                Posts14
Contact Methods
												ICQ
												222866862
												Gender
												Not Telling
												Location
												Slovakia
alco-trencin's Achievements
	I already tried it, instead I gave 220ohm 100ohm, and the result is the same, I have to buy 47ohm and try it with them. But that's LED VU meter does not work for MIDI tracks is very interesting. I joined with other users MIDIBOXU_LC and also it does not work. But as has been described above, it is about AET SONAR software.
	OK, for me is working properly and the previous version MIDIBOX-LC :rolleyes: - I have a little problem with the only Level Metro LED diodes because some of my poorly lit. But this is probably due to the involvement that I've done. Because I found that the LED Bargraph is, each BC, EF, GH, JK common pinout. I did not know it involved other than that I have these two diodes used as connected in series, so I reduced the number of points but the level meter. But not at 12 to 8, as the common point of diodes in series pretending they are one and therefore less likely to shine. :whistle:
	I installed version 1_6e and everything behaves quite normally. I would notice any change. LCD works as before. I had something special test? :frantics:
	Should I question to Thorsten: - I do not know why but I never LEDs are off when the buttons in the group FADER BANKS and MODIFIERS. If I will test the LEDs light up, but not in normal use. :unsure:: ( - What is the function button HOLD LAYER? - Level meter shows the signal displays the audio or VSTi track, the MIDI track can not see anything, so right? Midibox I connected the SONAR software. Maybe it's somewhere in Sonar AET. Perhaps I wrote it clearly :flowers: Thank you for your help. Laco
	Thank you, and I have great pleasure;) I wish you a Merry Christmas and happy new year 2011, a lot of music and entertainment ... ;) ALCO :sorcerer:
	The complete photo gallery can be found at: www.midi.alco.sk/MidiboxGalerry :frantics:
	Done, work took me about two months. Total cost approx.: 600Eur. - I thank the creator of this project.
	So in conjunction with software SONAR button under the description templates for SONAR, I just tested it ....
	Please MIDIBOX LC users and software SONAR: What features are keys to your MIDIBOX LC? Valid descriptions of the original Mackie Control, or the description provided by the Mackie Control MIDI controller for your connection in the original software SONAR? I want to do for my description MIDIBOX LC, and I can not describe or name by original Mackie Control, Mackie or the master program for use in SONAR. Thank you for your early reply.
	Thank you for your advice, it helped. I know why I did not communicate and Cakewalk SONAR. I had to change line setup_midibox_lc.asm define (LC_EMULATION_ID 0x14) I had originally 0x10 so now everything is OK and I can continue to work on. ;)
	Hi all users of this forum. First I want to thank the creator of this idea MIDIBOX because his invaluable efforts helped many people. I am from Slovakia, I do not know English well, please excuse my grammatical shortcomings. After reading forums and websites uCApps.de I came to believe that you build your own MIDIbox LC. I ordered the parts company with www.reichelt.de My link. After a few days I have proposed the formation of the front panel, printed circuit board is made out and revived CORE module with 2x40 LCD. I attach some pictures: Gradually I will add pictures of implementation. With all efforts, I would like to ask for help. I uploaded all necessary files to the PIC processor. The display will show me a sign Logic Control Emulation Ready, I assume that this is correct. I wanted to try but the whole board CORE with the program SONAR 8.5 but failed to connect with a plate CORE software, the display is lit only writing and responding to commands with SONAR software. Then I tried Logic Audio software, and you have my software immediately discerned as a Logic Control emulation MCU. Now suppose that everything is okay and the problem will only AET SONAR for communication. - But I found that, in conjunction with CORE LOGIC CORE Audio unit still sends some data via MIDI. The display will still alter the value of volume, pan if accidentally. This is because I have no controls attached to the core module such as potentiometers buttons, etc. ...? Thank you for your help and advice ...
	Zdravim Vas, sice trosku oneskorene, ale prave som sa pustil do vyroby midiboxu LC, mam vsetky suciastky a momentalne navrhujem predny panel a rozmiestnenie prvkov. Je tu niekto kto LCcko dokoncil? ;) Laco, som z Trencina,Slovensko
