massiveheadpain
    3
Everything posted by massiveheadpain
  1. i appreciate the help. I've spent the majority of the day looking for parts. Anybody know where I could get some REAN knobs in the US? The ones I wanted at mouser were non stock with a 50 minimum order :(
  2. hi i've spent hours and hours reading a learning how to make a midibox - and so far has come to grasp everything pretty well. I'm designing a DJ style Ableton controller that consists of: 50 potentiometers -4 pots for 4 channel volumes (rotary mixer style) -44 regular pots for aux, fx, eq, tempo,.... 30 push button leds (switches from mec.dk) -28 of these will be clip triggers -2 of these will be up and down scroll 3 faders -1 100mm panasonic xfader -2 60mm cue and master volume faders If im correct this would require: 2 AIN modules 1 DIN module 1 Core module 1 Dout module The dimensions of the controller will be the same as the Allen and Heath Xone 92 mixer - 12.6" width x 14" length x 3.5" depth. The design and layout of the controller will also be similar to that of a xone 92 mixer. Im currently drawing up my design in a cad program (which is new to me) and had some questions regarding the front panel. I have my layout how I want it but regarding the size of the holes im unsure. I was thinking of buying the pots from smashtv's site the 6mm by 15mm D shaft. Does that mean the hole on the panel should be 7mm if im panel mounting all the components? And regarding the faders, the panasonic faders have two screw holes on each end, i couldnt find anything in regards to the size of the holes for the screws. The 100mm fader tech sheet shows that the screw holes span 120mm, does that mean i put the screw hole 10mm from each end of the faders travel length? My last question concerns the mec led switches. The leds are built into the switch so will I still need a dout module? Thanks for the helps and hopefully within a few month Ill have a midibox to share with the community. TB
  3. hi, here is what i want to try to do: combine a bcr 2000 and a bcf 2000 into another case, re arrange the knobs and faders and buttons to my liking and throw in a 4ch audio/midi interface into the box. I was thinking to just daisy chain the behringer units, and send midi out from those into and audio midi interface, and then sending USB to the computer? I havent taken apart my behringer and i wanted to know if something like that would be possible? sorry for being a NEWBIE! ;D
