hoxo
    4
Everything posted by hoxo
  1. Hi! I made a Traktor controller myself and I used 64 buttons, which I think is more than enough to control pretty much everything in Traktor (that's what modifiers are for, and with led lights to remind you what modifiers are on its very comfortable) . If you plan to use all 4 decks, I would recommend you to make something like 2x NI X1 My link and a mixer section. Try to minimize your designs and maximize peformance. Planing something carefuly is much better than doing it twice. Good luck with your project!
  2. Awesomeness! I fixed the problem. It was bad wiring, but i only had to redo 6 solder joints. Thanks again for your help!
  3. Thanks guys. Yeah, my wiring was a bit of a mess from the beginning (low heat), will look at that. I see a lot of work ahead of me(again). :ermm:
  4. As far as i know MIDI cc values range from 00 to 7F, yet almost all of my knobs on MB64 have a much narrower range(from around 08 to 7C). I'm trying to figure it out what the cause could be: -cheap pots -wrong power supply -something wrong with the midibox Did anyone had any issues like that?
