Hey Flo. It's a small world, huh? What tube amps are you building? I built a few from the AX84 community. I started with the Hi-Octane kit, which I then upgraded to an SEL 20W with an EL34 in it. A couple of months ago I built an L2L Club which is a 20W Push-Pull amp with a set of 6V6's in there. Presently, one of the members from the community is taking a look at it, as I just can't seem to find the source of this annoying squeal I get when I plug a guitar in and dime the knobs. I was able to get it to about 1/4 MV without any squealing and then, once I tried to get any more volume out of it, it would start to squeal. I've tried all sorts of stuff and was going back and forth on the forum for a while. Hence, one of the designers of that project eventually offered to take a stab at it. I've also built about 20 pedals and my own pedalboard but now, I need something to put it all together without tap dancing on stage.
So yeah, I defintely want to pick this up but, like I said in my first post, right now I need some basic info about the Core and DOUTx4 modules before I proceed. First off, i'm assuming I only need one DOUTx4 module, of which i'll only be needing 1 and 1/2 of the 74HC595's, in order to run 12 relays/loops/pedals, correct? If that is so, I can just vectorboard 2 74HC595's and associated components, correct? Will I be limited to 7 patches per bank using the Core and DOUTx4 module? This is important as I was hoping to have 8 switches (one for each of 8 patches) on my pedalboard. How many banks can I get out of the 2 modules? I am shooting for something like 8 banks with 8 patches in each. Is it neccessary to use the ULN2803 to drive the relays? What other relay drivers could I use? You suggest using Mini DPDT relays but, which ones should I use? 5V or 12V? Does it matter which one I use? I'm assuming the banks and patches will get stored on the Core unit. Is that correct? If not, then I guess I will need some Banksticks in order to store all these patches and banks, correct?
I have a lot more questions but, if someone can answer these few questions, I will have a good start. Again, I am new to PIC based electronics and MIDI so please, have mercy. I know these questions probably sound dumb to some of you but, as you know, it's not easy to navigate thru stuff you just aren't familiar with. Ask me about scales, modes, polyrhythyms and the sort and i'll have no problems but, MIDI and PIC? Anyway, I appreciate any help.
Thanks
