Hi,  I recently stumbled upon MIDIbox when reading up on some theatre and classical organs that were MIDI enabled.  I have been looking for a solution for some time that would allow me to improve functionality and eliminate unsightly (and ridiculously heavy) cabling on my electro-mechanical carillon instrument.  For the uninitiated, this is a Schulmerich Americana Bells instrument that uses small metal rods to generate sounds similar to those of cast bells.  Since it was built in 1962, it has thick "one wire per note" cables.  It contains many metal rods, capable of generating 61 notes of Flemish (carillon) Bells as well as 61 notes each of Harp, Celesta, and Quadra voices.  The factory's crowning achievement was the "Carillon Americana" which had a full sized organ console with pedalboard and a multitude of stop tabs at various pitches.  I was curious if I would be able to use MIDIbox (along with some stop tabs or buttons) to free me of the cable problem AND to allow me to have the flexibility of playing the various bell voices at different pitches.  I presume this should be possible, as this same technique is used all the time in unified organs for using one set of pipes to play multiple pitches and on multiple keyboards.  Automatically speaking, a mechanical clock controls the playing of Westminster chimes and hour strike.  It also triggers a continuous loop roll-player, which plays selections.  Ultimately, I would love to be able to record rolls FROM the roll player to archive them in MIDI format.  Implementing a MIDI-based "roll" player would then be possible with memory cards, which would be more reliable than the mechanical player and aging rolls.  It would also be possible to arrange new music for the instrument as well.  It would be cool to rig up a system to punch new rolls, however it would present some difficulty as the players were restricted to 25 notes of a single voice at a time.  Thus, they switched between an upper and lower compass of 25 notes (for a total of a 49 note range on rolls).  They also could be switched between voices.  That would require some custom arrangements coming from MIDI files, but nothing an editor and some creativity couldn't fix!  At any rate, I know this sounds like quite an involved project, but I am curious what the pipe organ folks have to comment on this, since pretty much all of this functionality is found in pipe organs somewhere.  The only thing I wonder is if I could convert the roll player to MIDI so that it could still operate for playing as well as archival purposes.  Any thoughts? :)
