Let me start that if I missed something really dumb here to please excuse me. I have done much searching to find my problem as well before posting so if I missed a past post that would have helped please again excuse me.
Also I am experienced with loading chips (many types of CPU's, Mem, etc) so I post this with great dismay that I could not solve this on my own.
Now the history of what I have done.
I have a PicStart programmer which comes direct from Microchip, it has the latest firmware board update, I am using the latest MPlab software so in my opinion the programming hardware should be be an issue (but I may be wrong)
The first PIC18F452 I bought was preprogrammed from Smashtv and it worked fine, when I decided to continue building up my project I elected to buy virgin chips from the local supply house, they are the exact same part as SmashTv sent, PIC18F452-I/P. My first attempt to program them was to clone the working one I got from Smash which I figured should save me some setup time. It worked fine, I replaced the chip in my install and everything went as planned, it even transfered the Midi-map for MIDO128 (the module I am using). Now I bought some more chips to continue my build up.
The problem I ran into is that my cloned chips will not communicate with MIOS Studio!! Ok, I took shortcuts with the clone job so I went and setup the bootloader (1.9) from the download, pop'd that in the chip and SAME THING!! The only difference is that the Hail the chip gives off on boot once from the original preprogrammed chip is now repeating over and over. I figure that is normal since I have not loaded MIOS yet (Am I correct with that assumption?)
To make a longer story short now, I have tried everything I know to figure out the problem, looked at all the flags, config settings, etc. It acts like the User ID is wrong (It's all zeros for Device 0) However I tried MIOS Studio on ALL Id's thinking if that were wrong it would Communicate on some (unknown) ID.
What makes me even more aggravated is I only saved $2 per chip by not buying from Smash so let my lesson help others that may want to do the Virgin thing that it's not always a slam dunk. I should just to buy more programmed ones but now time is an issue and I really want to get down to the bottom of the!
Please any help or insight would be appreciated.
Jmayes
PS, the repeated Hail (via midi) I get when just fresh programmed with the bootloader is;
f0 00 00 7e 40 70 01 f7, same as the single hail the fully programmed SmashTv chip gives me at boot.
