Raikard
    6
About Raikard
  • Birthday 01/01/1
  • Gender
    Not Telling
Raikard's Achievements
MIDIbox Newbie
  1. Thank you, i'll try! I have to control only one laptop with the mb64, the one that receives midiclock, so seems that the setting up can't be difficult, i'll see tomorrow. Rik
  2. Hi, as i'm going to do a liveset where 2 laptops must be syncronized, using ableton live, i'm wondering if there's a way to use my midibox64 to send or receive midiclock. If someone can help me...let me know how i must setup the device! Thank you all, Rik ;)
  3. Problem solved!! Was the inverted SIL! ;D Thank you Tim!!
  4. I think that the problem is found, could be the upper sil packages installed in reverse, because if the sil point one reported by you is the correspondant number one here: i've installed the upper sil in reverse for the two DIN modules. I will try tomorrow, thank you for the help, never thinked about the verse of the sil...i hope that this thing fix the problem!!!
  5. I'm sorry Tim, what you mean for backwards??? (my english is schoolastic!!) Burned?? Not working??? The strange thing is that all 8 registers for the 64 buttons have the same problem, first 4 butt works, the other 4 trig every one all the remaining 4.
  6. Hi to all and thanx for this great project! Yesterday after 2 months of work i've connected the power supply to my midibox and i'm so happy that the pots work!!! The latency is uncomparable to other midi ctrls, the mb simply rocks!!! The only problem that i've is with the DIN buttons. My midibox have 64 pots (works all), 64 buttons (here are problems) and 64 leds (at moment DOUT disconnected to find DIN problems). Here's the DIN problem: A single 74HC165N handle 8 buttons, when i press the first 4 buttons (one per time obviously) on the display i've this Butt1: *0000000 Butt2: 0*000000 Butt3: 00*00000 Butt4: 000*0000 On the remaing four (ever one per time!!): Butt5: 0000**** Butt6: 0000**** Butt7: 0000**** Butt8: 0000**** Before the disconnecting of the DOUT (leds) i've checked that 4 leds per time with a single button press (from butt5 to butt8) were on. I've checked that on the circuit nothing is in short...i've yet desoldered and resoldered the DIN in the afternoon..and nothing changed.. What can be??? Maybe something with parameters configuring or... let me know!!! The picture of my box:
