dontplaymygame
28 -
Everything posted by dontplaymygame
so the midi preferences need to be: input-all on output-remote off
10x man it works now hurry ;D
ok the buttons are sending an on/off note, but can the note sound be eliminated in ableton? 10x
hi i just finish my midibox and everything is functioning normal, accept for one thing. when i press a push button from my midibox, a note sound can be heard on ableton.. does anyone know how i can eliminate that note sound and from where it is coming? 10x
having problems with my DIN 16 module
dontplaymygame replied to dontplaymygame's topic in Testing/Troubleshooting
yeah np about the questions. im constructing this midibox for my final school year project... ;D -
10x guys for the help i just diagnosed the problem.. 1. my midi to usb cable is crap (need to by another one) 2. i had a short in my buttons P.S this is my midibox ;D -
when i switch on the midibox the normal sysex message appears, but once i push the button it starts to send lots of random messages -
1. using DINx2 2. board is DIY 3. i am using the midibox64 application -
hi at the moment im working on my DIN module and i cant get it to work properly. im using a 16 input din. i tried using one push button and it worked, but its not displaying the note on the LCD...wat can be the problem? and do i need to modify any part of the program? 10x
:-[ sry my LCD hehe can any one help????
hi yesterday i managed function my AIN module but now im having problems with my DIN module..once i connected all the buttons, an internal bankstick message was showing on the LCD. now i disconnected all the modules and this message is being displayed on my PIC _ _ _ _ _ _ _ _ _ _ _ o o o o o o o o o o o can anyone help me out? ???
trouble with 16DIN and 16AIN
i found out wat the fault was; it was my crappy midi cable.. 10x -
hi i just finished my midibox, the only trouble im having at the moment is floating points. im using a 16DIN and 16AIN module, and i uploaded the midibox64 application on my PIC. all my unused inputs have been grounded and still im having trouble with random messages being sent from my PIC. can anyone help me solve this problem? and could this problem be because of the midibox64 application? 10x
cheers
hi can any one tell me if i still need to connect the resistors to the inputs of the din module if im using normally open buttons? and can i use this link http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf as my guide line? 10x
yeah i have already read the datasheet before but thats just the technical specifications of the PIC. i need more info about the sofware of the PIC which in this case is the mios and bootloader, thats my main problem 10x alot for your help i hope i get good marks for this project ???
ok maybe im not a pro :-X but its important to me to know whats going on in the program (at least some basic knowledge) if someone can help me out ill appreciate it alot ;)
ok i found the files..know what program do i need to use to open them so i can read them? 10x
emm my problems is im doing my midibox for my final year school project and i need to explain how the pic's program structure works..and my problem is i never programmed a pic before. so i need some sort of soft copy of the bootloader and mios so that i can learn wats happening. and which link do i need to use? 10x
hi is it possiable to obtain the C script of the bootloader and midibox applications? 10x
cheers 10x alot for the help
and is it possible not to use the DOUT module and just connect the matrix directly to the DIN inputs? 10x
hi i just bought a 4x4 matrix button PCB http://www.sparkfun.com/commerce/product_info.php?products_id=8033 now the question i would like to ask is: is there a specific program application that needs to be used in order to control every single button independently? and if yes where can i find this program application? 10x
hi i am trying to purchase 10K linear slider but at the moment i cant find 10K. the only close sliders that i found where 22k. my question is, can i use 22k slider instead of 10K sliders? and will it have any affect on the input voltage for the PIC? 10x alot :)
