mQueue
    3
Everything posted by mQueue
  1. Hi Thorston, I took a look at the first link's code, does it make any difference that I'll be syncing to an external midi clock? Thanks again for your help.
  2. Hi All, I'm trying to figure out a way of implementing a note repeat feature in a midibox and having trouble getting my head around how it should be programmed. Note Repeat is a feature on the Akai MPC where a button is held and then the machine spits out continuous 16th notes or 8th notes etc. of a midi note received. I know I'll have to look at Midi Clocks being received from a Master and send note ons based on that, but I'm having trouble conceptualizing the steps to get the MidiBox sending out the continuous notes. Thanks in advance for any help.
  3. Sorry I posted this in 2 forums, I didn't realize there was a programming section. Hello all, I'm new to this forum and still trying to get my head around the midibox concepts. I would like to build a midi tranposition box and I'm wondering how much programming would be involved to do this. I don't know C but hope to pick it up. I know SQL and am somewhat familiar with computer logic. Here's what I'd like to do: Build a box that transposes fixed note values from a pad controller into different scales and modes. This box would have 16 channels of input/output and be able to select a a root note and scale/mode for each channel. The box would take the incoming note data (fixed values - pad 1 (first in scale) pad 2 (second in scale)....) and transpose these values into the correct values in scale. Here's an example of how the mapping would look for a C major scale: Scale: Major Root Note: C Mode: Ionian Set Note value 1 - 23 (C -1) (ROOT) Set Note value 2 - (notevalue 1) + 2 = 25 (D-1) Set Note value 3 - (notevalue 2) + 2 = 27 (E-1) Set Note value 4 - (notevalue 3) + 1 = 28 (F-1)...... Notes would continue to be calculated up using the steps of the scale. I'm not sure how modes would work, I would have to develop logic to have the mapping assignment start partially up the scale then continue on. I've been looking at the different midibox products and I'm not sure which would be best for this. Ideally I'd like to have a decent size screen. Thank all of you in advance for your help.
