Thanks for the fast response. I checked all the ICs and I did have 2 chips swapped. After confirming all the rest were in the correct positions the control panel and all the LEDs started working correctly. I proceeded to installing the bank chips and watched them format with no errors. I then uploaded the default patches which went fine. I then put in the SIDs (6582a), set the jumper horizontal, installed the 4 22nF caps (positions 1,3,4,6) and turned it on. It worked great and I started going through the presets playing notes off the keyboard in MIOS Studio, after about 5 minutes of lovely SID goodness, the unit just turned off like I had flipped the power switch. I turned the power off and then back on, however nothing happened, no LCD / LED activity.
I had unpulled the power when I installed all the components. I checked the power supply and it was still working correctly. I double-checked all the solder points on both boards, but didn't see any shorts. I then pulled all the ICs and the 4 SID caps off the bottom board and tried the voltage tests again. I'm not getting 5v at any of the points I was before. I am getting 9v off the left 7809 pin, but I'm getting 18v off the right pin where I should be getting 12v. The 0 off the right 7805 pin. This was with the multimeter set to DC. Any suggestions of what to do next?
Thanks again, I really appreciate it,
wallofnoise
