oano
11 -
Everything posted by oano
Problems upgrading to full control surface (DIN, LED matrix)
oano replied to oano's topic in MIDIbox SID
Update: it works! Thanks guys. On with the project... /Ralf -
Ok great thanks, well hopefully I've located the problem now! I had no idea there were different kinds of arrays. The more you know huh. I'll see which components I can find tomorrow and hope I can continue with my project after fixing this issue... Cheers, /Ralf -
Ok, I've now tried changing the IC's to new unused ones of the same kind, and also tried changing them to the ones on the old functioning DINX2, and they are still behaving erratic. However, after googling my resistor arrays and comparing them with the exact Reichelt order# on the ucapps order list, I noticed there are 3 different kinds of arrays. I seem to have the kind that is "isolated" (no connection between pairs of resistor pins), but the one on the order list seems to be "bussed" (connection through the whole array). Then there seem to also be "dual terminator" arrays (a dual line of resistors connected to each other). Could this be the problem after all? I will try ordering the bussed kind and see if that helps, unless there are no other ideas on what could be wrong? /Ralf Edit: updated faulty info -
You are right, no random events are generated. Does this mean something is wrong with the IC chips? Could they have become broken from before, when I had misunderstood the connections and connected the pins in the wrong order several times? Or is this model maybe not compatible (SN74HC165N)? I can't see anything especially wrong with the soldering, but if all else fails I guess I will have to resolder... Thanks again! /Ralf -
First, thanks so much for all your replies and assistance, it means a lot! It seems I had misunderstood the order of the connectors between the DINs and DOUTs, so after switching them I start getting some more acceptable signals through, at least on the DOUT chain, which now seems to be functioning correctly. The LED matrix lights up in different patterns for each bank preset, which I'm guessing looks right. The two DINX4 circuits are still not working correctly though... I've tried the MIDIO128 application, and every time I connect either of the two new DINs I just get a lot of random signals. When I connect them using the setup_8580 I either get a "Cloning slaves" message (from the Menu button registering, I guess) or a lot of random signals here as well. My old DINX2 still functions correctly. From reading around on the forums I understand this could mean a short somewhere, but I don't see anything wrong on the PCBs at least, and it seems strange that both boards are completely nonfunctional, I'm not that bad at soldering and, as I said, the DOUTs are working fine... Could there be something with the components? The resistor arrays have 6 pins and are called Bourns 6X-2-103LF, are these acceptable? The caps say BC 104, and I don't suppose these have to face any specific direction on the board, right? I don't know what else to look for, and any further assistance would be very helpful, thanks a lot again! /Ralf -
Hello, hope someone of you knowledgeable types see this post some time in the future and feel like helping an electronics beginner in finally trying to finish his sid synth... I'm too unschooled in these matters myself, so I have no idea how and where to find what's wrong and I've now attempted everything I can think of myself. Sorry in advance for any hypothetical stupidity on my part. Basically, I recently decided to upgrade my old SID synth v2 (Minimal control surface, functioning), so I bought all the components I need, and then thought I followed all the instructions correctly, but I must have done something wrong somewhere since I keep getting these strange problems. I have so far built the LED matrix with its buttons, plus 2 DINX4s and 2 DOUTX4s (from SmashTV/midiboxshop). I have attached a picture of the whole build, so far. The problems are mainly two (so far): 1. The 2 DINX4s don't seem to be working, at all. I tried connecting the LED buttons to them, nothing happens. When I reconnect my homebuilt DIN from the Minimal control surface I get input from the buttons around the matrix, so they are not the problem at least. I have followed the soldering instructions on the DIN page on ucapps as far as I can tell. I've read about caps on the bottom side of the PCB, but I guessed those were moved, and are the ones now on top? I also guessed that the side with the dot on the 10k resistor arrays should face the arrow on the board. The ICs are called SN74HC165N, i don't know if that's the problem, since the ones on the old homemade DIN are a different kind called CD74HC165E. Would this make a difference? I attach a photo of the DINs. 2. The LED matrix acts strange. Firstly, it flickers randomly and faintly all the time, but I've read this might be relatively normal because of how the circuit is designed? At first, nothing else happened, and I had followed the instructions at http://www.ucapps.de/midibox_sid_cs/mbsid_v2_dout_default.pdf , and removed the resistor array at J6 on the second DOUTX4 in the chain and put bridges there instead. But then I noticed another diagram for my SmashTV PCB layout at http://www.ucapps.de/mbhp/mbhp_dout_8x8leds.pdf where the rows of LEDs are connected the opposite way (from D7 to D0 instead of D0 to D7), and also on the J3/J4 instead of J5/J6 of the DOUT... Does this matter? Isn't the default mapping made for the J5/J6 alternative? Anyway, when I inverted the connectors for the LED rows I got one bottom line lighting up on the matrix (see picture), rest still flickers. I have also attached a picture of the rear side, with the anode/cathode net, again, I've followed the guides and can't see anything that looks wrong myself. So I don't know what to do. Hope someone can help so I don't have to give up completely on this project. Thanks a lot in advance to anyone who might feel like helping out in any way, I'd be so very grateful for any assistance! /Ralf, Sweden
Ah jo, jag tänkte fel. Pin 15 är såklart kopplad till jord på pin8 och pin16 är +5V. Men även om man vänder på det, kan kondensatorn ligga mellan 15 & 16 (innan resistorn) eller måste andra kondensatorbenet till någon annan plats med jord? Enligt detta schema ser det ut som att det går (Jag gör en DINx2 förresten, för minsta control surface): http://www.ucapps.de/mbhp/mbhp_dinx1.pdf På 16 ligger där kondensatorn innan R9 (som ju går till +5V), och 15 är jord. Jag har svårt att fatta Eagle-schemat och soldering-guiden på DIN-sidan, dels för att kondensatorn inte är med i schemat och bilderna är så oskarpa. Jag har byggt kretsen själv också på ett experimentkort, så den är mycket mer kaotisk, med många fler små kablar och ställen där det skulle kunna finnas fel. Jag kan försöka ta en bild på den senare. Vet förresten inte heller hur enkodern ska kopplas in då jag inte kan hitta modellnamn eller datasheet till den, vet inte vilken pinne som är jord/d0/d1... Det är så irriterande bara, det är det sista jag behöver göra för att ha en helt fungerande SID-synt och så måste det såklart krångla! Jaja, hoppas det löser sig strax, tack igen för all hjälp.
Nytt problem nu efter ett tag, med DIN-modulen denna gång, de två knapparna (Sel 5 & Menu) plus rotationsenkodern fungerar inte på nedre delen av första IC-kretsen. Alla andra knappar fungerar. Jag har försökt söka efter information, om någon vet vad det kan bero på, annat än dålig lödning, hör gärna av er. Var lite osäker på kondensatorn på undersidan, kan jag ha den direkt mellan pin 15 (+5V) och 16 (jord) eller har jag tänkt fel? Annars vet jag inte, eftersom resten fungerar men jag får väl kolla igenom alla lödningar en gång till i så fall, även om allt ser bra ut vad jag kan se. Tack tack!
Det funkar! Tack så mycket, trodde inte man skulle använda det kopplingsschemat till senaste versionerna av korten också. Men nu, efter lite felkopplingar får jag rätt spänning överallt till slut. Väntar bara på en LCD nu så ska jag fortsätta. Får se hur det går, hör av mig igen vid problem. Ha det fint!
Tack för hjälpen! även om jag kom på det själv innan också(att de ska kopplas ihop). Så nu får jag ström i IC-socketsen, men fortfarande bara 4v. Ännu lägre än innan alltså. Ja, voltregulatorn är borta på core. Har ingen aning vad som är fel, det enda jag upptäckt är som sagt likriktaren , som verkar ha lite motstånd. Någon som vet något? Tacktack
Hej hej, jo jag är ny ja, har just slängt ihop bl a en SID-modul för att till slut få ihop en hel synt någon gång snart, som många andra här antagligen också har gjort. Jag tänkte att jag testar skriva här på svenska först för att det är lite lättare, om ingen kan hjälpa får jag väl testa engelska. Hur som helst så har jag byggt CORE-modulen och strömförsörjningskretsen för C64-trafon. Jag har kollat den senare kretsen, den funkar, delar upp spänningen i en 5V och en 14V. 5V-utgången går ju till CORE-modulen och den är också testad, får ut runt 4,7V i IC-socketsarna, vet inte om det räcker eller om jag behöver fixa något? (Har tagit bort voltregulatorn i CORE-kretsen enligt anvisning) Verkar bli ett litet spänningsfall i likriktaren och jag vet inte om det ska vara så eller inte? SID-modulen däremot, jag har mätt med multimeter och oscilloskop och det kommer in 14V som reguleras till 9V av 7809an, och det finns sedan även 9V i pin 1 på SID-socketen. Men när jag mäter mellan de pins som det står att man ska mäta mellan på ucapps-hemsidan (gällande SID v1, hittar ingen annan info ang. detta) får jag inget utslag alls. Det är alltså mellan pin 14 & 25 på IC1, och 8 & 16 på IC2 & 3. Så, vad kan vara fel? Vet inte var spänningen tar vägen helt plötsligt, och allt annat verkar se helt ok ut på själva kretskortet. Tacksam för hjälp i alla fall. Hare bra!
