Dnigrin
    4
Dnigrin's Achievements
MIDIbox Newbie
  1. Thanks again Nils!
  2. Thanks Nils, exactly the info I needed! Last question - if I *do* decide to go the battery route, since I'm also pretty clueless with electronics (though I can build things from a circuit diagram quite well), can someone point me to the circuit I would need to build to convert a 9v battery output to the required +5V?
  3. Hi Altitude - nice to see you here too! That *is* quite close to what I'm looking for. Programming in assembly is something I could do without, but it looks like I may be able to squeak by with the examples given. But the bus power is what I'm after, ideally. Anyone know if that's possible? Also - since you are dealing with a total midibox newb here - do I have to get the core PCB board and all of its components as well, or can I just get the PIC and connect power and my MIDI connector I/O to a few of its pins to do the job?
  4. I'm new to Midibox. I would like to build a simple, self contained box that will filter out active sensing MIDI info, and pass everything else. Ideally, I would like this box to not require power. Is this possible with Midibox? It seems that the core32 is overkill for what I want to do. I'm also unclear if I would have to power it via USB or something. Thanks for any tips or ideas.
