t_xen
    148
About t_xen
  • Birthday 01/28/1975
Contact Methods
  • Website URL
    http://t-xen.livejournal.com/
  • Gender
    Male
  • Location
    Seattle, Washington
t_xen's Achievements
MIDIbox Addict
MIDIbox Addict (2/4)
  1. yup. I moved 1 wire over on the IDX and now it's in stereo. (core to sid) that's what I get for looking into the details. ;D
  2. ok, I did a double check on the audio wiring. I have the "Tip" (left output = bottom sid) and the "Ring" (right output = top sid) connected to the appr. pins of the stereo jack. The Top Sid Board (J2) is 1 to 1 on the Core (J10) except on the Top Sid board (j2-pin9) connected to (j14)........ Oh, crap. I just saw the prob. blank pin conected to nothing. let me adjust the wiring on my 10 pin IDX connector. ::) moving a wire over... My cabeling on the sid has 3 connectors on it like a montherboard to a slave HD an master HD, But rather than that, it's a left and right channel.
  3. ok. I figured I have the Left and Right SID modules wired up to the core correctly, because I am getting audio from both left and right channels. but the audio produced (no matter how much tweaking I do through the menu interface) it still comes out as mono. My mixer has a left and right audio level readout and I am getting audio from both channels, however there is no noticeable difference between the channels. I use a stereo cable that splits to left and right channels that plugs into my mixer. On the output, continuity checks out by testing the Tip to the right module and the Ring to the left module. Not sure what to do at this point. any insight? Thanx
  4. There could be a problem with the PSU being flakey cuz I tried puting a load on it from another project that works and it doesn't work on that. So.... I got another design for a Bipolar PSU. Is this adequate? So for the caps after the regulators, I have some tantalum caps, but no electrolytic. Should those be fine?
  5. Happy Pyro Day! :P
  6. that's what I figured was happening. My walwart seems to be delivering just enough amps though. What I'm going to try is putting in another 5v regulator, move all the shift registers for the SID Modules off the current regulator and link them to the added regulator. Should pull some heat off the current 5v regulator that's in it by reducing the load off that part. I'll update when I get around to doing this.
  7. I think there is a possibility you might be right. It reads fine but the second I put a load on it, I get weird voltage readings from the module I connect to it. Pics and schematic will be posted in a bit. I need to take a break from it for a bit. :P
  8. oh yes. I did. After setting the project aside for a bit (sometimes it's good to step away) so I don't get too frustrated, I think the majority of the issues I'm having is a less than adequate PSU that I'm currently using.
  9. I built an analog synth (Soundlab from MFOS) and wanted to build the midibox CV to control it. I built an AOUT_LC etched myself and populated. it worked fine for the external filter I have for the SID but not good enough for controlling VCOs. so I decided to etch an AOUT. The etch turned out fine and populated all the parts. I ended up with faulty readings on the pins that I tested for the OPAMP ICs. and I could not trigger the DACs that I had gotten as samples from the core module. I ended up putting the board to bed. The Aout_NG came along. I put it together triplechecking to make sure I had the proper parts in the proper places and oriented properly. alas, I get faulty readings when testing the voltage. there is a bridge somewhere on the board that's not being created by solder or lead clipping sitting across some pins. After a week of working on the aout_ng and testing. I have given up since I have not been able to get a solution in sight. I'm baffled over this because I have built an 8xSID v2 from individual modules and did not have any weird voltage issues, or strange, anomalous problems. the only problem I have with the 8xSID is that I'm not supplying enough current to it. that's an easy fix. I almost wonder if I failed to build a proper bipolar PSU even though I get proper readings off it from the + and - rails. Only when I connect it to the aout_NG, do the readings off the negative rail get flipped around. positive rail comes out fine. I got troubleshooting tips from various users, even seppoman, the creator of the board, but still have yet to determine what went wrong in populating the board. alas, like the others I've put this one to bed. :'(
  10. I put a probe on the jumper that runs from P12 after passing through the resistors, and the other on - rail. I can get a reading and adjust the resistance, but when I place the probe on the + rail, I get a reading, and cannot adjust it. At this point, I'm giving up on this. into th estatic bag it goes and into a box in the closet. :'( :'( :'( :'( :'(
  11. ok. no continuity when checking the pins on the board for P12. when checking the trimmer by itself, no continuity. but when I put the trimmer back into the board, I get continuity off 2 pins.
  12. I removed the trimmer and now the positive and negative rails aren't bleeding together, but unfortunately I'm still getting a + reading off the negative rail.
  13. I was testing for continuity and started checking the pins under the trimmers. I found a bridge underneath p12. time to desolder the part and check.
  14. off a whim, I did a continuity check. pin4 has continuity to the positive rail. when I checked pin 11, I get continuity to both positive and negative rails. now I have to figure out where it's happening.
