alexglvr
33 -
About alexglvr
- Birthday 01/01/1
Gender
Not Telling
alexglvr's Achievements
Hello, I used a pic based Core to make a midi pedalboard. As I know how to use PIC micro controllers and that I needed very special features, I developed my own code (from scratch). In order to be able to update my pedalboard software if needed, without having to open the enclosure each time, I thought implementing a boot loader. Mios 8 is ready to use, with midi functionalities, and it could be a good solution... Just One question : Can I use it with my custom program or is it only working with Mios dedicated programs? All configuration are made by my program. It is fully standalone. Therefore, after Mios procedure, my program must be loaded and executed as if Mios was not there... Is it what it does? Thank you for your help, Alexandre
Hello, I need for my guitar Rig something I will call a MIDI Event processor. The goal is to scan the midi message and on some MIDI events, generate several pre-programmed midi command. After a long search not he internet, I found only one solution from "MIDI Solution", but the number of preset is too limited for my application. Therefore, I am exploring using uCApps solutions to make it. As I only know the Pic based core which I used for several applications, I would like to have your advise and be sure the STM32F4 Core can fit my needs. 1.For the programming interface I will need - 1 or 2 rotary encoders - a few (less than 10) switches - a graphical LCD display (192x32 based on the ST7920) 2. For MIDI, one MIDI_IO module should be nice 3. The USB connection and SD card interface can also be quite interesting. I suppose that STM32F4 core can support all that in the same time, but I would like your confirmation please? Now, the "big" problem is the memory. I need to store in the beast the presets. Each preset will be around 256 bytes (trigger, order to send, preset name, etc…) if I want 256 possible presets, it gives a total memory of 64kbytes. Can I use the STM32F4 Flash memory to store my presets or is it fully used by the program? Thank you for your help, Alex
Hello, I am working on a midi box project based on the PIC CORE. This project needs both Bankstick and LCD module. These two modules use The PIC #28 PIN (RD5). Will it create conflicts? Thank you for your help, Alex
Ok ! So if I want to build a midibox that receives orders from two different pedalboard, I see two possibilities: 1- The two pedalboards plugged on a midi merger, and the output of the midi merger to the MIDIBOX 2- Make a two port midibox. In this case, it could even use a single channel isn't it?
Thank you for your Help! I read several documentation on Midi but things are still a bit confused... Each midi component is attributed a midi channel ! But, this channel is only usefull for midi in, isn't it? But for example, for a midi keyboard with a midi-in and a midi-out, how does it work? If it is attributed channel 1, it sends midi orders on channel 1 and receive order on channel 1? In fact I am completely lost... lol Alex
Hello, My name is Alex, and I am working on a Midi Pedal Board project. For this, I get an old ENGL Z12 midi footswitch, that I emptiied to keep only the enclosure and the switches ! As I do not have much room in the enclosure, I will go for a custom PCB made with CMS components... Here is what I have : - 1 MIDI in PORT - 1 MIDI out PORT - 4 analog inputs (for external expression pedal / switchs, 2 TRS jack) - 12 input switches : 10 for midi message, 2 for bank up/down - 8 relays : 4 for external switching (2 trs jacks), 4 for 2 FXLoop (2x 4 TS jacks) - 16 Leds : 10 for midi switches, 4 for the relais, 2 for the FXloop - 2 seven segment digit that will be used to show the current bank number As I am making my own PCB, I thought adapting the Core whilestaying as compatible as possible with the original design... Here is what I was thinking : Schematic Is it a good configuration? Thank you for your help ! Alex
Hello, I am working on a midi project based on the PIC CORE module, and I was wondering something on the MIDI protocol: While reading a midi message, is it possible to know the midi channel of the Sender of the message? Thank you for your help, AG
I would like to use a PIC with USB 2.0 capabilities... I know I will have to nearly reprogram the entire MIOS but i am used to PIC development... Cheers, Alex
Ok so with some modification using a PIC with NO EEPROM memory should work...
Hello, The PIC based core uses a PIC18F452 which has 256 bytes of EEPROM Memory. I was wondering if this EEPROM was mandatory to build a midibox? If yes, could you please tell me what is it used for? Thank you for your help, Alex
Hello, i am working on a project, and i need help to design it, please!! The goal is to use the midi protocol to command the volume of Audio links (electric guitar type). For this, i will certainly use the pga4311 chips... My question is this one: The cable plug on my system can reach quite long distances (15m or so). How to know if the pga4311 can drive that, or if i need a driver/buffer chip??? Another question (which in fact is the same i think) : when designing a midi out module, how to compute and design the signal driver placed just before the plug? thank you for your help, Alex
Hello, I am about to make a Pedal Board to command my guitar amplifier and my multieffect rack. As i didn't manage to find a proper enclosure, i thought using a line6 fbv or fbv shortboard. I then have the choise between two options : - find a way to plug the line6 fbv on a pedalBox or - empty the fbv to keep only the switches, enclosure and expression pedals, and to put inside the pedalboard electronic. The second solution seems to be easier isn't it? Thank you for your advises. Alexandre
hello, the six pistons are working... For the moment they are sued to link the keyboards... The stops are not motorized. We thought about that, but to difficult (mecanicly speaking) and much more expensive to do... Maube later on....
Thank you for all your great comments !!! I can't remember how long it takes to my father... I will say 2 or 3 weeks full time job... The sound is also amazing. Hauptwerk is said to be the best church organ software... ++ Alex
Hello, My Father being a Pipe organ player, he decided, a few month ago, to built an electric classic organ to practice at home. The 4 Keyboards were made by Hoffrichter. The software used is Hauptwerk, running under WinXP Pro on a dual processor computer (2Go Ram, E-MU sound Card). The Wooden console was hand made by my father. The Midi project was to command the sound selection using Stops knobs (like in church organ). This was made using the MidiIO128 project. As I got lot's of help from the ucapps forum to realize this project, i wanted to post some photos for you. Here is the Finished Organ: Here is the detail of the Stops Knobs Switch Matrix At the bottom of this matrix, one per side, A MidiIn Card... Now, the system mounted with the Stops Knobs.... A Zoom... Thank you again for your Help. Without you, it wouldn't have been possible.... Regards, Alex
