production
16 -
production's Achievements
clone hammond midibox64 mapping led (help)
production replied to production's topic in MIDIbox User Projects
Thank you for your quick response, I'll look into your suggestions. :phone: -
Hello, excuse me for English I'm French and I use google translation to English. I'm on a hammond clone now for 1 year on the basis of MIDIbox64, I come to the end but I have one last problem with the configuration of LED. Change presets to do thanks to key painted in black on a Hammond organ, and these remains down until the pressure of another preset button, this allows visualization of preset select. On a normal keyboard the key back automatically, so to view the selected preset I want to do thanks to LEDs, but faudrai for a precise group that led on by his touch preset goes out of another key preset lights another led. I hope I was clear in my explanation. I hope that this will be possible. Thank you
it will be super nice of you, thank you. And I await your return from holiday with impatience.
Hello, sorry for my English is not only a google translation of my french Well, I'm on the end of a MIDIbox64 for Hammond clone, but I do not understand how (despite the explanations I could Rescueing) replace the navigation buttons by datawheel in the program. I need help. Thank you in advance to all
Bonjour Voilà , je suis sur la fin d'une midibox64 pour un clone Hammond , mais voilà , je ne comprend pas comment (avec les explications que j'ai pu recuperé) remplacer les boutons de navigation par une Datawheel. J'aurai besoin d'aide. Merci d'avance à tous
Bonjour à tous , je viens de charger mon mios 1,9g sur un core (pic 4865), à la fin du chargement il me répond bien READY sur l'ecran , puis, je charge le HEX midi64v2 , et la, il me met "(in)-----" et en dessous "volume 64". Là , le fameux volume 64 clignote , enfin il plein d'inscription qui s affiche trés rapidement comme ci il avait à gerer plein d'info en meme temps. Ma question est: Est ce que c'est normal ? je precise qu' aucun bouton ni led n'est connecté sur le core . Juste les midi et l'alimentation. bien-sur j'ai testé avec 12 boutons mais toujours le meme resultat. Quelqu'un pourrait m'aider ?
Je viens de brancher l'ecran en version pour PIC 4685 l'ecran est bien allumé mais il reste vide et la moitié de celui-ci clignote toutes le 15 secondes en allumant tout les pixels (si je peux dire ça comme ça) J'ai charger plusieur apllication et aucune ne faire fonctionner l'ecran. changement de pic toujours pareil.
Salut, j'ai reussis à me procurer un ecran LCD , je vais faire des essais cet apres midi et je verrai bien ce que me dira l'ecran. Je te remercie pour le contact , je le prend precieusement avec moi. Pour l'ordi j'utilise une tour (Ordi dernier model tres tres puissant) Je fais beaucoup de 3D. J'ai aussi un graveur de pic , au pic des cas je vais essayer de cramer la flash et de la recharger. Encore des heure d'essai en perspective . PS: A tout ceux qui veulent se lancer dans l'aventure Midibox n'oublier pas une chose ça demande enormemant de temps.
je travail souvent à Besançon au casino en tant que pianiste . Je suis à coté de baume les dames. -Pous envoyer les info j'utilise le mios 2 celui qui est en téléchargement sur Uccaps. -Oui tout seul ou connecté c'est pareil et comme g monté 2 core g essayé les 2 , pareil, changer de Pic , pareil. -Les midi sont bien branché, essai de plusieur carte son , toujours pareil. -Par contre je n'ai pas d'ecran LCD je travail qu'avec le module sid et core -Oui pour le rencard , Je dis oui ne serai-ce pour le contact . -Oui g un appareil photo
Déjà un grand merci de répondre à mon appel au secours. -Alors mon PIC est le 4685, le mios est le dernier en téléchargement le 1.9g. -Je n'ai pas de capture d'écran pour l'instant mais je pourrais en faire. -Le tone ne se coupe pas , il marche très bien, très clair très fluide et ce, pendant plusieurs minutes. - A la fin du chargement (je ne suis pas tres bon en anglais) mais en gros voici le déroulement ; une fois le 38rc charger il me dit en gros "application / run" puis je rafraîchie, il me dit "bootload / run" je rafraîchie "plus de connections core 8 ou core 17", à chaque rafraîchissement c'est un vas et viens de ces 3 propositions, plus ou moins dans le même ordre, et souvent plusieurs fois le même avant de passer à une autre. je preçise que j'ai une impulsion constante avec le 38rc (toute les 3 secondes, module sid connecté ou pas) reconnus par le midi out, on entend ce petit Tac dans l'amplification et je la retrouve sur le voltmètre . Par-contre toute les autre appli compatible Pic 4685 sont stable, pas d'impulsion et rafraîchissement nickel. Tu habite dans le doubs? moi je suis d'haute Saône .
Apres plusieurs essais avec plusieurs applications , toutes les apllications fonctionne bien ( Midibox FM etc... ) seul le midibox sid 2 rc38 me fait perdre la communication Midi en alternance. Est ce que la mise à jour ne serai pas corrompu??
J'ai fais les test de connection et tone tout est ok, apparemment le probleme survient quand j'installe le HEX du SID
Bonjour à tous , J'ai un soucis sur la conception d'un mdibox sid v2. J'ai monté 4 modules SID et 2 cores commandé chez Mike . Mais voila au moment de faire les testes son avec un SID et un Core tous ce passe bien pour charger les HEX , par contre le son arrive une fois de temps en temps et ce coupe puis plus rien, puis je joue le son reviens mais qu'une seule note (style sustain) impossible d"en faire d'autre 3 seconde , puis le son se recoupe pendant 14 sec etc...... j'ai fais beaucoup de test pendant plusieur jours , changement de sid, de modules, de core, de pic, d'alimantation, de connection d'alimentation toujours pareil. Je penche vraiment maintenant. Donc a la fin je dis HELP!!!
En faite concretement il n'y a pas de PCB disponible finalement? Ou alors une eventualitée dans avoir dans un avenir incertain? Ouais si c'est bien ça, ca ne m'avance pas beaucoup, dans le projets MB 808. Je n'ai plus qu'une solution , l'ecriture d'un nouveau PCB avec toute les galere que ça entraine :blink: Alors j'aurai une nouvelle question, je la lance sur ce topic et si je n'ai pas de reponse je lancerai un nouveau sujet. Est ce quelqu'un aurai un peu plus d'info sur L'accent? comment est t'il geré au sein de la machine ? Merci pour vos reponses, et vos futurs reponses.
salut moi aussi je suis preneur
