midiboxxer
    133
About midiboxxer
  • Birthday 07/04/1982
Contact Methods
  • Website URL
    http://myspace.com/digitaltreatment
  • Gender
    Male
  • Location
    Neuried, Germany
midiboxxer's Achievements
MIDIbox Addict
MIDIbox Addict (2/4)
  1. The MB Link function should be the best solution. http://www.ucapps.de/midibox_link I think you can change the option with Seges Syx Editor: http://www.ucapps.de/howto_tools_syxedit_18f.html or in the code. Hope this will help you a little.
  2. Congratulations, well done! Greetings Markus
  3. Hi, nen Vorwiderstand brauchst du nicht, die Helligkeit deiner Hintergrundbeleuchtung kannst du ja über ein Poti am Coremodul einstellen.
  4. Good to hear and hope to see your result next time! ;D
  5. Perhaps this will fit: ;) http://www.reichelt.de/?;ACTION=3;LA=4;GROUP=A529;GROUPID=3013;ARTICLE=44901;START=0;SORT=order_col_artnr_besch;OFFSET=16;SID=29NxDA3awQAR0AABkh3aA352f106dd03198b8699d8c7c2baf872c
  6. This one is not black but looks good: http://www.online-schrauben.de/cgi-bin/onlineschraubende.storefront/473b29ca00791a04273fc0a8022305d9/Catalog/3353
  7. Which size do you need? P.S.: Looks like Shorty`s
  8. Yes, you got it. You should check if the keyboard merges the incomming data, but normally it should. The Snap, Relative or Parallax mode should work too. The midibox gets the feedback from the pc over the midi out of the keyboard. You will have a little bit latency, but that should be no problem. Greetings
  9. As discibed above. So you dont need an LTC module or an external merger. If you want to record the midimessages in detail with your pc, you can set the channel for the midibox messages and the keyboard messages different. Hope this answers your question.
  10. Than you can use the midibox 64 application too. But you should know, 4 buttoms are reserved for the menue navigation. So you will have 28 free programmable buttoms, 32 free programmable pots, 32 leds depended from your din module. You have to costomize the firmware e.g.: number of pots... But this is not very hard to do and you will find much help here. Greetings
  11. Hi, an welcome. First you should think about of what kind of midibox you will build. I built a cascaded midibox 64, there is the possibility to customize the firmware. TK provided this so. After you have done this all external midi in signals will be routet to the midi out port. Greetings midiboxxer
  12. Can you post pictures of the first dout module (both sides)?
  13. Download the midibox 64e application, there you can find the 16e. ;)
