toxictv101
    68
About toxictv101
  • Birthday 01/01/1
  • Gender
    Male
  • Location
    BELGIUM
toxictv101's Achievements
MIDIbox Newbie
  1. i would like (if it's possible) to use some dout doing Pwm and some filter and so use this as Analog output for velocity control. any one have some sugestion for handle this in the C skelton ? :P
  2. i m realy sorry i realy dont know what did appen to my circuits. i added a led function that was a bit to long maby in the init it was like a 2 For loops that flashed led in a fashion way like 100 time when mios started i simply removed all these unusual thing and everything work well now
  3. instead it would be realy cool. if i can use the j5 as Analog output ???? anyone got experience with it ?
  4. i notify that when i use Global variable the core reboot all the time. maby there is an overflow somwhere or something ?
  5. but is there a initialisation port procedure ? and what is the name of the variable that get the value in ?
  6. hi, is it possible to use the j5 pin as Analog to Digital converter for my custom C apps. tks.
  7. i ve made a litle led sequence in the init fonction , so that i know when it boot. and it call this fonction every 3 secondes ... ???
  8. hi all, i ve got 2 pic here, and they boot reboot every 2 or 3 seconds whatever i write in the code. anybody know what is it? maby i forgot to configure something.
  9. is everything else work ? is the sid work ? is the core send data by midi when powering on ?
  10. OP
  11. terrible la dernier exemple !!! ca me donne envie de jeter l'insoleuse que j avais fabriqué avc un vieux Scanneur et des mini tube pour bronzer (tube u.v)
  12. hi all, is it possible to add velocity suport in the midio128 i would like for exemple that on "dout" pin1 is for c1 vel-from 0 to 40 pin2 for c#1 from 40 to 80 and 3 for D1 from 80 to 127 ???? any help would be great tks
  13. hi all i need some help to finish my box it's a midio128 with 8 dout output pin that are play by midi i would like to get 2x 1ms pulse on pin1 & 2 and keep gate on others i ve a idea of where i could put some code but dont know exactly what to call and i know that the folowin function is call 1ms after some output have change can i put something there that can reset a given pin so 1ms after that it have move. -------------------------------------------------------------------------- ;; This function is called by MIOS after the shift register have been loaded ;; Note that this is an interrupt service routine! Use FSR2 instead of FSR0 ;; and IRQ_TMPx instead of TMPx -- and make the routine as fast as possible ;; -------------------------------------------------------------------------- USER_SR_Service_Finish ;; fetch DIN registers if requested IFCLR MB_STAT, MB_STAT_FETCH_DIN_REQ, rgoto USER_SR_Service_Finish_End bcf MB_STAT, MB_STAT_FETCH_DIN_REQ call MIDIO_DOUT_FetchDIN USER_SR_Service_Finish_End return --------------------------------------------------------------------------------------------- tks !
  14. what is the soft that create such great Panel ???
  15. very nice!!!! but what software did u use to create this picture ???
