fabricio
22 -
Everything posted by fabricio
ok do you think it's possible to programm that
hello, i want to know if it is possible to record sysex from an external advice on mb i know i have to use the bankstick. is there any exemple (sorry i have search but i don't find) thanks a lot fab
this is a special message foe audiocommander but the topic can interessed other people. Audiocommander have you tested the qt301 with the sensorizer cause i have some problem with the stabilisation of the signal. thanks fab
midibox programmation through the midi_router ?
fabricio replied to fabricio's topic in MIOS programming (Assembler)
thank you tk. No problem. MIOS Studio is ok through the router. I want to thankyou for all your work for midibox. i have make : a midi bass pedal a floorboard for guitar(looper) a midi clock and finally the router with this system. all this midibox have unique function(programmation in c) i thank you very much !! -
ok i answer to me. IT's possible with sysexbox but not with mios studio thank you to all the people ( serge tk etc ...) fab -
thank you for your answer.(waou tk himself). after a lot of try i have succeed. i show you the code in router.c : and i have to modify midi_rxtx.asm : i don't know if it's elegant but the led (green and red)flash with the tempo and i'm happy fab
hello i'm trying to add beat indicator led (like for the seq) but i don't know how make it. thank you
my friend say me he has received the chips. i have looked to saelig store and surprise !!! : no more qt301 who have take all qt301 ?
i will command it by a friend who is living in brooklin. I think i will take 10 ics cause they are many use for that ( like fx pedal with optocoupler or with the midi box). So i will come back.
hello i'm looking for the qt301 by quantum cause it's seem too be easy to use with midibox. look at that : www.youtube.com/watch?v=GLXIEXfpUjM (thanks to audiocommander) unfortunately there is just one store who have this one but the shipping cost is expensive to france. Is there an american midiboxer who can buy it for me ? the link for qt301 : http://www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=IC3032&Category_Code= thank you fab
moi donc je suis parti et arrivé du coup à faire un looper switcher étant guitariste ca me permet de router mon son vers des pédales. Quelques images : pour quelques détails, le programmes etc hésitez pas
I don't understand how too utilise this functions for receive midiclock and convert in into BPM. Can i have a short example. thank you FAB
Ok, i try that thanks FAB
I don't want all the monitor application. I just want the code who convert received midi clock(0xF8) into BPM. For include in application who i'm writing. After converting midi clock into bpm, i want to display the BPM on LCD screen. excuse me for my english(cause i'm french). Thanks a lot. FAB
OK, Ok sorry for the double post sorry for the smiley (i never utilise it) thank you for your answer The problem with clockbox : it donesn't receive midi clock just Send Monitor is good but in assembler. So i'm swimming a little thanks FAB
from midi in (midi clock (adrenalinn2))
I'd like to received BPM and display it on LCD. How can i programm it Thanks FAB
bon, je vais étudier tout ca, par contre le prix de ces petites bestioles, sachant qu'il m'en faudrait quatre. Merci en tout cas, de toute façon, je vous tiens au courant vu qu'il va quand même falloir que je fasse un peu de programmation et que là , ca va être chaud, chaud !!
Ceci étant dit et pour ceux que ca intéresse j'ai trouvé des switchs qui correspondraient à ce que je recherche (donc spdt pour avoir un true bypass). c'est un composant qui vient de chez maxim (n'est ce pas) et c'est le max333. Bien sur il existe en package dil (cool !!)
En fait dans mon cas il faudrait un switch spdt et pas spst. Bon mais sinon ca répond pas à ma question, quelle est l'appli la plus proche de ce que je veux faire ? Une petite idée
je vais router le signal en commandant des relais 2rt ( ca ce dit bien comme ça ?) et laisser les pédales d'effet sur on. Pour ce qui est des switchs la référence est fausse. Analogue device fait bien des switchs mais c'est que du montage en surface
L'idée serait d'utiliser les relais ou bien des switch comme il m'a été suggéré justement pour bypasser. Ainsi, en appuyant sur un seul footswitch momentané (que l'on trouve chez banzai effect) je pourrais mettre en action un ou deux ... jusqu'a huit effets en même temps suivant ce qui a été programmé pour chaque footswitch. Voila c'est un looper commandé au pied. Pour ce qui est du C, je profite de cette occasion pour m'y mettre. Du coup, je suis pas près de quitter ce forum.
Bonjour, Je vais essayer d'être clair : Je voudrais faire un pédalier qui commande des relais pour ainsi bypasser ou non des effets. Il y aurait 2 modes : un en programmation et un en utilisation Il me faudrait plusieurs bank, un peu comme le floorboard classique Je voudrais savoir quelle est l'application qui se rapproche le plus de ça dans un premier temps.
