zappso
    5
About zappso
  • Birthday 01/01/1
  • Gender
    Not Telling
zappso's Achievements
MIDIbox Newbie
  1. Fixed. It was either a dodgy connector to the board or a dodgy wire. That's what you get for recycling old IDE cables and connectors!
  2. The problem was simply due to the labels on the SmashTV DIN board being a bit misleading; using the 5 J1 pins furthest away from the labels on the circuit board fixed the problem and now I can see activity when I connect buttons and encoders. I've recompiled the MB64e application with settings appropriate for my setup. However, I have a new problem now. Whether I turn the encoder clockwise or anticlockwise, the value always DECREASES.
  3. Yep, the display does not change. I've got AIN boards connected to CORE:J5A and CORE:J5B, each has all of its analogue inputs connected to Vs. I also have a DIN board connected to CORE:J9 and a single rotary encoder connected to DIN:J3:D7/Vs/D6. When I rotate the encoder, I don't get any change on the display nor do I see any MIDI IN activity. Cool, another Melburnian Midiboxer! It would be great to all get together a few times a year or more. I'd be happy to organise this, maybe even organise a live event, as a friend owns a pub in Brunswick St and I'm sure he would oblige.
  4. Hi Stryd, Thanks for your reply, I will do some more testing on the core. I plan to use my MIDIBox as a control surface for Cakewalk Project5. I am using an M-AUDIO Audiophile (firewire) for MIDI IN/OUT. It's great that you are in Melbourne! Is there any chance we could meet? I'd be very interested to see your MIDIBox projects in action, and I think I could fast-track the solution to my problem. Don't worry, I'm not expecting you to just fix it for me, I did electrical engineering at Monash, was programming in assembly and designing circuits when I was 7 (yeah, I didn't get out much, can't catch a ball to save my life!). Drop me an SMS on 04300 29191 if you have some spare time to catch up. Kind Regards, Chris
  5. Hi, First of all, thanks to TK for making public such a great project! When my Midibox parts arrived, I spent an entire 2 days and constructed everything. Not wanting to wait, I mounted the pots and buttons onto cardboard, I suppose it's a Cardboard MidiBox at the moment. I powered the unit with 9VAC and got the MIOS 1.9f message, followed by READY. After a few weeks, I've had time to return to the project. I connected the Midibox to my MIDI IN/OUT, then downloaded and installed MIOS Studio. First thing I did after configuring MIDI Device Routing was test the MIOS LCD Message - success, yay. I then proceeded to download midibox64e_v2_2a, and used MIOS Studio to install midibox64e_v2_2a\main.hex. I get some output on the LCD display, but not what I expect from reading the documentation and forum. It is the same whether or not I have DIN R5 / AIN R4 boards connected: Int.1 [] [] [] [] [] [] [] [] 1 |CC# 7 [127] [] (The [] above is a full 8x5 block, and the first one on the first line is flashing a few times a second) The box appears to be ignoring all input from buttons and encs. On the DINR5 board, I tested voltages Vs->D7,Vs->D6, etc. and they were all 5V, this seemed to make sense as I understand they are high when open, tip to 0v to close. (Wondering if I had uploaded the right file, I tried uploading setup_midibox64.hex instead, and the LCD display went nuts appearing to scan inputs, but I couldn't get it to stabilise even with all boards connected and all analogue inputs connected to Vs. The box was unresponsive to MIOS Studio (the MIOS LCD message wouldn't work, saw no hex at all in MIDI In monitor), so I uploaded srio_interconnection_test in manual mode successfully, then after this bad experience re-uploaded main.hex. So, back to square 1!) If anyone could help, I would greatly appreciate it. Regards, zapps Melbourne, Australia
