ALCOLOIC
    14
Everything posted by ALCOLOIC
  1. i tried but i can't make a decent picture with my crappy camera . i'll try to borrow one . i rechecked the module and resoldered everything on it but without succes
  2. thanks i think i understand better now i retried but the results seems weird with everything connected (4cores+lcd+complete control surface) i get 0,33 with everything connected except the dout modules i get 0,07 with everything connected except the dinmodules i get 0,07 with everything connected except the LCD i get 0,14 the j1 connector on the first dout module
  3. it's fully working when i disconect/reconect the dins or dout . sometime it boot normally after i made a "shortcut" with my finger . if i don't solve the problem i'm gonna add a switch but i hate to solve a prblem this way
  4. i tried to do what you said but i get a static 21 ma wich make me think i'm doin it wrong . what do you mean by "bridge" ? this is very frustrating i have a fully working sidbox that crash on startup . thanks for helping
  5. nobody ever had the same problem ?
  6. hi i'm not sure i understand the question . i allready mesured the current on the core ic1 like you told me and i had C1:MCLR(1) - IC1:Vss(12) = 4,6v IC1:Vdd(11) - IC1:Vss(12) = 4,6v IC1:Vdd(32) - IC1:Vss(31) = 4,6v where am i suppose to mesure the current now ?
  7. i tried without backlight and without the slave core modules but i had the same result. i'm using the c64 psu with http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf i checked all the soldering and it looks clean thanks for helping
  8. that sucks i have that problem again ! everytime i power the unit up the lcd show a blackrow . but if i disconnect/reconnect the din or dout my midibox boot normally C1:MCLR(1) - IC1:Vss(12) = 4,6v IC1:Vdd(11) - IC1:Vss(12) = 4,6v IC1:Vdd(32) - IC1:Vss(31) = 4,6v
  9. hi my midibox is nearly finished (but it's already working fine) i started a popcorn remix to try that beast and it's a lot of fun ! i tought i'd share my joy with you all cause those kind of topic helped me a lot when i started this project . i know the design is far from original but here's a few pictures http://www.slide.com/r/xla54bzv7j8c1D1wpo3n5WRoPixrDmDE?previous_view=mscd_embedded_url&view=original i'd like to thanks Mr Thorsten Klose for this fantastic and really well documented project and everybody on this forum (nearly all the questions i had were already answered) edit: it's a 4x6581 midibox sid with complete control surface with 8 banksticks
  10. thanks for helping midiboxxer ! i resoldered a few cables on the power supply i made months ago and it worked perfectly . now i only have to make holes in the enclosure ( a c64 box ) for the plugs and my sidbox is finished . but it's alive already !
  11. i have no idea why but it's working normally now !!!
  12. C1:MCLR(1) - IC1:Vss(12) = 0,9v ??? c1 is the capacitor right ? what is MCLR ? IC1:Vdd(11) - IC1:Vss(12) = 4,6v IC1:Vdd(32) - IC1:Vss(31) = 4,6v sc-j10 is not connected r1 is 100 ohm thanks a lot for helping
  13. hi thanks for the quick answer i use the c64 optimized psu http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf
  14. hi everybody i just finished my midibox sid (4sid) with complete control surface and everything is working normally . the only problem i have is that it freeze on startup when the din modules are connected ( the lcd show a black row on the upper part ) if i disconnect/reconnect the din modules everythying work normally . i soldered all the resistor and the unused chips are not stuffed on the last din . if someone has an idea of what's wrong that would make my day thanks in advance ps: it's a v1 midibox sid
