cogsmech
    17
Everything posted by cogsmech
  1. Don't know if this helps. Mios hooked to core through us 122l mios to core.JPG mios to core.JPG
  2. yes i'm sure. I just tried my us 122l and the input matched the output
  3. I tried a different midi cable and it's the same
  4. Is this what you wanted? Input monitor is blank. mios out.JPG mios out.JPG
  6. It seems the file is too large to upload.
  7. Hello my friend, honestly, I'm feeling totally lost. I don't know hnow to send a screenshot of mios studio, however, the port routing appears to be correct if in goes to in, and out to out. If not I don't know how to change them. Yes I have an actual cable going from in to out on the midisport, and when I send the Midio128 hex.,I see stuff in the output monitor and not the input monitor. I don't see what could cause an "echo" as you describe. I don't know if it helps, but I have recieved ok checksums. Thanks!!
  8. Still no luck. Should I get note messages after only uploading the midio 128 hex, or does it need the separate ini. file? In which case shouldn't I be more concerned with mios studio than midiox? Thanks!!!
  9. I'm trying different low level output buffers and delays working with the loopback, trying to get the messages to match. Sometimes I am getting long strains of control messages in blue and sometimes have to disconnect the midi cable to stop it.
  10. Hello and happy holidays!! I'm back and still no midi :( I bought a midisport 1x1, tried several drivers, and the communications still don't appear to match. Actually it seems worse. When I send an upload or sysex, I can't tell if it's working.What am I looking for in midiox and mios studio as far as messages from the midibox? I tried sending the midio 128 syx through the loop back and I'm not getting matched input and output. I'm feeling kinda lost. I even tried using another computer. Please help!!!
  11. Sorry I didn't see the link. Thanks again for your time and I shall report back :)
  12. I haven't seen a "blacklist"
  13. Would a regular us 122 work?
  14. I just started my quest for midi again and I don't know if it'll help but I have +5v on the out midi port from center (ground?)to both of the terminals in question and nothing at all on the in port. Thanks!!
  15. Hello sir, I know I'm supposed to go as far as I can before I ask for help is all and all the posts I see everyone seems so smart. Ok well thank you very, very much for the reply. test prog 1. not sure what that means. test core 1, yes but is it right? # is a100abc, does polarity matter? test core 2, N/A? brand new from smash. test core 3, checked and checked and checked, I haven't done much electronics soldering but I do plenty of copper pipe silver soldering and understand how it flows, I think I did a pretty good job! also checked some with a continuity tester. test core 4, all checks out at 5.06 test core 5, all checks at 5.06 except j3, I cant find it. test core 6, this is where I started having problems, I,m not sure how to do this, I don,t get voltage when checked between the two points indicated. test core 7, I get .-0.16 one way and 0.20 the other way, not sure if I'm doing this right. test core 8, both about 217 test core 9, check test core 10, I don't get excess messages test core 11, cap is soldered well, I don't have a spare plus I haven't got a message like that test out 1, I have leds on my usb adaptor and they both flash ( tascam us 122l) I don't have any others test out 2, should I disconnect this? test pc 1, appears to be fine test pc 2, not sure what the settings should be, tried 256 and 512 and 60 ms. I'm kinda out of time right now. Am I going in the right direction? Thank you very much for your time, Conrad
  16. Hi folks, I tried not to come here but I'm lost. Please help! Ok, I've got a core hooked to just one din for now to try to get familiar with the system. I built the boards a week or so ago and couldn't get it working. I am a total newbie. I do have many hours in the forum and other places starting befor I even ordered the parts from smash tv. Initially I thought the problem was the octocoupler from some reading and the fact that I accidentally soldered it in without the socket. I bought 3 new octos from mouser and have tried two so I don't think that's the problem. Everything appears to be ok to me except that shorting the pins does nothing, even tried another din. Here's what I have on power up in midiox (no lcd) TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 001ADBCB 1 1 F0 Buffer: 2 Bytes System Exclusive SYSX: F0 F7 001ADBCD 1 1 F0 Buffer: 8 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 01 F7 Is this normal? I pretty much followed the midio mysteries pdf plus the diagrams on the smash tv site and have used the original (sample) ini . I followed the troubleshooting as much as I can ( I'm not a technician) I have a beautiful 32 note pedalboard just begging to come to life!! Please, please help!! Thank you very much, Conrad
