Macron
    13
Everything posted by Macron
  1. Thanx! =)
  2. Thanx! =)
  3. Macron
    DARK MATTER
    Wow! I have the similar problem with CEM3379 in my MBSID V2. Perfect control (I use AOUT modul) VCF section (cut off and resonance control is ok), but problem with control of VCA section of 3379. I can change VCA voltage via menu parameter "volume", but I also try to route EG on VCA via matrux - no result :poke: . Whats wrong? :unsure:
  4. Hi Wilba! I need two kits :rolleyes:. Send PM to you.
  5. No. I don't turned the contrast pot, when display died, but now this is not important, VFD is dead. =((( Any way thanks a lot for yours answers.
  6. Ok, but how display works befor I udate mios to 1.9g? Pin 3 always be connect to V0, befor display dead. M202SD16AJ.pdf
  7. Thanks for you attention and help! :) All operations I made in MIOS Studio 2.1 Update to new mios was be correct – for Pic 18F4685 via midi. Once again, step by step: 1. I connect my VFD display Futaba M202SD16AJ via 4bit ( http://ucapps.de/mbh..._4bit_mios8.pdf ) to Core with Pic 18F4685 with mios v1_9d. After power on display show me “READY.†2. I load the last sid v2 firmware - V2.0_rc37, display show me how formatted my memory chips and after that I can see MidiBox Sid V2 interface on my display, I load patches and test the sound of my 6581. 3. I update mios to v1_9g, and after that I got a blank display (I see nothing) after this update. 4. I load again last sid v2 firmware - V2.0_rc37, display still blank (I see nothing), but my 6581 sound ok! 5. Post this topic. 6. Reset id to all zero via change_id app, load mios v1_9g, load last sid v2 firmware - V2.0_rc37, display still blank (I see nothing), but my 6581 sound ok! 7. I double check connection via lcd_interconnection_test_v2.zip, and check again data shit for my display and found one error… Pin 3 must be not connected, but I connect them to the V0 Pin on Core. 8. I load again last sid v2 firmware - V2.0_rc37, display still blank (I see nothing), but my 6581 sound ok! 9. I check another LCD display, it works fine!!! I kill my VFD via mios update, because I forgot disconnect Pin 3? I can’t understand what’s going on. =(((
  8. Hello! I have a problem with my VFD display Futaba M202SD16AJ. 1.9d - O.K., 1.9g - blank display. I use this schematic - http://ucapps.de/mbhp/mbhp_lcd_4bit_mios8.pdf, display work fine via mios 1_9d, (I use old pic 18F4685 from smash tv), after that I install the last firmware sid2, display still works fine, then I update mios to v1_9g, and after that i got a blank display after this update. This some bug? How I can fix it? Maybe I can back to mios v1_9d?, but I cant find any old mios version. Anybody can help me?
  9. Hello! Now I working on my Midi Box Sid: 2x6581 with 2x20 LCD and AOUT module for controling 2xCEM3379, all in one compact box. J5 I want use for analog inputs. My AOUT setup: #define DEFAULT_F2A_CUTOFF_L_AOUT 1 #define DEFAULT_F2A_RESONANCE_L_AOUT 2 #define DEFAULT_F2A_CUTOFF_R_AOUT 3 #define DEFAULT_F2A_RESONANCE_R_AOUT 4 #define DEFAULT_V2A_VOLUME_L_AOUT 5 #define DEFAULT_V2A_VOLUME_R_AOUT 6 #define DEFAULT_K2A_OSC3_L_AOUT 7 #define DEFAULT_K2A_OSC3_R_AOUT 8 ch7 and ch8 I want use for controling a two another analog synth. And now I have a few questions: 1. Can I use this setup for Multi Mode in this configurations - L (or R) SID play on midi ch1 and, at the same time, AOUT ch8 (or ch7) controling analog synth via midi ch2 ? 2. How I can get the gate signals for starting to play analog synths via 7 and 8 CV channels? J5 i want use for analog inputs, and can't use for this. I see on http://www.ucapps.de/midibox_sid/mbsid_aout_interconnections.pdf , but can't understand when happen triggering from "Gate 1" and why "Gate 2" not used ? 3. How i can do this for my setup ?: - GATE_OSC3_L_OUT = "Gate 1" from AOUT - GATE_OSC3_R_OUT = "Gate 2" from AOUT. If my questions very n00by sorry about that, and sorry for my english! =)
  10. Привет ÑоотечеÑтвенники! Ð¡ÐµÐ¹Ñ‡Ð°Ñ Ñ Ñ€Ð°Ð±Ð¾Ñ‚Ð°ÑŽ над Midi Box Sid’ом Ñледующей конфигурации: 2x6581, 2x20 Ñ LCD и AOUT модуль Ð´Ð»Ñ ÑƒÐ¿Ñ€Ð°Ð²Ð»ÐµÐ½Ð¸Ñ Ð´Ð²ÑƒÐ¼Ñ Ñ„Ð¸Ð»ÑŒÑ‚Ñ€Ð°Ð¼Ð¸ CEM3379, вÑе Ñто буде в одном компактном корпуÑе. J5 Ñ Ñ…Ð¾Ñ‡Ñƒ иÑпользовать Ð´Ð»Ñ Ð°Ð½Ð°Ð»Ð¾Ð³Ð¾Ð²Ñ‹Ñ… входов (ручки Ð´Ð»Ñ Ñ€ÑƒÐ»ÐµÐ½Ð¸Ñ Ð²Ð¾ Ð²Ñ€ÐµÐ¼Ñ Ð»Ð°Ð¹Ð²Ð°). Мои AOUT уÑтановки: # Определить DEFAULT_F2A_CUTOFF_L_AOUT 1 # Определить DEFAULT_F2A_RESONANCE_L_AOUT 2 # Определить DEFAULT_F2A_CUTOFF_R_AOUT 3 # Определить DEFAULT_F2A_RESONANCE_R_AOUT 4 # Определить DEFAULT_V2A_VOLUME_L_AOUT 5 # Определить DEFAULT_V2A_VOLUME_R_AOUT 6 # Определить DEFAULT_K2A_OSC3_L_AOUT 7 # Определить DEFAULT_K2A_OSC3_R_AOUT 8 СоответÑтвенно управлÑÑŽÑ‚ÑÑ 3379 и вÑтроенные в них VCA, Каналы 7 и 8 через джеки выходÑÑ‚ во внешний мир, Ð´Ð»Ñ ÑƒÐ¿Ñ€Ð°Ð²Ð»ÐµÐ½Ð¸Ñ Ð´Ð²ÑƒÐ¼Ñ Ð°Ð½Ð°Ð»Ð¾Ð³Ð¾Ð²Ñ‹Ð¼Ð¸ Ñинтезаторами. ЕÑть неÑколько вопроÑов: 1. Могу ли Ñ Ð¸Ñпользовать Ñти наÑтройку Ð´Ð»Ñ Multi Mode режима в такой конфигурации - L (или R) SID играет на миди канале1, и в то же времÑ, AOUT Ch8 (или Ch7) играет аналоговым Ñинтом на миди канале2? 2. Как Ñ Ð¼Ð¾Ð³Ñƒ получить гейт Ñигналы Ð´Ð»Ñ Ð¼Ð¾Ð¸Ñ… аналоговых Ñинтов которые виÑÑÑ‚ на 7 и 8 CV канале? ПовторюÑÑŒ что J5 занÑÑ‚ Ð´Ð»Ñ Ð°Ð½Ð°Ð»Ð¾Ð³Ð¾Ð²Ñ‹Ñ… входов. Я Ñмотрю на Ñту Ñхему http://www.ucapps.de/midibox_sid/mbsid_aout_interconnections.pdf, но не могу понÑть, при каких обÑтоÑтельÑтвах тригиритÑÑ "Gate 1" и почему "Gate 2" не иÑпользуемый? 3. Возможно Ñделать Ñледующие наÑтройки Ð´Ð»Ñ Ð¼Ð¾ÐµÐ¹ конфигурации?: - GATE_OSC3_L_OUT = "Gate1" из AOUT Ð¼Ð¾Ð´ÑƒÐ»Ñ - GATE_OSC3_R_OUT = "Gate2" из AOUT модулÑ. ЕÑли что очевидное Ñпрашиваю, прошу проÑвить терпение, Ñ ÑƒÐ¶Ðµ в течение долго времени читаю Ñтот форум и ucapps.de, но чёткого ответа так и не нашёл.
      • 1
      • Like
  11. has not set their status
