![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Naturebot
12 -
About Naturebot
- Birthday 01/01/1
Gender
Not Telling
Naturebot's Achievements
![Rank: MIDIbox Newbie (1/4) MIDIbox Newbie](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
Lexicon Lambda?? Anybody use it to load sysex to MB?
Naturebot replied to JRock's topic in Testing/Troubleshooting
I used it to upload programs, had to re-upload one that was only partially installed. Happy to report that it worked in the end! -
Gloss Red and Gloss Black MB-6582 panel sets back in stock : )
Naturebot replied to julianf's topic in Fleamarket
I want to add on to the pigpile too- I ordered mb6582 panels through julianf and love them. Much higher quality (and slightly cheaper) than FPD for a titch less cost. Shipping across the Atlantic Ocean only took a week or so. Very happy w/ them! -
Clem and everyone else- Thank you for the help! So, after searching about for months, I found the culprit- a resistor that rests under the master PIC was coded red-red-brown instead of vice versa, but the color was barely visible to me so I glossed over it! When I got in there and took out the PIC and measured it my values were indeed off. The beast is up and running now! No more issues uploading files and all appears to be working beautifully! :purple: So now on to the next project... modular analog drumsynth ensemble w/ Midibox CV and SEQ to control it??? Can't wait to get home and play around w/ this some more! Yeh yeh! Ian
Thanks Clem, I have tried it both ways with the same results.... still no luck.
OK So I let my brain relax a bit, got new optocouplers in the mail, soldered up the lcd and still am having the same issues. Specifically, I cannot upload hex files to the cores of my mb6582. In MIOS Studio I send a hex file and this happens (and nothing else!)- "Starting upload of setup_mb6582.hex Waiting for upload request... Received Upload Request Sending block #1 00003000-000030FF " doh! I've gone through all the troubleshooting and cannot find pinpoint any issues at this point. Here's my results... TEST PC1: All is good TEST PC2: worked fine TEST IN1: OK TEST IN2: OK TEST IN3: flickers (good) TEST IN4: lit up TEST IN5: Works fine TEST IN6: all good TEST IN7: all good! TEST INOUT1: all data sent was received and resent... endless data loop of sysex data Additional software checks: TEST SW1: Cannot program the hex file onto the pic TEST SW2: smashtv pic, n/a My LCD shows 2 bars at startup, gives the MIOS v1.9f message, and shows READY. I have now tried 3 midi interfaces with no luck! What to do? I've just about reached desperation w/ this and am convinced myself earlier I was ready to (I know! bad! I will not!) take this in to an electronic instrument repair shop. NO! :) Thanks guys, looking forward to getting this off the ground!
btw- a correction- With TEST IN7 above (reply #8) I had actually, amazingly, built that little circuit wrong, and all checked out as should be with the new optocoupers I tried today
Thanks for the help, I tried to upload w/ banksticks in and out (same results as before, both ways). I tried out a couple brand new optocouplers (and performed the standalone, not-in-core-module test on each beforehand) to the same results. I also tried unplugging the psu for a few seconds before attempting upload to the PICs and used very short (1 ft) midi cables. Still same result. I'm out of ideas, could this possibly be related to my MIDI interface (Lexicon Lambda)? Any help is greatly, GREATLY appreciated :) Ian
Checked all of these components, everything appears fine MIDI Troubleshooting tests- TEST CORE1: bought from Smash, so should be rtg TEST CORE2: n/a TEST CORE3: visually all looks alright TEST CORE4: all check out TEST CORE5: all check out TEST CORE6: all good TEST CORE7: ok TEST CORE8: ok TEST CORE9: ok TEST CORE10: Hmm, so this wasn't expected... When I used my Lexicon Lambda as my MIDI interface the situation outlined in above messages occured. When using my Novation Remote (NOT a Remote SL, which is blacklisted) I received an endless series of upload requests as outlined in this section of the troubleshooting guide. However, I tried to trace this signal path and check for any accidental solder bridges etc and didn't find anything. TEST IN1A: ok TEST IN1B: ok TEST IN2: ok TEST IN3: led lights, can't get it to flicker when sending a series of midi messages, perhaps just not enough of an effect for me to notice TEST IN4: led lights TEST IN5: LED flickers ever so subtly TEST IN6: LED stays lit no matter what! TEST IN7: no voltage measured from the test, whether switch open or closed. I tested 2 different 6n138's as I had one from when I initially tried a year or so back to build a midibox sid using the standard modular pcb's (not a mb6582) and had similar issues with my core. The optocoupler ripped from there reacted the same way as the one I received with the kit. TEST INOUT1: not receiving any data back into the input TEST PC1: ok TEST PC2: ok Even trying w/ 2 octocouplers I received the same results. Is this just a case of 2 faulty optocouplers? I've seen the messages that have said "when all else fails, its the optocoupler" and I just sent in a Fatman only to find out the optocoupler was faulty!!!! OPTOCOUPLER! I WILL DESTROY YOU!!!!!! :) Yeh, is that what this all means?
Just looking around the net to understand a little more about optocouplers (esp the 6n138), found this- http://forums.m-audio.com/showthread.php?p=52764 It looks like M-Audio issued a full recall on its lower level midi interfaces due to the little bugger. But, what may be of interest if this is common, is that there's a "fix" using 2 resistors that someone posted up there (see post #40). Just thought I'd share, still haven't tried anything on my midibox yet.
No, its a Lexicon Lambda. I know the question seems unnervingly noob-ish, but what I'm really unsure of is what to expect to see if a transfer is successful. Application transfers in MIOS Studio will get a confirmation message if all goes well right? Is my best bet to go to the midi troubleshooting then? Its so hard to wait to finish this project, I'm so excited to make some noise with this!
Wow, totally forgot about the troubleshooting forum... gahk! ok, have a lot of reading to do now :)
Hello all, I have mb6582 (smashtv kit) and all the tests on the base pcb construction guide have checked out, no problems to be found! I am at the point of trying to upload the testtone app with mios studio. I start the upload, have j11 bridged for the PIC in question (this is happening on all of them!) and the device ID set, plug in and switch on my midibox and the upload request is received. MIOS Studio sends block 1 and doesn't continue, no further acknowledgement or request messages are sent from the machine. This same problem occurs if I trying to upload the mb6582 hex file I've been reading all the documentation for a few hours now and am totally stuck! Anything I'm missing? Thanks in advance :)
