japanesepotato
17 -
Everything posted by japanesepotato
How to disable F1 - F4
japanesepotato replied to japanesepotato's topic in MIOS programming (Assembler)
Thank you very much moxi!! -
I guess this quetion have been asked over and over but I couldn't find topic so let me ask once again here. I built 64e and everything works fine, now I want to disable F1 - F4 and use like other buttons on Ableton live MIDI map. Could anybody let me know any idea which inc I should change or any page explain about it? Thank you
Problem with convert.bat
japanesepotato replied to japanesepotato's topic in MIDIbox Tools & MIOS Studio
I found them thank you very much! ;D -
Oh I didn't know that...I thought change the table and convert.bat and send by MIOS. So do I still have a prob at convert.bat point with those message? I did a lot of researching but I haven't quite understood yet... if there is any good page to read about building a main.hex could you recommend? Thank you -
Thank you very much stryd! I installed the program you introduced and stied to open batch file from cmd.exe but it goes C:?Documents and Settings?Takashi>perl hex2syx.pl main.hex Can't open perl script "hex2syx.pl": No such file or directory and nothing changed. honestly this is the first time for me to open cmd.exe and I have no idea what is going on there...I looked for the solution on the net but I couldn't find(may be I should say couldn't understand so far) If there is any idea or something could solve problem could you give me some idea? Thank you very much -
I built a box with 24 buttons (D1 - D3) and 19 enc ( 3 enc on D4 and 16 enc on D5 - D8) and I uploaded 64E, evrything seems fine except 3 enc on D4(they are recgonized as buttons with 64E right?), then I understood that I have to change "mios_table.inc" after reading forum. I changed as ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 4, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 4, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 4, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 5, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4 ENC_ENTRY 5, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 5 ENC_ENTRY 5, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 6 ENC_ENTRY 5, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 7 ENC_ENTRY 6, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 8 ENC_ENTRY 6, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 9 ENC_ENTRY 6, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 10 ENC_ENTRY 6, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 11 ENC_ENTRY 7, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 12 ENC_ENTRY 7, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 13 ENC_ENTRY 7, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 14 ENC_ENTRY 7, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 15 ENC_ENTRY 8, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 16 ;; encoders 17-32 ENC_ENTRY 8, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 17 ENC_ENTRY 8, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 18 ENC_ENTRY 8, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 19 ENC_EOT . . . . and I tried convert.bat but hex file doesn't look to be changed. after I start batch file window closes really quickly so I asume that it has problem there but I absorutly have no idea what is the reason. If anyone have any idea, please please help me! After a lot of problem and it's getting closer to finish the box I can't really sleep before completly finish it. Please!! Any idea will be very appreciated Thank you
resoldering Buttons and Encs
japanesepotato replied to japanesepotato's topic in Testing/Troubleshooting
I finally finished resoldering everything and everything works!!(not perfectly) but I guess all I need to do is software part so hardware part is done I think!! Thank you so much for your help!! I really really appreciate you guys help especially David, thank you so so much. ;D -
>I think you and me both stumbled upon one of the friendliest, most helpful and downright nicest corners of the web.. I'm planning to stay for a bit.... I really really appreciate for your big help!! :) I got pump and desoldering braid, wish me luck. BTW I really respect that you are so positive David. -
Thank you guys, I will go to look for those tools, Thank you David!! I really hope this thing is the only prob I have on my borad and solve evrything. ;D -
Do you have any tips to take parts off? :'( these 6 legs monsters are crazy -
OMG I found a prob! I installed every single resister pack backwords. I don't know why I decided that way. Thank you very much guys again!!!! ;D -
Thank you DavidBanner, Smash TV!!!! I will try what you saggested, I really hope nothing is burned or broken. :) -
I'm trying first DIN now and it seems from D0 to D3 on every lot work well but D4 to D7 don't work at all I connect them to ground and each of them have 3V. I can ground them to same pin with D0 to D3 go to right? Do you have any idea what the prob might be? -
yeah that's very true, if I finish this thing without anyproblems, I probably didn't try to understand the program as much as I do now. I guess by the time when I finish my box I will be quite ready for the next box. hee hee ;D -
Thank you very much!! I will try that app and try one by one. some of buttons worked perfectly so I thought it caused by my lack of soldering skill but now I think it's cause of I haven't used software propally because my software skill is worse than soldering. Thank you very much again ;D -
Hi there, I have a couple of quetions I will appreciate if someone can answer these, After uploading MIOS and app(64E), I found out my buttons works really badly and encs don't work at all and I decided to solder them again since it looks like it caused of bad soldering or wiring after reading this forum. Then I want to make sure that I'm not doing something wrong. I got parts from Smash TV and buildin MIDIBOX64E with 24 buttons and 19 enc I have 2 of DINx4, first one has 24 buttons on J3,4,5 and has 3 enc on J6, (D6,7 of J6 is opned) second DIN has 16 enc. onhttp://www.ucapps.de/mbhp/mbhp_dinx4_16enc.pdf 2 enc share one ground, but is it ok that 4 enc share one? Opned D6,7 of J6 on first Din, Can I just leave it opne since resistor network is already on the board? sometime when I turn on the swich, screen shows ???????????? . what is the reason can be? ??????????????????????????????????????????????? :-[?(reinstall solves this prob?so far) If anyone can leave some idea or advise I will really appreciate. Thank you very much
My first machine with smash TV's PCB
japanesepotato replied to japanesepotato's topic in Design Concepts
Thank you so much for your help. ;D I finally understood what I was wondering about for a month!! Have a good year!! -
Thank you so much audiocommander!! for introducing me all pages. :) Yes I'm planning MIDIBOX 64/E and it's possible to use some extra encoders instead of some buttons on DIN1 right? I read all pages and I'm still confused a bit. I understood DIN gose to J9 on core. http://www.ucapps.de/mbhp/mbhp_dinx4.pdf says J1 is 5 pins. but smash TV's PCB, DIN-J1 has 10 pins and Core-J9 has 5 pins. ??? How should I match them?? Do I use only 5 pin of DIN-J1? Best regards Japanesepotato -
I'm planning to build my first box and want to make sure I know what I'm doing.(after read many topics and pdf) Core - DIN 1 (16 encoders) - DIN 2 (3 encoders and 16 buttons) I know it's much simpler than what most of people building here but I already have a question... I got a PCB from smash TV(thank you!!), "J1 on DIN" has 10 pins but "J9 on Core" has 5 pins. To connect DIN to core, do I connect "DIN J1" to "J8 and J9 on Core", to "J6 and J9" or only to J9? if it's only J9 which pins from J1 on DIN do I use? or I have to connect each DIN separately to J6 and J9, like said on smash page "J6 on core" for DIN with encorders, "J9 on core" for DIN with (buttons/digital inputs)...am I getting it wrong?? I read some people asked same kind of question before, I read those but I still couldn't see how it goes... any reply will be much apriciated. please help me. thank you for your time. happy new year :)
