6 -
About deepMago!
- Birthday 12/08/1977
Gender
Male
Location
Italy
Interests
Modding Guitars, building Stompboxes.
deepMago!'s Achievements
Solved! three days I'm working on and the problem was serial resistor on DOUT matrix. I'm sorry. Mattia
Ok, I have retry version 1.33pre1. The problem is still there. So now I will check my board because the behringer was cabled very different and could be there is a short that I've not found. Thank you so much for help! Mattia
Hi, thank you for the faster answer! Today I had try version 1.33pre1,2 and a older 1.32pre1 found in another topic. I not try with inverted DIN order, tomorrow I'll check. Thank you, Mattia This is my .NGC file: RESET_HW #SCHEDA 1 #Encoder MAP ENC n= 1 sr=3 pins=2:3 type=non_detented ENC n= 2 sr=3 pins=0:1 type=non_detented ENC n= 3 sr=3 pins=4:5 type=non_detented ENC n= 4 sr=3 pins=6:7 type=non_detented ENC n= 5 sr=2 pins=2:3 type=non_detented ENC n= 6 sr=2 pins=0:1 type=non_detented ENC n= 7 sr=2 pins=4:5 type=non_detented ENC n= 8 sr=2 pins=6:7 type=non_detented # Encoder events EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 fwd_to_lcd=1 type=CC chn= 1 cc= 16 label="Gain %3d@(1:1:2)%B" EVENT_ENC id= 2 fwd_id=LED_MATRIX:2 fwd_to_lcd=1 type=CC chn= 1 cc= 17 label="Tone %3d@(1:2:2)%B" EVENT_ENC id= 3 fwd_id=LED_MATRIX:3 fwd_to_lcd=1 type=CC chn= 1 cc= 18 label="Volume %3d@(1:3:2)%B" EVENT_ENC id= 4 fwd_id=LED_MATRIX:4 fwd_to_lcd=1 type=CC chn= 1 cc= 19 label="Reverb %3d@(1:4:2)%B" EVENT_ENC id= 5 fwd_id=LED_MATRIX:5 fwd_to_lcd=1 type=CC chn= 1 cc= 20 label="Time %3d@(1:5:2)%B" EVENT_ENC id= 6 fwd_id=LED_MATRIX:6 fwd_to_lcd=1 type=CC chn= 1 cc= 21 label="Feedback %3d@(1:6:2)%B" EVENT_ENC id= 7 fwd_id=LED_MATRIX:7 fwd_to_lcd=1 type=CC chn= 1 cc= 22 label="ToneRepeat %3d@(1:7:2)%B" EVENT_ENC id= 8 fwd_id=LED_MATRIX:8 fwd_to_lcd=1 type=CC chn= 1 cc= 23 label="Mix %3d@(1:8:2)%B" # LEDring-7digits Buttons configuration DIN_MATRIX n=1 rows=16 sr_dout_sel1=1 sr_din1=1 inverted_row=1 inverted_sel=1 mirrored_row=0 button_emu_id_offset=1001 DOUT_MATRIX n=1 rows=16 sr_dout_sel1=1 sr_dout_sel2=2 sr_dout_r1=4 sr_dout_r2=3 inverted_row=1 inverted_sel=1 led_emu_id_offset=1001 # modified ledring patterns for 16 LEDs # LED_MATRIX_PATTERNs LED_MATRIX_PATTERN n= 1 pos= 0 pattern=1000000000000000 LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1100000000000000 LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1110000000000000 LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1111000000000000 LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111100000000000 LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111110000000000 LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111111000000000 LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111100000000 LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111110000000 LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000 LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000 LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000 LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000 LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000 LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100 LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110 LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111 #7segments Display EVENT_LED_MATRIX id=9 fwd_id=LED_MATRIX:10 led_matrix_pattern=Digit1 EVENT_LED_MATRIX id=10 fwd_id=LED_MATRIX:11 led_matrix_pattern=Digit2 EVENT_LED_MATRIX id=11 led_matrix_pattern=Digit3 #buttons rows EVENT_BUTTON id=1001 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 01:01 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1002 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 02:02 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1003 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 03:03 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1009 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 09:09 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1010 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 10:10 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1011 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 11:11 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1017 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 17:17 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1018 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 18:18 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1019 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 19:19 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1025 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 25:25 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1026 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 26:26 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1027 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 27:27 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1033 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 33:33 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1034 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 34:34 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1035 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 35:35 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1041 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 41:41 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1042 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 42:42 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1043 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 43:43 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1049 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 49:49 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1050 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 50:50 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1051 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 51:51 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1057 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 57:57 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1058 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 58:58 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1059 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 59:59 lcd_pos=1:4:2 label="%d" #next 4 rows EVENT_BUTTON id=1004 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 04:04 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON id=1012 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 12:12 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1020 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 20:20 lcd_pos=1:4:2 label="%d" EVENT_BUTTON id=1028 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 28:28 lcd_pos=1:4:2 label="%d" #OUTPUT LEDS EVENT_BUTTON id=1001 fwd_id=LED:1194 range= 01:01 radio_group=1 EVENT_BUTTON id=1002 fwd_id=LED:1195 range= 02:02 radio_group=1 EVENT_BUTTON id=1003 fwd_id=LED:1196 range= 03:03 radio_group=1 EVENT_BUTTON id=1009 fwd_id=LED:1197 range= 09:09 radio_group=1 EVENT_BUTTON id=1010 fwd_id=LED:1198 range= 10:10 radio_group=1 EVENT_BUTTON id=1011 fwd_id=LED:1199 range= 11:11 radio_group=1 EVENT_BUTTON id=1017 fwd_id=LED:1200 range= 17:17 radio_group=1 EVENT_BUTTON id=1018 fwd_id=LED:1193 range= 18:18 radio_group=1 EVENT_BUTTON id=1004 fwd_id=LED:1210 range= 04:04 radio_group=1 EVENT_BUTTON id=1012 fwd_id=LED:1211 range= 12:12 radio_group=1 EVENT_BUTTON id=1020 fwd_id=LED:1212 range= 20:20 radio_group=1 EVENT_BUTTON id=1028 fwd_id=LED:1213 range= 28:28 radio_group=1
Hi, I'm working on a controller for my guitar pedal board based on MIDIbox NG. I'm try to use a heavy modded Upper PCB from a Behringer BCR2000 for 8 enc with ledrings and several buttons. For now I have the Button Matrix sharing rows with the Led Matrix. It have reverse diode connection. With the Ledrings set by an ENC with CC <16 the Button matrix works, with CC > 16 the button matrix stop work only for the button line connected with these ledrings. If I disconnect only the led row everything works fine with any ENC value. Hope my description is clear, my english is very bad! For now I know could be hardware problem but my first question is, it's possible to use Button Led Matrix with MIDIbox NG or I'm trying to do something that never work? I've read several topics an there is one () speaking about a different problem with Matrix. I'm interesting in try an older version (1.031) for test but I cannot find it. I attach my .NGC test file Mattia
Ok, after several tries seems works in this way: RESET_HW LCD "%CSimpleUSBmidiCON" LCD "@(1:1:2)PC Bnk " #bank1 EVENT_BUTTON hw_id=1 fwd_id=LED_MATRIX:1 bank=1 type=ProgramChange button_mode=OnOnly range= 01:01 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON hw_id=2 fwd_id=LED_MATRIX:1 bank=1 type=ProgramChange button_mode=OnOnly range= 02:02 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON hw_id=3 fwd_id=LED_MATRIX:1 bank=1 type=ProgramChange button_mode=OnOnly range= 03:03 lcd_pos=1:4:2 label="%2d" EVENT_BUTTON hw_id=4 fwd_id=LED_MATRIX:1 bank=1 type=ProgramChange button_mode=OnOnly range= 04:04 lcd_pos=1:4:2 label="%2d" #bank2 EVENT_BUTTON hw_id=1 fwd_id=LED_MATRIX:1 bank=2 type=ProgramChange button_mode=OnOnly range= 11:11 lcd_pos=1:4:2 label="%d" EVENT_BUTTON hw_id=2 fwd_id=LED_MATRIX:1 bank=2 type=ProgramChange button_mode=OnOnly range= 12:12 lcd_pos=1:4:2 label="%d" EVENT_BUTTON hw_id=3 fwd_id=LED_MATRIX:1 bank=2 type=ProgramChange button_mode=OnOnly range= 13:13 lcd_pos=1:4:2 label="%d" EVENT_BUTTON hw_id=4 fwd_id=LED_MATRIX:1 bank=2 type=ProgramChange button_mode=OnOnly range= 14:14 lcd_pos=1:4:2 label="%d" #OUTPUT LEDS EVENT_BUTTON hw_id=1 fwd_id=LED:17 range= 01:01 radio_group=1 EVENT_BUTTON hw_id=2 fwd_id=LED:19 range= 02:02 radio_group=1 EVENT_BUTTON hw_id=3 fwd_id=LED:21 range= 03:03 radio_group=1 EVENT_BUTTON hw_id=4 fwd_id=LED:23 range= 04:04 radio_group=1 # decrement/increment bank EVENT_BUTTON hw_id=7 id=1007 type=Meta meta=DecBank button_mode=OnOnly fwd_id=LED_MATRIX:1 lcd_pos=1:14:2 label="%q" EVENT_BUTTON hw_id=8 id=1008 type=Meta meta=IncBank button_mode=OnOnly fwd_id=LED_MATRIX:1 lcd_pos=1:14:2 label="%q" # 7 segments dout DOUT_MATRIX n=1 rows=8 sr_dout_r1=1 inverted_row=0 mirrored_row=0 sr_dout_sel1=2 inverted_sel=0 led_emu_id_offset=0 EVENT_LED_MATRIX id=1 fwd_id=LED_MATRIX:2 led_matrix_pattern=Digit1 EVENT_LED_MATRIX id=2 fwd_id=LED_MATRIX:3 led_matrix_pattern=Digit2 EVENT_LED_MATRIX id=3 led_matrix_pattern=Digit3
Hello, this is my first post here. Hope my question is not so stupid. Ok, I try to build a simple USB MIDI pedalboard that send Program Changes with a 7segments display. My Hardware: -STM32f4 core with the latest NG version 1.032 -1 display 2x16 -1 DINx1 built on veroboard with 8 buttons -1 DOTx4 - j3 Led matrix for 7segments - j4 d3-d7 cathode drivers -j5 led outputs - j6 not connected for now I've started with 4 leds and two banks. PC are 1-2-3-4 on first bank and 11-12-13-14 on second bank. My .NGC file: RESET_HW LCD "%CSimpleUSBmidiCON" LCD "@(1:1:2)PC Bnk " #bank1 EVENT_BUTTON hw_id=1 id=1001 bank=1 type=ProgramChange button_mode=OnOnly range= 01:01 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%2d" fwd_id=LED:17 EVENT_BUTTON hw_id=2 id=1002 bank=1 type=ProgramChange button_mode=OnOnly range= 02:02 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%2d" fwd_id=LED:19 EVENT_BUTTON hw_id=3 id=1003 bank=1 type=ProgramChange button_mode=OnOnly range= 03:03 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%2d" fwd_id=LED:21 EVENT_BUTTON hw_id=4 id=1004 bank=1 type=ProgramChange button_mode=OnOnly range= 04:04 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%2d" fwd_id=LED:23 #bank2 EVENT_BUTTON hw_id=1 id=1011 bank=2 type=ProgramChange button_mode=OnOnly range= 11:11 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%d" fwd_id=LED:17 EVENT_BUTTON hw_id=2 id=1012 bank=2 type=ProgramChange button_mode=OnOnly range= 12:12 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%d" fwd_id=LED:19 EVENT_BUTTON hw_id=3 id=1013 bank=2 type=ProgramChange button_mode=OnOnly range= 13:13 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%d" fwd_id=LED:21 EVENT_BUTTON hw_id=4 id=1014 bank=2 type=ProgramChange button_mode=OnOnly range= 14:14 radio_group=1 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%d" fwd_id=LED:23 # decrement/increment bank EVENT_BUTTON hw_id=7 id=1007 type=Meta meta=DecBank button_mode=OnOnly fwd_id=LED_MATRIX:1 lcd_pos=1:14:2 label="%q" EVENT_BUTTON hw_id=8 id=1008 type=Meta meta=IncBank button_mode=OnOnly fwd_id=LED_MATRIX:1 lcd_pos=1:14:2 label="%q" # 7 segments dout DOUT_MATRIX n=1 rows=8 sr_dout_r1=1 inverted_row=0 mirrored_row=0 sr_dout_sel1=2 inverted_sel=0 led_emu_id_offset=0 EVENT_LED_MATRIX id=1 fwd_id=LED_MATRIX:2 led_matrix_pattern=Digit1 EVENT_LED_MATRIX id=2 fwd_id=LED_MATRIX:3 led_matrix_pattern=Digit2 EVENT_LED_MATRIX id=3 led_matrix_pattern=Digit3 Ok, so my MIDIbox sends PC and I'm able to change Patches on my ZOOM ns50-g but with this .NGC file I see on 7segments only Bank changes and not PC. If I swap any EVENT_BUTTON like this: EVENT_BUTTON hw_id=1 id=1001 bank=1 type=ProgramChange button_mode=OnOnly range= 01:01 radio_group=1 fwd_id=LED:17 fwd_id=LED_MATRIX:1 lcd_pos=1:4:2 label="%2d" then 7-segments starts working and not turn off only the led of the modified .ngc line. In this case when change to bank2 the LED 17 stay on. Hope my description is clear. Anybody could tech me where's my fault?
