Wise,  I am pleased to see a possibility. 100 meg ethernet works without issue for 300 ft. I am sure there is a way to have 2 meg 100% perfect over 100 ft. Looking at the DOUT data lines with a scope, it doesn't appear to be a whole lot different than RS232, just faster and using less robust master hardware (the 452). My DOUT module failures on long runs are most related to the 5+ volt line and voltage drop on long runs due to the current draw required by powering 32 opto-isolators for the triac boards, so I have changed to a ditributed power arrangment placing a7805 and filter caps on each DOUT card and running +12 on the power line, this has improved stabilityt. I will look into the line drivers, probably buy a few and build to see what it ends up running like.  Thanks again!  Jerry
