LTC and mb-6582 question
reboot
I once bypassed the two NOT gates... i.e. connected the output of the optocoupler directly to the 220 Ohm resistor of the MIDI Thru jack. It worked... I did loopback tests with a PC via this MIDI Thru port and didn't get any errors. My theory was, if the optocoupler output could drive the PIC's Rx pin (which doesn't actually draw much current at all) then it could probably drive another optocoupler at the other end of a cable attached to a MIDI Thru port.
It works, but the buffers are a better idea and the right way to do it.
