Los Zelos
    7
Los Zelos's Achievements
MIDIbox Newbie
  1. Very thanks, i used YAMAHA driver, and , red diode blinking every 2 secons. First idea was that drivers don't work properly. But out data (sending green diode have normal function). I also bought new chip and reprogramme with bootloader, now after complete check board and i dont know, where is mistake... I try to buy your solutions. Again thanks!
  2. Okay, board runing up but i have still problem with stable connection. when i start mios studio board is connected sometimes mios show me : after when i restart mios studio , sometimes board dont want to run up and mios show me screenshot 2. when i want to upload project.hex via mios studio, MS show me : where is next wrong ??
  3. YESSSS !!!! I found mistake in ID Location. I have to burn chip with 0000 0000 0000 0001! The code 0000 0000 0000 0000 is only for MIDI interface , if you using LTC you must change location. I found calculator @ www.midibox-shop.com/idgen.html and tried to reprogramme device. After that Mios write me your board is connected ^.^ Im satisfied and happy that my board running up!! :)))
  4. Why ? I started with simple building for first start. I dont need super device, i will be satisfied with old solution. I built only http://www.ucapps.de/mbhp_core.html, because i want to only copy "Traktorizer". I ordered interface cable USB to MIDI and im waiting for that from China. I have also only intergrated soundcard , therefore i cannot connect to Joystick connector, however now i have free COM port and therefore i wanted to try connect via that. Also on older computer i have Win XP , otherwise i have Win 7. I tryied that with YAMAHA To-HOST driver. Think you , that better is USB module from here ? http://www.ucapps.de/mbhp_usb_gm5.html ... Here is cable from China: http://www.ebay.com/itm/USB-IN-OUT-MIDI-Interface-Cable-Converter-PC-to-Music-Keyboard-Adapter-Cord-/271286969299?pt=US_Cables_Snakes_Interconnects&hash=item3f29f6a3d3 What way will be best for me ? btw, must i build the programmer from here with win soft for programming P18 http://www.ucapps.de/mbhp_burner.html ? Or is my JDM programmer with PICPgm sufficient ?
  5. I use JDM programmer from this page: http://www.schematics.wz.cz/schemata-PIC_Programator.html . With this programmer i tryied to load bootloader, if i understood right, i have to upload first bootloader with any programmer and connect the core via LTC to pc, after that, mios must show me that core is connected and with mios studio upload mios fw ?
  6. Hi guys, Im newbie in midibox, and i have problem with CORE module. I tried to find anwer in this forum, and i found one topic, where guy had short-circuit there. I found also one small short-circuit, but now im checked both PCB - LTC and CORE and i think that everythink is okay. I also read about ID field therefore i downloaded PICPgm Programmer and tried to power up. Still i only get this pictures: And ID field in programmer must look like this ? : btw .. I had shorted 6 and 9 pins of pic18f452 ... Is it real, that i send this output to silicon's sky ? I tryied everthing and im sad that i cannot continue in building ... :( therefore PLEASE HELP :( here is fuses from programer...
  7. hey boys, im good in pc and electronic, but im newbie at midibox... scheme and connecting is simple, but i dont know about software. My scheme includes 1x CORE, 1x AIN,2x DINX4 and LTC PCBs. My midibox missing DOUNT modules. Can i use standart MIOS (bootloader?) software for 64e or i must editing and delete section for missing modul? what i must do in next step? I will not read a lot of english text, because im newbie in english too :D May you say me problematic about software in cube? MORE THX FOR SUPPORT! =) Im dude from czech republic and i want to build midibox for playing Drum & bass in traktor =)
  8. Los Zelos
    fotky
