Oli
10 -
Contact Methods
Website URL
http://www.ducktronic.de
Gender
Male
Location
Berlin, Germany
Recent Profile Visitors
Oli's Achievements
Thank you very much, Ronald! That was exactly the reason why the LED wasn't lighting up. Now it works!
I looked at exactly the same thing and thought the same thing. But since the firmware is relatively old and I couldn't find anyone else whose LED wasn't lighting up during my search, I thought it couldn't be the firmware. That's what I'm thinking too, but where do you turn this feature on? For me, for example, Sine+Random light up at the same time when I have a positive Sine LFO waveform. That's how it's explained in the manual. You should be able to turn off this display feature and turn on the separate LFO positive LED, right? It is installed in many MB 6582 models. (Picture attached) But when I compare the ASM files, I can't find any differences. And in this video, you can see at the beginning how the preset is changed and then LFO 1 has a positive triangle waveform. So there, the LFO positive LED lights up instead of the random LED. https://www.youtube.com/watch?v=FA0i5-bAfUQ
Hello acfnews, Thank you for your reply and your test. I suspect that the LED would indicate the positive range of the currently selected LFO. That would make the most sense to me. In some pictures and videos, I find SIDs that have this LED installed. But I have not seen it light up in any picture or video. Perhaps someone who has installed this LED and has it displaying something can say more about it. If you find out more or get the function to work, please let me know. :-) Best regards, Oli
Many thanks for the quick reply. Yes, I sent another function to this LED as a test and it then worked without any problems. So I can actually rule out everything on the hardware side. Unfortunately, I can't find many SIDs where the LED is used. I also couldn't find any videos on YouTube where someone has installed this LED and you can see it in use. In my *.asm file, the DOUT line looks like this (Shift Register 6): DOUT_ENTRY TMP5, 5, 6, 7 ; LFO Positive LED Is that all I need to enter for the LED function to work?
Oli started following MIDIbox SID V2 ‘LFO POSITIVE LED’ never lights up
Hi, I'm currently building a MIDIbox SID V2 with the complete Control Surface. Everything works great, except for one thing. The additional ‘LFO POSITIVE LED’ never lights up. I can rule out errors on the hardware side, as I have already assigned ‘TMP5, 5,’ to other DOUTs and the LED does not light up then either. However, other functions are displayed on the outputs without any problems. I have of course already changed the LFO DEPTH and RATE. With positive LFO waveforms, for example, Random + Sine lights up, as described in the manual. Can anyone tell me what the problem might be or does something else need to be changed in the code? Thanks!
Hello, about 10-15 years ago I built some MIDIBox projects and adapted the respective setup file (e.g. setup_8580.asm) and compiled a hex file from it. Since I was working on Mac OSX, Thorsten helped me to set up the whole thing so that I was able to do it myself. Unfortunately I have no experience with programming and compiling. These were the instructions at the time: 1. install Xcode 2. download gputils 3. open the terminal and go to the directory where gputils is located (e.g. Downloads) 4. enter “tar xfv gputils-0.13.6.tar.gz.tar” 5. tar file is now unpacked 6. use “cd gputils-0.13.6” to change to the gputils directory 7. enter “./configure” 8. enter “make 9. enter “sudo make install” 10. enter the root password 11. change to /Users/<name> with “cd” 12. touch .bash_login 12. open .bash_login 13. Insert “export PATH="/usr/local/bin:${PATH}”“ 14. save and close Setup completed 15. to create the hex file, change to the MIDIBox directory with the software in the terminal 16. enter “make“ 17. new hex file has been created Unfortunately the download of gputils at Sourceforge doesn't work (I tried Mac/Windows and different browsers) and I don't know which version I currently need. I also can't find a working download of SDCC anywhere. I was able to download “gputils_1.4.0.orig.tar.xz” from another site and install it successfully. I get as far as point 6 of my instructions, but nothing happens when I enter “./configure”. The terminal says “zsh: no such file or directory: ./configure” I myself use a MacBook Pro (2021) with mac OS Sonoma 14.6.1. Does anyone know what to do or where I can get the correct versions? Would other solutions (Xcode or MPLAB X IDE) be alternatives? I have already looked through countless pages and YouTube videos, but most of the explanations are far too old and no longer work or are no longer available. Thanks a lot! Oliver EDIT1 : By the way, I want to use a PIC18F4685 for a MIDIBox SID V2. EDIT 2: A friend helped me to install Gputils 0.13.7 correctly. Now it works without any problems on my MacBook Pro M1 Max 2021 with macOS Sequoia. So my question was answered outside the forum.
Hello, i've got a problem with my 808 Clap. The reverb of the clap starts too late. It's the same problem like discussed in the MB 808 Manual: "It was all right finally or so I thought, after a some chatting with Jeff, I found out the reverb delay bug on my box is still there, how to reproduce it/find out if you have it too: Start a pattern with some CP hits, the first step (some times more than one step, up to four in my case) don't have any reverb on it, some hits later the CP reverb starts to sound fine. Stop the pattern and wait some time, go play it again and the bug comes back. It sounds like it has something to do with C14 (original schematic). Just like it needs more than one CP trigger to get charged and once charged stays at a certain level until it is stopped for too long. Moogah: I've been tracing this problem on one of the units I have here, and what I've found is exactly what Etaoin describes (except I think he meant C76, which is the 47n green cap near the 2 1M resistors). Watching this cap on the scope, the thing that really bugs me is that the voltage settles to -10mV (?!) and I can't figure out why it's able to settle to a point below ground.. and we know from basic transistor theory that the 945 which creates the envelope here won't turn on until the voltage is above 60mV. When I worked out the RC time constant equation for this it made perfect sense that the cap needed a bit of "pre-charging" before there would be any appreciable envelope voltage above the 60mV cutoff point. My thoughts about this are: either the transistor should be biased closer to the 60mV turn on point, or there is a problem with the ground plane in this area which is causing the voltage to be lower than it should be.... Perhaps this problem is solved easily by reducing the 1M resistor which the trigger pulse comes in through, this would allow the cap to charge faster without affecting the discharge rate (I think..) By the way, I just came across a post on the Dutch synth forum where someone mentions (about a real TR808) "you shouldn't hear the reverb on the first clap, only on the subsequent ones" and someone else agrees. So at least some TR808's exhibit the same behavior." Does anyone know how to fix the problem? Thank you!
Hallo Antix, vielen Dank für die Information! Vielleicht meldet sich ja noch jemand der eine Lösung für das Problem kennt. Gruß Olli
Hallo, ich habe mein GM5x5x5 Interface fertiggestellt und bemerkt das die LED's unterschiedlich hell leuchten. Zum Beispiel leuchtet die Status LED beim MIDI Out Signal auf den Ports 1-4 normal, so wie es sein soll. Beim Port 5 jedoch leuchtet sie nur ganz schwach. Auch die MIDI In LED's leuchten unterschiedlich stark. Alle Lötverbindungen und Bauteile habe ich mehrfach überprüft und auch sonst funktioniert alles einwandfrei. Hat jemand eine Idee woran das liegen könnte? Vielen Dank! Olli
Hallo Acidtracker, auf der sicheren Seite möchte ich auch sein. Allerdings baue ich das CV Interface in ein 1HE Gehäuse ein und somit ist der 25VA Trafo, von dem du mir den Link geschickt hast, etwas zu hoch. Aber es gibt bei Reichelt ja auch diverse Flachtransformatoren von denen ich dann einen nehmen werde. Wahrscheinlich den mit 24VA 2x800mA (Best.Nr.: UI 39/17 215). Da ich kaum Erfahrungen mit "CV-Strömen" habe werde ich ja mit solchen Trafo hoffentlich nichts falsch machen können. Vielen Dank für deinen Rat! Olli
Hallo! Ich baue mir zur Zeit ein MIDIbox CV Interface mit 8 CV- & 8 Gateausgängen. Für die CV Ausgänge benutze ich die AOUT_LC Module wofür ich ja auch eine ±12V Stromversorgung benötige. Nun bin ich mir aber nicht sicher wieviel Leistung ich für die AOUT_LC Module brauche!? Kann mir deshalb jemand sagen wieviel VA der Trafo für das ±12V Netzteil mindestens haben sollte um genug Leistung für die CV Ausgänge aufzubringen? Vielen Dank! Olli
