pek
    6
Everything posted by pek
  1. Ok thanks! :)
  2. Great! Thanks a lot clmo :) Regards :)
  3. Hi all, I just found back my two sids chips (6581) while moving out, and decided to start a stereo project from scratch, since stuff have upgraded to Sid v2! So, I'm considering buying all parts (except for LCD and future control surface) from SmashTV, but a small question came into my mind: In the walktrough, the board needs to be bridged at the very beginning, but I can't see any of these bridges on SmashTV's live board map! So my guess is, no need for bridging, but I may be wrong? Also, are the MIDI sockets included in the Core Kit? Thank a lot for your answers, I hopefully become one of yours soon!
  4. Hi guys, I'm kinda new over here, although registred for a couple of years now! I had to drop my midibox sid project, because of loads of work... But back in the game now! Wilba I loved you work with your midibox sid, and decided to do the same (or almost, at least 8 SIDs running!) So I'm interested with your megasell, but was wondering if I did something wrong: I just edited the wiki page, to add my name and numbers of required chips. And then changed the total so that count my order in. Was it the way it was supposed to work? Just to make sure really....
  5. pek
    Petit nouveau ici :)
    Merci! Je vais zieuter ca avec grand interet. J'ai recuperer un SID ce matin meme, j'attends les composants de chez Mike et c'est parti!
  6. Salut a tous les midiboxeurs francais... Bon, apres avoir passe quelques mois a zieuter ce forum et ce fantastique site, je me jette dans le bain. j'ai commande toutes les pieces pour faire une midibox SID et en attendant qu'elles arrivent, j'aurais 2 ou 3 questions: j'ai commande les kits sur le site de mike: dans chaque kit il fournit une alim. Le createur de ce projet recommande d'utiliser l'alim du commodore, mais en options il preconise une alim de meilleur qualite (500 mA si je me souviens bien...). Donc, est-il preferable d'utiliser les alims fournies dans les kits? Et genre imaginer un petit boitier regroupant les 2, comme ca une prise de courant et zou plus a s'embeter a brancher 120000 trucs? Sinon, a propos de l'isolation du cristal sur le module Core: que pourrais-je utiliser comme adhesif isolant? J'ai rien de tout ca chez moi, donc avant de faire une betise je prefere demander ;) Sinon, a ce qu'il parait un cristal ne rayonne pas, donc est-ce vraiment necessaire tant que le boitier en metal ne touche pas les pistes? Enfin, je voudrais faire une fois que mon compte sera remis de ces achats une surface de controle de type A (6 boutons, un LCD et une roue codeuse). MAis quel type de roue codeuse faut-il? J'oserais suggérer un encodeur qui incremente, mais encore une fois je prefere avoir confirmation ;) Merci d'avance et promis je metterai des photos des que j'ai fini :)
