madmurdoc
    2
Everything posted by madmurdoc
  1. thx... so i would start with: 1 core_v3-module 1 d_out-module for the relays and LED#s 1 d_in for the buttons of the unit.....maybe possible manual mode, programming (if its possible) and so on... connecting a lcd for sure. would this one work ?? WINTEK WD-C2704M-1HNN http://www.pollin.de/shop/downloads/D120232S.ZIP, maybe i got another one in stock...just have to find some time for outparting some things... the other feature of my fcb1010, it has 2 expression pedals, but i really don´t know what commands it sends while moving them... maybe i would like to try a vonversion...expression pedal value --> resistance....for example with a motorfader or programable resistor ic...i think with a stereo motorfader, it would be possible to use the 2nd pot to check the position of the unit... i guess i should build further : 1 a_in module and 1 a-out modul. is there a freeware program or so, that displays all midi commands, that my foot controller sends, when its connected to my pc ? maybe this would make it easier to understand for me. i really dunno what my expression pedals do...giving fixed values for every position or just the difference of moved way..from powering up. ok i would say...i gonna build this, would be fantastic if i could get some help for programming...and for sure i will share a complete documentation... greetz madmurdoc from germany
  2. hi all. i have built some analog guitar effects and a 3channel tube preamp by now.....everything was built with a relay true bypass switching then i have a korg a3 multieffect, using it for reverbs, delay, eq....using a fcb1010 to control my guitar rack. what i would like 2 build, is an easy free programable midi in (from my fcb1010) to maybe 16 or more relay out contact unit. that i could program FREE...like this. programm change 01 from fcb1010: relay1 on / relay2 off / relay3 off / relay4 on........... programm change 02 from fcb1010: relay1 on / relay2 on / relay3 on / relay4 off........... programm change 03 from fcb1010: relay1 off / relay2 off / relay3 on / relay4 on........... i built by now for example... 1 accoustic sim stompbox clone, 2 tube screamer ts808 overdrive clones, build in a 19" 1 Hu.. every of those 3 effects has a separate input, output and relay plug... there will be some more in the future... and if i my fcb1010 sends the programm change XXX....my programmed effects for XXX should turn on...an my korg a3 should turn to preset XXX if i my fcb1010 sends the programm change YYY....my programmed effects for YYY should turn on...an my korg a3 should turn to preset YYY...and so on i have absolutly no plan of midi... a dream would be a unit with display...where i can program it like this ...change to program XXX... relayX on, relayY off.....and so on but i guess programming a switch matrix..on pc... would be much easier and cheaper.... does someone know a solution for this ??? thx ...madmurdoc
