I'm using one of those AC wall wart with multiple voltages settings, set to 12V. The box says it can deliver up yo 1,8A. The plug is connected in parallel to j1 on the core and to this (http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY.php) board to get bipolar +/-12V for the aout_ng module.  Now I got scared from your statement since using this supply configuration with the bipolar ground connected is still turning off the box (lcd and aout_ng led turn off). By disconecting the bipolar ground I find 50Hz 20V peak to peak signals at the gate outputs, when at least it should be the opposite, no?   So it could be that I damaged the DAC? Anyway notice that going back to separate wall warts I'm stuck in the out-of-range/steady-out situation
