gvees
    5
gvees's Achievements
MIDIbox Newbie
  1. I think there will be enough space inside the J12. It's pretty big.. :) The expr pedals use the same technique as the Behringer. (LED with light sensitive receiver; a piece of plastic with a gradient on the pedal that moves in font of the LED - sensor receives less/more light and transmits more/less voltage accordingly) What kit would be best and most complete for my needs? Thanks for your help!!
  2. |I will gut the Johnson controller.. Want to dedicade it to MIDI controlling. I would only use the momentary switches and expression pedals which work like the ones in a Behringer BCF1010. You think it would be possible? I was thinking of getting a prebunred and programmed PIC from the AVI Showtech site. Than it wouldn't be to hard to build it am I right?
  3. Hey! Great topic and great info! I have a question.. I have a Johnson J12 footcontroller which has two expression pedals and twelve footswitches (momentary). I'm wondering if it would be possible to somehow modify this controller into a MIDI controller..? It holds a 27C256 PROM and works through a 7-pin cable which also supplies for it's power. If it would be possible to reprogram the 27C256 PROM that would be very nice, if not, I give up and will get myself a Behringer or something.. :)
  4. Thanks! I'll dive into it!
  5. Hi guys..! have been strolling around here for quite some time now and decided to take up on an old project of mine. I have this housing for a floorboard midi controller I'd like to use. What I want to use it for is: two expression pedals (for continuous controlling parameters) and 12 switches (2 for bank up/down, 10 for on/off switching). I really need some help from someone who could point me into the right direction where I should start, which controller I'd need and maybe an indication of how much programming is needed..? :) Thanks for any help! I hope I'm clear enough on this.. :console:
