mr_kholl
13 -
Everything posted by mr_kholl
Thanks reboot!! Jidis: Thanks Jidis!!! the tiny Brando keyboard will be very nice there..indeed. That's the original concept of my LC....the winamp controller will be an add-on, or a standalone setup. audiocommander: Thanks AC!! it would be a honor! nILS Podewski: The pinball thing seems really awesome!!! ;D Oh yeah...let the world to do everything with Midibox! ehehe
Ohh..Thanks a lot stryd_one! So glad you liked TK!! thanks a lot! I will keep you updated about the tut, before i publish it i could send it or post here for some check up. Once again thank you very much! :) Kholl.
Hi Ilmenator! :o Sure...input mistake.....already fixed! Thanks!
Hi TK, I created a new software called 'Midibox to Winamp', which allow you to control the Winamp via Midibox. It isn't a generic Midi translator like the Bome's software, besides the basic functions, there are some custom features. This is the list: - OSD - Volume, Track Pos and EQ Bands/Freqs - Basic Functions - Previous, Play, Pause, Stop, Next, Open file Dialog, EQ Band Left/Right, etc... - Virtual POTs (Jog Wheel style) - Volume, Playlist Seek, Track Seek, and File Dialog Integration (*). - Smart Playlist - Shows up the Winamp Playlist when you are seeking by the jog wheel, even if the winamp is minimized. Auto-hide the playlist when you stop the movement (according the show time set). - File Dialog Integration - Allow to interact with the windows standard file dialog box: Up, Down, Page Up and Page Down by virtual pots. Home, End, Level UP, Select All, Shift and Control by buttons. Enter by button or rotary encoder's built-in switch. - MIDI Learn/Setup - Where you teach the software to get the MIDI message and fire up a Winamp event or File Dialog event, also, allow to set the Rotary Encoders Sensitivity (movement speed). The main window: MIDI Learn/Setup: Systray Menu: About box.... I assembled a simple Midibox setup on the protoboard just to test the software: The setup: Note that the Playlist Seek rotary encoder has a built-in switch: The Midibox to Winamp in action: PS: The File Integration feature on this video had a little bug - Already fixed. TIca_Bjey7o Smart Playlist feature: 7VohfPiyhRE PS: At the point of the videos below I added two buttons in the setup: Toggle Shuffle/Shift (file dialog mode),Toggle Repeat/Control (file dialog mode). MIDI Learn: mwAKHvq877Y ...MIDI Learn cont....Encoder Sensitivity: XvFwER1r5vk Current File Dialog Integration: jM9fislLRAM Some friends (and members from the bit-tech.net community) asked me to create a tutorial and publish it at bit-tech.net. Of course, I will not post the uCapps.de docs, I will post the links so the users will open the uCapps.de website and there will learn about the Midibox world. My request is to publish some steps to create a Winamp controller based on Midibox. Of course, as you can see at the About box of the application, all the credits about Midibox will be for you and Midibox. PS: I have no plans to sell the software (will be freeware) or even the hardware setup and I know that the Section tittle is : Sale Requests, but I really don't where I could ask you about. Thanks, Kholl.
Does RS60N11M9 (5K version) works on MF Module?
mr_kholl replied to mr_kholl's topic in Parts Questions
Hi Roger!! Thanks again man. The problem is that i'm in Brazil and the seller in Germany!! hehehe...expensive shipping cost and long time to arrive here. I have to do it in one shot. If anyone else can inform it i really appreciate. Maybe some modification on MF driver... Roger, anyway i will search about the 5k pot issue. Thanks!!! Kholl. -
Hi, I'm one step to order some ALPS 60mm motorized faders from a supplier, but first, i need to check if it will work on MF module, because its resistance value is 5K instead the usual 10K (I.E. RSA0N11M9). This is the datasheet: http://www.modtv.com.br/mr_kholl/402331_RS60N11M9_5KB.pdf PS: You will see on the specs that this fader has the same pinout of the RSA0N11M9, including the 'touch sense' pin. Does anybody can inform me it? Thanks in advance. Kholl.
Testing MIOS on 40x2 VFD...** SOLVED **
mr_kholl replied to mr_kholl's topic in Testing/Troubleshooting
Hi TK, You are right again!! the problem was the cable!! I was talking with SmashTV on Wednesday, and he suggested to forget the bridge which i've made and make another cable, direct way: core -> display, exactly what you is suggesting now, make the same way which I did about the smartie. So yesterday i made it and BINGO!! worked!! heheheh....i tried to tell him about it, but only SoundDuke was active in the chat and he knew this news! thank you very much SmashTV Today i'm reading your post, and see that you are in the right way too!! This is the cause of the problem: I made this bridge to make it easy to connect the two displays required by LC app, but it's seems like the display doesn't like this!! hehe Well, i'm very happy to see MIOS running perfectly on the vfd: Now I see that LCD Benchmark was printing 1565 and not 5655 (or another wierd number)! The cable in direct way: Thank you very much for your support!!! congrats again! -
Hi Sasha, Trust me, it's true white in real. The blue is awesome and the amber is perfect! -
Hi Sasha, These are the Noritake's international contacts. Note that there's no info about Brazil (my country), but in fact they have a representative sales here, and I got my displays from this office here in Sao Paulo, so, the best thing to do is send an e-mail and ask for your country. I use PSC's optical filters. You can convert VF displays from green to white, blue, amber, red, yellow, etc....just need to apply the correct filter. I have 1 blue, 1 amber and 2 white (which in my option is the same effect) The white the filter is a kind of pink. You are right, you can't capture the true image of a display with a camera, it's really boring. -
Hey TK, Firstly, thank you very much for your attention and congratulations for the outstanding MIDIBOX!!! Well, I think you got the point! The spacing (definitely before) occurs with the characters: "G", "K", "M", "N", "O", "S", "U", "W", "Y", "3", "5", "7", "9", "^", "_", "-", "+", "=", "{", "}", "|", ";", "'", ">", "?"(two spaces) and "/". The others characters works perfectly. Note some pics: PS: Sequence of 20 characters "A" and "a" (Working, as well as "B", "C", "D", "E", "F",...etc....) "G" and "g" "O" and "o" (note the double space on "o") "V" and "v" (Aleatory spacing on "V") "u" and "s" (I sent only 20 characters as well as the others, but these are duplicating) I placed NOPs according your instructions, but nothing happened. Timing info: From the Datasheet: From the Application Notes (thanks SmashTV): I hope have posted nice tips to solve this 'mystery'. Thanks a lot. Kholl. -
Hi! This is my first attempt into the Midibox world. I have been working with displays for a long time, I really love it, I'm a 'display addicted' ;D You can see some photos of my 'babies' here: http://www.modtv.com.br/mr_kholl/kholl_displays.htm (Noritake's Dot Matrix VFD 258x128 and 128x32, Blue HD44780's 20x4 and 8x2, Blue T6963's 240x128 and Planar's EL 240x128 (my favourite) -------------------------------------------------------------------------------- I have plans to build a LC project, and since it's my first Midibox project, i decided to use two 40x2 Character VFD's, so, next time I will try to use dot matrix displays. You can see the two VFD's inside the red mark (PS: All images are thumbnails.). According to Noritake, the U-Series is a LCD drop replacement, it means that you can replace your lcd for this vfd without any changes in your code. In fact it's works well, the functions are quite compatible. Well, I made the wiring for the core module and did the first test: Ops....something is wrong (note the weird spacing): LCD Sendmessage in MIOS Studio: "Testing MIDIBOX" "ABCDEFGHIJKLMNOPQRSTUVWXYZ" I decided to made the wiring for the PC Parallel port just to test if the VFD is a really true replacement. Well, started Smartie, picked the HD44780 driver, and voilá, worked perfectly! (including animations), note that it ran without any special config, just plug and play. I have been talking with SmashTV, jimp, ultra, fossi.bs, SoundDuke, seppoman (sorry if i forgot someone) about this problem in the chat, and I would like to thank them very much for the support! After several suggestions I did the tests below: 1. Core assembly Check: Ok 2. LCD wiring Check: Ok 3. CPU mode Check: 8bit mode as well 4. LCD Init sequence Check: It's Original LCD Init code from mios_clcd.inc movlw 0x08 ; Display Off rcall MIOS_CLCD_Cmd movlw 0x0c ; Display On rcall MIOS_CLCD_Cmd movlw 0x06 ; Entry Mode rcall MIOS_CLCD_Cmd movlw 0x01 ; Clear Display call MIOS_CLCD_Cmd bcf MIOS_LCD_TIMEOUT1, 7, BANKED ; everything ok, make sure that LCD_TIMEOUT, bit 7 is cleared movlw 0x38 ; select 8-bit interface again BIFSET MIOS_CLCD_PIN_E, 7, BANKED, movlw 0x28 ; select 4-bit interface again rcall MIOS_CLCD_Cmd movlw 0x0c rcall MIOS_CLCD_Cmd movlw 0x00 ; set cursor to zero pos rgoto MIOS_CLCD_CursorSet According to a doc from Noritake it's the suggested Init procedure: So, I changed the original code and recompiled the MIOS: movlw 260 ; 260 ms delay call MIOS_Delay movlw 0x38 ; select 8-bit interface again rcall MIOS_CLCD_Cmd movlw 0x38 ; select 8-bit interface again rcall MIOS_CLCD_Cmd movlw 0x02 ; brightness 50% rcall MIOS_CLCD_Data movlw 0x08 ; Display Off rcall MIOS_CLCD_Cmd movlw 0x01 ; Clear Display call MIOS_CLCD_Cmd movlw 2 ; 2 ms delay call MIOS_Delay movlw 0x0c ; Display On rcall MIOS_CLCD_Cmd movlw 0x06 ; Entry Mode rcall MIOS_CLCD_Cmd Guess what?? nothing happened, still same spacing problem, note that it's my first try in MIOS, so I changed the brightness param to 50% just to check if I was changing in the correct place, in fact, the brightness param worked! 5. lcd_interconnections_test_v1 application Test: Pins about 4.58v 6. lcd_benchmark application Test: Result: 565 * 8 * 100ns or 565? * 8 * 100ns PS: the values wasn't clear because the position/spacing problem. 7. PrintChar test (One character per time): I filled the grid with a sequence of PrintChar command, from 'A' to 'Z' character using 1ms and 400ms of delay...the result is still weird! Checkout the videos: 400ms: http://www.youtube.com/watch?v=7zf4Xy0EIss 1ms: http://www.youtube.com/watch?v=4Dpj_ZRMtEk .... Any help? Thanks a lot! Kholl.
Hi DavidBanner, Thanks for your post. In fact, I've sent an e-mail to SmashTV and also a PM (here), I believe that he is very busy by now. No problem at all, just to know if someone have an idea about it. Thanks a lot, Kholl.
Hi, Long time reader, first post. Finally I'm ready (i guess ;D) to start my little project. I have a small recording studio in Brazil and have plans to build a mixing controller. CONGRATULATIONS for this amazing project!! MIDIBOX really is fantastic. Thanks a lot for share it! I tried to order some parts at avishowtech.com but I can't see my country (Brazil) in the country dropdown list. Is there anyway to order from here? Thanks, Kholl.
