung sein, habe bereits sicherheitshalber nachgelötet, leider ohne Ergebnis. Kurzschlüsse habe ich keine Entdeckt (optische Kontrolle mit nem Uhrmacherglass und durch Messungen mit dem Multimeter) Verbindung vom Core zum Display doppelt geprüft, sind OK. Es wird auf dem Display alles korrekt angezeigt, nur die Hintergrundbeleuchtung fehlt. Was mich etwas stutzig macht: Die Spannung Pin15 - Pin16 am Display ist immer 5.205V - Drehen am Luminanz-Poti bewirken keine Änderungen. Die Spannungen am BC337 sind: UBE =0,758 UCE =0,00 UBC =0,755 Wenn ich am Luminanzpoti einmal komplett drehen, ändern sich die Spannungen folgendermassen: UBE =0,665 UCE =0,00 UBC =0,660 Dies soweit zum Display...ob da der BC337 defekt ist? Problem 2 (kein Sound am Ausgang des SID-Moduls) Kondensatoren, Widerstände und Bestückung allgemein ist ok - doppelt und dreifach überprüft (auch die Brücken ;)) Wenn man den SID einschaltet (btw: PSU optimized auf Lochraster mit C64 Netztrafo, alle Spannungen OK), hört man ein Knacken...was mir normal scheint. Interconnection Test funktioniert soweit auch. Allerdins bin ich mir nicht ganz sicher, ob das so in Ordnung ist. Folgendes habe ich festgestellt: Sobald man den SID einschaltet, sind alle Spannungen an den für diesen Test relevanten PINs des 8085 auf 5V. Erst wenn der Chip einmal den MWheel - Controller bekommen hat, sind alle auf 0V, bis auf der PIN, dessen Controller momentan aktuell gesendet worden ist. Soweil ich in der Main.asm gelesen habe, sollten die Spannungen ja alle bis auf ein PIN#14 (CS#) = 0V sein. Das sind sie bei mir aber erst, wenn ich einmal das MWheel "durchfahren" bin. Ist das so richtig? Achso, die Applilation "SID-Testtone" habe ich auch bereits probiert...kein Signal am Ausgang. Vielleicht hat ja jemand von euch noch eine Idee woran meine Problemchen liegen können, würde mich über Vorschläge/Ideen und eure Erfahrungswerte sehr freuen. In ähnlichen Topics bezügl. solcher Probleme habe ich leider keine für mich zutreffenden Hinweise finden können, bzw. habe diese schon ausprobiert (Interconnection, Testtone, Nachlöten, Bauteilprüfung, etc.) Gruß Dimi
