peng12341
    3
About peng12341
  • Birthday 01/01/1
  • Gender
    Not Telling
peng12341's Achievements
MIDIbox Newbie
  1. peng12341
    Frage zu Befehl
    Hi, also ich würde in deinem Code folgendes ändern: Musst du die Werte für die Motorfader im Bankstick speichern? Du kannst sie doch auch einfach in ein globales Array speichern, oder brauchst du die Werte nach dem Ausschalten wieder? Die eingestellte Ebene würde ich auch in einer Variablen speichern und nicht nur über den Status der LED abrufen. Hier findest du noch eine Tabelle mit Midievents: http://www.midi.org/about-midi/table2.shtml
  2. Thank you very much stryd_one. It works now. @audiocommander: I already tried that, but that was not the problem.
  3. I'm using this code: unsigned int FX1; unsigned int FX2; const unsigned char FX_Names[10][11] = {"THRU", "F:92 LP", "F:92 BP", "F:92 HP", "F:T2 L/H", "F:T2 L/W", "Delay", "Reverb", "Flanger", "BeatMasher"}; int FX_Values[10] = {0,10,20,30,40,50,60,70,80,90}; ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after startup to initialize the // application ///////////////////////////////////////////////////////////////////////////// void Init(void) __wparam { FX1 = 5; MIOS_SRIO_UpdateFrqSet(1); MIOS_SRIO_NumberSet(4); } void DISPLAY_Tick(void) __wparam { //int n = 5 => works //or //int n = FX1 => does not work MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintCString("FX 1: "); MIOS_LCD_PrintCString( (FX_Names[n]) ); } Now I have the following problem: If i Initialize the var n in the display_tick function everything works well, but if i use FX1 instead (global var) i get a linker error: Makefile generated. Makefile.bat generated. Assembling MIOS SDCC wrapper ========================================================================== Compiling pic18f452.c ========================================================================== Compiling main.c ========================================================================== Linking project error: missing definition for symbol "__mulint", required by "_output\main.o" ERROR! I don't know why it should use that function. Has anyone an idea?
