225 -
jrp last won the day on April 26 2025
jrp had the most liked content!
About jrp
- Birthday January 1
Gender
Not Telling
Recent Profile Visitors
jrp's Achievements
MIDIbox Addict (2/4)
-- Display MIOS32_MIDI_SendDebugMessage() messages and transmit data/trigger functions -- this prints to the Touchosc Log window, as well as to a text element called "text" local MIOS_MSG = root.children.text -- <- this text element must be in root, or simply change this adress function log(msg) print(msg) text = msg.. "\n" .. text --text = text .. "\n" .. msg local count = 0 MIOS_msg_lines = {} for line in text:gmatch("([^\n]*)\n?") do if line == "" then break end table.insert(MIOS_msg_lines, line) count = count + 1 if count >= maxLines then break end end text = table.concat(MIOS_msg_lines, "\n") MIOS_MSG.values.text = text end -- messages in the form of "Start .. ID .. list of numbers seperated by spaces .. End" can be used to transmit data to TouchOSC and call functions local MIOS_SYSEX_COMMAND_FUNCTIONS = { -- numbers from mios are 0 based! MyFunction = function(numbers) print(#numbers) end } function Do_MIOS_Sysex_Command(ID, numbers) local fn = MIOS_SYSEX_COMMAND_FUNCTIONS[ID] if fn then fn(numbers) end end -- sysex message handling local sysex_buffer = {} local last_sysex_time = 0 local sysex_timeout = 200 -- ms (adjust if needed) function flush_sysex_buffer() if #sysex_buffer > 0 then local msg = table.concat(sysex_buffer) sysex_buffer = {} log("MIOS32 (timeout flush): " .. msg) Log("[TIMEOUT] " .. msg) end end function onReceiveMIDI(sysExMessage) local now = os.clock() * 1000 -- ms resolution -- if too much time passed since last byte -> flush old buffer if now - last_sysex_time > sysex_timeout then flush_sysex_buffer() end last_sysex_time = now local headerLen = 8 for i = headerLen + 1, #sysExMessage do local b = sysExMessage[i] if b == 0xF7 then -- end of SysEx, flush buffer as a complete message local msg = table.concat(sysex_buffer) sysex_buffer = {} local ID = msg:match("^Start%s+(%a+).-%d+.-End$") if ID then local numbers = {} for num in msg:gmatch("(%d+)") do table.insert(numbers, tonumber(num)) end Do_MIOS_Sysex_Command(ID, numbers) else log("MIOS32: " .. msg) end else if b ~= 0 then table.insert(sysex_buffer, string.char(b)) end end end end
I have a function that does some heavy floating point math (calibrating solenoids to a nice midi velocity response). It works, but is slow. The STM32 does seem to have an FPU. Is it enabled in MIOS32? If not, how can i enable it in my application and make the compiler use it? Thanks!
scan all inputs once after start of mios 32, send out via midi
jrp replied to ranger930's topic in MIOS programming (C)
i jst saw that tk answered the same question regarding mios8. The same should apply here. It works alsmost like the code i suggested above, with one big difference: I was suggesting a global variable. That does work, but is usually a good idea to avoid. The neat thing i just learned, and since we are both learning i like to share this:: What is a static variable? It is a variable that will be created once and not change over function calls. So if the code below would read "unsigned char ain_sent = 0;" without the static keyword, the variable would be recreated every tick and midi would be sent every ms. With static, this variable will be created once inside the function block (so it is not polluting the global namespace). Next time it will be 1 and the condition in the if statement will fail. ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS in the mainloop when nothing else is to do ///////////////////////////////////////////////////////////////////////////// void Tick(void) __wparam { static unsigned char ain_sent = 0; if( ain_sent == 0 ) { unsigned char pin; unsigned char num_ain = MIOS_AIN_NumberGet(); ain_sent = 1; // only sent once after startup for(pin=0; pin < num_ain; ++pin) { MIOS_MIDI_TxBufferPut(0xb0); // CC at channel 1 MIOS_MIDI_TxBufferPut(pin); // pin number corresponds to CC number MIOS_MIDI_TxBufferPut(MIOS_AIN_Pin7bitGet(pin)); } } } -
it´s in the manual under din http://midibox.org/mios32/manual/ I cannot try this right now, but i would assume something like int my_button = MIOS32_DIN-PinGet(0); will save 1 or 0 to the variable my_button. But again, if you have a normal "digital" push button this will only work while the button is actually pressed. -
s32 MIOS32_DIN_PinGet (u32 pin) With this function you gen poll the state of a din pin, eg when using switches in your setup. -
The thing is: With all digital inputs you cannot get any state UNLESS a button is pressed. It would be different with actual switches that hold their state low or high. But a button or encoder has no permanent state. When you press or turn it you get a pulse that will trigger the mios callback routine. Thats it. So the direction you should be looking is to save the last state of all buttons and encoders in your code, and load it on startup. Unfortunately i am still a noob, so i cannot really tell you how to do that. But there is some example code for sd cards and bancsticks. -
i am also wondering about running a function once. I was under the impression that this could be done within the init function, but that does not seem to work. What does work (please tell us if this is not the way to do this) is defining a variable like: u8 has_run = 0; then in the background task you can check for has run == 0, do your stuff, set has_run to something different than 0. Your code inside the if statement will never run again... if (has_run==0){ do everything you want; has_run = 1; } -
Dear Forum, like the titel suggests. The TLC5947 can be bought in ready soldered modules and was suggested to me for dynamically driving solenoids, as an alternative to dac channels i proposed in my other thread. Reason is the parts count, so before i build 24 ladders with analog shaping and drivers i thought i should maybe look into pwm once more. So the question is if from within an mios32 application, i can use the SPI interface. If so i would try to code some form of "hello world" example with the pwm module first and then go from there. Also is it fast enough? I need a pulse of less than 5ms to minimize the on time of the solenoids and give good response with pecussive instruments. Has anyone done something similar? Thanks!
pyBLM - Headless Python-based Novation Launchpad BLM implementation [BETA]
jrp replied to borfo's topic in MIDIbox BLM
i think it´s super cool that you post this after three years - we all know how fast a project can be on halt and never be returned to... I woul love to try this! Go midibox 2025! -
If anyone is interested, this sort of works, turning off the pins/updating the lcd after a specified time. It works as in the J5 debounce tutorial 006_rtos_task. Thanks for all the great tutorials, they really provide a good starting point for people like me!
// $Id$ /* * MIOS32 Tutorial #020: LCD Output * see README.txt for details * * ========================================================================== * * Copyright (C) 2009 Thorsten Klose (tk@midibox.org) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "app.h" #include <stdbool.h> const char* bool_to_string(bool value) { return value ? "1" : "0"; //u8 velocity_dependent_timings[16]={20,18,17,16,14,13,10,10,10,10,10,10,10,10,10,10}; } u8 note_off_timers[24]; ///////////////////////////////////////////////////////////////////////////// // This hook is called after startup to initialize the application ///////////////////////////////////////////////////////////////////////////// void APP_Init(void) { // initialize all LEDs MIOS32_BOARD_LED_Init(0xffffffff); // initialize all pins of J5A, J5B and J5C as outputs in Push-Pull Mode int pin; for(pin=0; pin<12; ++pin) MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); int i; for(i=0; i<24; ++i) { note_off_timers[i]=0; } } ///////////////////////////////////////////////////////////////////////////// // This task is running endless in background ///////////////////////////////////////////////////////////////////////////// void APP_Background(void) { // clear LCD // MIOS32_LCD_Clear(); } ///////////////////////////////////////////////////////////////////////////// // This hook is called each mS from the main task which also handles DIN, ENC // and AIN events. You could add more jobs here, but they shouldn't consume // more than 300 uS to ensure the responsiveness of buttons, encoders, pots. // Alternatively you could create a dedicated task for application specific // jobs as explained in $MIOS32_PATH/apps/tutorials/006_rtos_tasks ///////////////////////////////////////////////////////////////////////////// void APP_Tick(void) { // PWM modulate the status LED (this is a sign of life) u32 timestamp = MIOS32_TIMESTAMP_Get(); MIOS32_BOARD_LED_Set(1, (timestamp % 20) <= ((timestamp / 100) % 10)); int i; for(i=0; i<24; ++i) { if( note_off_timers[i]>0) { --note_off_timers[i]; } else { int j = i*4; MIOS32_BOARD_J5_PinSet(j, 0); MIOS32_BOARD_J5_PinSet(j+1,0); MIOS32_BOARD_J5_PinSet(j+2,0); MIOS32_BOARD_J5_PinSet(j+3,0); MIOS32_LCD_CursorSet(j, 0); // X, Y MIOS32_LCD_PrintString(" "); } } } ///////////////////////////////////////////////////////////////////////////// // This hook is called each mS from the MIDI task which checks for incoming // MIDI events. You could add more MIDI related jobs here, but they shouldn't // consume more than 300 uS to ensure the responsiveness of incoming MIDI. ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_Tick(void) { } u8 start=0; // to clear the lcd... int velocity_4bit; ///////////////////////////////////////////////////////////////////////////// // This hook is called when a MIDI package has been received ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package) { // toggle Status LED on each incoming MIDI package MIOS32_BOARD_LED_Set(0x0001, ~MIOS32_BOARD_LED_Get()); // no idea how and where else i can clear the lcd if( start == 0 ) { MIOS32_LCD_Clear(); start=1; } if( midi_package.type == NoteOn && midi_package.velocity > 0 ) { u8 note_number = (midi_package.note % 12); u8 dout_pin = note_number * 4; velocity_4bit = midi_package.velocity >> 3; //note_off_timers[note_number] = velocity_dependant_timings[velocity_4bit]; MIOS32_BOARD_J5_PinSet(dout_pin, !((velocity_4bit >> 3)) & 1); MIOS32_BOARD_J5_PinSet(dout_pin+1, !((velocity_4bit >> 2)) & 1); MIOS32_BOARD_J5_PinSet(dout_pin+2, !((velocity_4bit >> 1)) & 1); MIOS32_BOARD_J5_PinSet(dout_pin+3, !((velocity_4bit >> 0)) & 1); // Just for testing: Print to lcd: MIOS32_LCD_CursorSet(dout_pin, 0); // X, Y MIOS32_LCD_PrintString(bool_to_string((velocity_4bit >> 3) & 1)); MIOS32_LCD_CursorSet(dout_pin+1, 0); // X, Y MIOS32_LCD_PrintString(bool_to_string((velocity_4bit >> 2) & 1)); MIOS32_LCD_CursorSet(dout_pin+2, 0); // X, Y MIOS32_LCD_PrintString(bool_to_string((velocity_4bit >> 1) & 1)); MIOS32_LCD_CursorSet(dout_pin+3, 0); // X, Y MIOS32_LCD_PrintString(bool_to_string((velocity_4bit >> 0) & 1)); note_off_timers[note_number] = 3000/(velocity_4bit*2); // just for testing, this has to be tested and maybe we want longer gate for low velocity MIOS32_LCD_CursorSet(0, 1); MIOS32_LCD_PrintFormattedString("%02d:%02d:%02d", midi_package.velocity,velocity_4bit,note_off_timers[note_number]); } else if( (midi_package.type == NoteOff) || (midi_package.type == NoteOn && midi_package.velocity == 0) ) { u8 dout_pin = (midi_package.note % 12)*4; MIOS32_BOARD_J5_PinSet(dout_pin, 0); MIOS32_BOARD_J5_PinSet(dout_pin+1,0); MIOS32_BOARD_J5_PinSet(dout_pin+2,0); MIOS32_BOARD_J5_PinSet(dout_pin+3,0); //MIOS32_LCD_CursorSet(dout_pin, 0); // X, Y //MIOS32_LCD_PrintString(" "); } } ///////////////////////////////////////////////////////////////////////////// // This hook is called before the shift register chain is scanned ///////////////////////////////////////////////////////////////////////////// void APP_SRIO_ServicePrepare(void) { } ///////////////////////////////////////////////////////////////////////////// // This hook is called after the shift register chain has been scanned ///////////////////////////////////////////////////////////////////////////// void APP_SRIO_ServiceFinish(void) { } ///////////////////////////////////////////////////////////////////////////// // This hook is called when a button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void APP_DIN_NotifyToggle(u32 pin, u32 pin_value) { } ///////////////////////////////////////////////////////////////////////////// // This hook is called when an encoder has been moved // incrementer is positive when encoder has been turned clockwise, else // it is negative ///////////////////////////////////////////////////////////////////////////// void APP_ENC_NotifyChange(u32 encoder, s32 incrementer) { } ///////////////////////////////////////////////////////////////////////////// // This hook is called when a pot has been moved ///////////////////////////////////////////////////////////////////////////// void APP_AIN_NotifyChange(u32 pin, u32 pin_value) { }
///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "app.h" #include <stdbool.h> const char* bool_to_string(bool value) { return value ? "1" : "0"; }
now i have to look into timers to get some way of resetting my pins after some ms. Solenoids don´t like to be "on" for long, and the glockenspiel needs only a short percussive hit.
