Hi,
With the SIDv2 you have to be in the first menu after power-on, then hold down shift while cycling through the different engines with the second menu-button.
It goes like Ld->Bs->Dr->Ml which stands for multi.
Btw, i'm quite sure, It's the same on a sammich.
i was able to access multi mode. tried to edit multi init patch to make it 6 voice polyphonic. checked to make sure oscillators were active, checked to see if filters were too low. poly mode is enabled as well...
unsure what i am missing.
i only seem to be hearing sound from the audio leds (sid1) on the right side, i see leds flashing for the right side but no sound. maybe sid 2 is dead?or am i missing something super obvious. again checked manual
to see if im missing anything but everything looks ok to me?
again any help appreciated
