Argh! So, everything was looking good, ready to load in the MIOS.
Using a 12v unregulated, 500ma power supply, with 6581 Sids.
All the voltages checked out fine.
Installed the PIC18F4685, 74HC595's, 74HC165's. Left the bank IC's and the SID's out per the build guide.
Powered everything up. LED's flash on. LCD opens up to something like "MIOS by Franz", or something of the like.
Plugged into the midi jacks to get the operating system set up - strange behavior ensued. Turned off the Sammich. Turned it back on, the LED's flickered and the LCD was darkened. Turned the trimpot counterclockwise and got the squares. I checked and rechecked the voltage. Took the IC's out, put them back in. Checked solder joints. Made sure the shunts were placed correclty.
At one point, turned it back on, and a few of the LED's came on. The next time, none of the LED's. The LCD display continues to be the squares.
I wondered if this had something to do with the midi in connector, which was very sticky/tight and I had to force the midi cable a bit. Wonder if I knocked something around. It seemed like the problems began when I was using midi cables.
Appreciate any help.
Matt
