nosferatuspacho
    4
Everything posted by nosferatuspacho
  1. that arming both ends, changing the channel from 10 to 16 midi everything goes perfect, except the hihat, The edrum has a controlling open close position of the pedal (mechanicall) and a separate hit sensor , but when i hit the pad for hihat sound don´t do anyting (aparently he chances the hh freq but no sound), but if i replace the trigger pad conection to the pedal conection, it sound when i hit that pad (in pedal input) and the hh sensor works like open close sensor, but if i hit speedy it sound a little times! (like much retrigger) but i doubt is not from edrum another question is for position pedal, he only works in hi hat piezo input! strange... is like MBHP fm has changed that commands... if you can understand me please help...
  2. here are come again, i progrese with info, its because pic got code protection, but i can´t erase fully, anywayi will try a little more, tanks to read post.
  3. hi, tanks to read this topic. I tink have problems with the MBHP burner, because test passed ok, but at least of process i got "1 error in config"? if all program process have passed like that: Chip erased 4 Panel(e) Start write to PROGRAM-Memory --finished Start write ID --finished compare PROGRAM, ID and EEPROM : -->0 errors in PROGRAM -->0 errors in ID -->0 errors in EEPROM Start write Configuration --finished compare CONFIG : -->1 errors in CONFIG i tried to upload mios on mios studio: mios_v1_9f_pic18f452 and pass but continue sending request every 2 sec. its normal? i tink can be damaged pic... but i don´t make nothing. also i cannot blank check pic, so many errors: PIC-Typ PIC18F452 Rev. 7 detected CP-Blocksize : 2000 Panelgröße : 2000 Chip erased Blank-Check : ## 24162 errors in FLASH ## 8 errors in ID ## 223 errors in EEPROM ## 4 errors in CONFIG it had code protection? how to fix it? please helpme.
  4. hola, tengo muchas ganas de construir un midibox fm y un edrum ;D, pero no se si funcionaran juntos los proyectos, tengo dudas sobre el fm, acerca de si necesito adicionarle la lcd, los led y los botones, o si no los necesito (como para editar en el pc y exportar via banksick) ???, si no es mucha incomodidad quisiese que alguien me ayudara a hacer el tutorial para llevarlo a cabo ;), estoy dispuesto a comprar los componentes (y conseguir los que no son adquisibles como el oscilador :o) que ya he cotizado, puedo subir fotos y tablas de datos, PERO NO SE POR DONDE EMPEZAR ??? ???. Comenzare armando el edrum, y luego el fm sinth (al parecer mas complejo). Agradezco de antemano a los interesados, ya que me parece que muchos han querido comenzar con esta empresa, pero de seguro hace mas de un año la habran dejado de lado. 8)
