the_ungod
    9
Everything posted by the_ungod
  1. Ok, thanks... I'm building a pedalboard using this http://www.jimkim.de/html/guitar01_01.htm 5x, for 16 pedal, guitar A/B selector. amp A/B selector and plenty fo other functions... but in this case the code is already available and i just program the chip... I'll build these components (it will take about a month 'cause i'm missing 4x the above switch) Thanks
  2. Ok, So i need to build one of each, and programm the pic... (that's the question part....i don't know nothing of writing the code...)lol
  3. Oh... that's cool!lol I didn't thought of that.... So, from the dout to the led the question is explained... and about the core!? Thanks
  4. Hi again, I was misunderstooding the functioning of the three digit led... Has you said it's easier to use three separated led.. like these ones http://futurlec.com/LED/7SR3911AS.shtml ... I Think.... So, in this case i will need a common ground and 7 signals for each led...(7 x 3 = 21) DOUTx3 give 24 outs right ?!?!?!? Thanks
  5. Hi, So, for what i understood, for example if i use this led digits,http://www.bond-led.com/specification/led-numeric-display/0.3%20Three%20digit%20numeric.pdf i will need 2 dout modules ( eight digital outs) right?! Thanks
  6. Hi, I had already made a midi splitter. For the rest ( modules and so on) i´m a noob...lol Can you explain it better?! Thanks
  7. Hi, No, its not a midibox.... I need an interface with a midi input, then turn that input into the led number... no problem with the zero.. just need numbers from 1 to 128... Thanks
  8. Hi, I have a midi switch witch controlls relays acording to program change messages, and i need to know what the current program number... for example if i change de program to 1, the led display will show 001, if i change it to the 105, the led display will show 105 and so on... thanks
  9. Hi, Does anybody knows how to build a 7-segmente led display that show the current program number?! Thanks
