.terrorizt
    6
Everything posted by .terrorizt
  1. I think you'e got me wrong, I want to hardwire the Midiout of the Sequencer to the Midi In of MBSID and MBFM, but also use the MidiOut for external gear. Is it possible to use the MidiOuts of the MBSID and MBFM for this? .t
  2. Okay, then I'll use the 2x16. Thanks
  3. Hi, another question from me. I want to know if it is possible to connect a MBSID or a MBFM internaly to the sequencer, without the midi out used. I thought to build the MB SID and later the MB FM directly into the same case, an then the internal connection would be great. But, I still want to use the Midi out, for instance to use my waldorf microQ again. Thanks in advance .t
  4. I've just taken a look to the MBSEQ Manual, and I'm wondering if 2 2x40 Displays are needed to use the MB SEQ full featured. I have to add that, due to the choosen layout the encoders are not under the display anyway. I have an 2x16 Display here, does this work? Thanks in advance .t
  5. Thanks for your answer. If they are only 20€ in germany, I'll rethink the Encoder/Pot thing. I Thought the would be more expensive. But my question i meant an other thing. Does it work if I exchange them all, or do I need some buttons or Pots adittionaly. The space should be not the problem, I'm just asking for the numbers of buttons, pots/encoders and led. The layout will be an completely different, and that's why I'm asking, I'm drilling it right now, so i need to know the number of parts ;-) .terrorizt
  6. Hi, I want to start building a MidiboxSeq, and I almost have anything i need. But naturaly there are some Questions first. I want to build The MBSeq like on the following Layout http://www.ucapps.de/midibox_seq/mbseq_panel_proto_final.gif but with Pots instead of Rotary Encoders. Is there Anything i have tho know, or are there no Problems at all? If you want to tell me that rotary encoders whould be the better way, i know. But i have a lot of Pots here, and I don't want to buy a lot of Encoders just for this. Hope you can help me, so i can start burning this thing together :-) Thanks in advance .terrorizt
