tmarcel
    4
  • Gender
    Male
  • Location
    The Netherlands
  • Interests
    Midi
tmarcel's Achievements
MIDIbox Newbie
  1. I think we found the problem here! In my situation RN2 and RN3 are facing away from the IC. RN1 and RN4 are facing Towards the IC. Double check: so all the •6A103G textlabels will be facing the display? I would be very thankful if you could send me 2 new resistor networks so i can replace them.
  2. It all seems to look fine... I added 2 pictures. Maybe you can see anything strange...
  3. When i press the menu button in the top menu it indeed will go from A003 to A002. The down button works fine. Up button does nothing (as far as i can see).
  4. Dear Midiboxers, I am a proud owner of a sammichSID since this weekend. I installed the midibox_sid_v2_0_rc36 with the v2_vintage_bank.syx presets. I can play my presets from A001 to A128 without any problem. However i do seem to have some problems with creating my own sounds or tweaking one of the presets. For example if i have a sound (A003) and i press one of the 5 top buttons i enter the menu. In that menu i have the possibility to change the OSC, FIL, LFO, SAV etc. If i click OSC i go to the OSC menu. Here i can make my adjustments. When i have editted a parameter and want to save my change i need to press menu to go back to main menu where the SAV option is available. Here the problem shows up. When i want to go back to the main menu it will go back, but not to the mainmenu of the sound i just editted. When i editted A003 it goes back to A002 and so i lost all my changes. This way it is never possible for me to save any sound. I also noticed that the "up" button on the right bottom corner not works when i am in the menu. The "downbutton" works fine. I hope my problem is discribed clearly and that there is someone who can tell me what the solution to this problem is. is this a hardware or software problem? am i the only one who has this problem, or should i just be patcient till the next os update comes? Greet, Marcel
